0 Members and 108 Guests are viewing this topic.
stivep
ok I think I have got it ( if I'm totally not in error)
Signal from the antenna is delivered to be mixed with signal from generator utilizing Cristal oscillator.
That oscillator  reacts as heterodyne of AM receiver
Mixing of these two signals is being done in middle horizontally placed toroidal transformer... just as  the typical IF filter for  first IF
Typically you in the AM receiver have tiny wire (transformer) and ferrite  screw road that is screwed  inside and that is what make bandpass of filter tuning it to desired  frequency of IF.
Than to goes to amplifier (transistor) than there is step up transformer vertical  toroid that works as voltage doubler.
at the end of this on the secondary you have light bulb  220V LED
but the voltage delivered is only 100V 1 A.( if it is 1A... that current is only assumption of the presenter of this video)
That is  what is clever.... is being able to rectifier part of AM strong  RF field
with the help of 4 diodes  filter it with  capacitor and utilize it to power microchip and transistor. in means of DC
The light does not fluctuate with the presence of AM signal as the speech or music is being played because the AM modulated signal contains of  two sight waves and the carrier. If  frequency of  carrier is being utilized than carrier represents steady RF  voltage when  side waves fluctuate .
AM modulation is the modulation of amplitude of the carrier but in its spectral
form  you see  big carrier and two side waves from left and right.
Wesley
PS:
v shape wires might be inductive type of tunning.. where shape of that V  is altered to tune to carrier.
This device will work only in presence of nearby strong AM signal...
or if clever one .........tune it to frequency of power line  :)
Waves
Thanks Cosmo, i made week ago almost samekind of coil and it works. And now to the next step!
cosmoLV
Quote from: Waves on April 11, 2011, 01:50:55 PM
Keep your chakras opened :)
cosmoLV
Quote from: scratchrobot on April 11, 2011, 03:13:51 PM
Thank you, this is part 2 of schematics?
regards,
scratchrobot
This is not the part, but continue of schematics with revealed some parts unhidden
