0 Members and 86 Guests are viewing this topic.
scratchrobot
Quote from: cosmoLV on April 15, 2011, 03:51:30 PM
No, this info is about humans and our relationship with Nature â€" about Lies and True, True about Egypt and true about our civilisation and where we must go! Just read - it is true Knowledge...
I will keep that in mind and read it again.
Can you explain in what way your device will help us go where we must go?
I understand if you can not answer.
Respect,
scratchrobot
LtBolo
Quote from: MrPayback on April 15, 2011, 10:32:40 AM
It's all about symmetry breaking as Utkin stated and the Kapanadze patent shows. Heterodyne seems rather key from my experiments which makes sense.
Maybe. I see lots of discussion about breaking symmetry and such, and very few concrete examples of such working.
Where does the free energy come from? Until you can definitively answer that question, the rest is just speculation. I suspect that breaking symmetry does not create energy, although it may play a role in moving it.
Gut tells me Stiffler is close with discussions about cohering vacuum energy. Gut also tells me that the nature of FE is that the available energy is broadband and must be collected and cohered properly. Sparks are then about creating resonances with the widest possible bandwidth. Bifilar coils are about canceling inductance to create coils that resonate over the widest possible bandwidth. Unusual coil arrangements are about using electrostatic forces to nudge energy acquired from the broadband resonance to cohere and flow in one direction.
Think about it this way: If you had a room filled with small air conditioner units, all running, what would the average temperature in the room do? It would slowly increase...not due to the action of the A/C units...but only due to the heating due to electrical losses in the units. If you were to isolate the input and output of each A/C unit, and aggregate all of the cold in one place, and all of the hot in another...what would you have then? A huge amount of energy, that was well in excess of the amount required to power the units. Oddly enough, the temperature in the room would still be the same.
I think that free energy conversion is similar to that process. When we ring coils with spark discharges, we start powering the A/C units. They start cohering and pumping vacuum energy, the higher the amount of energy in the coil, the greater the amount of vacuum coherence. When we try to collect it using traditional means, we kill the action of the units and shut the process down. The curious bifilar coil arrangements are designed to gather the hot and the cold without disturbing the pumping action, and are specifically designed to operate on very wide bandwidths (because the energy is spread out) with the minimum amount of inductive damping.
Heterodyning may in fact play a role by shifting energy from a wide band to a narrow band...that wouldn't surprise me at all.
Just my theory, and until we see a functional device, one theory is as good as another.
core
Quote from: scratchrobot on April 15, 2011, 04:26:57 PM
Respect,
scratchrobot
He doesn't mean you are 'physically' going somewhere. After reading the book I can tell you that it is very similar to another very popular book called 'Conversations with God'. This book came out in the mid 90's and spent a huge amount of time on the New York Times bestsellers list. Actually the section regarding the souls progression through levels is almost identical if memory serves.
Regardless both books borrow heavy from the writings of 'Edgar Cayce - The sleeping prophet' as he was called. And the philosophy of reincarnation or the 'souls' return to a new physical body is a wide held belief in many religions. The majority of Christians with the exception of a few denominations reject reincarnation.
Ultimately it goes like this. Some people are on a higher plane of life then others. At times a 'higher authority' sends a messenger to assist in 'moving' things in the right direction. These messengers are not just religious people such as Jesus or Moses. People such as Tesla, Maxwell, Beethoven and maybe even Tariel are specially selected (higher level) souls that are periodically sent back to help/assist the lower level souls in an effort to direct mankind in the right direction.
One important thing to understand, what is considered a good idea now can have horrible ramifications in the future. The old 'Action/Re-action'.
Respectfully,
Core
Choose username
http://www.youtube.com/watch?v=VlMU9H3-ShE
ANOTHER ONE DID IT !!!!!!!!!!!!!!!!!!!!
NEW SR !!!!!!!
:o :o :o :o :o :o :o :o ;D ;D
(published by delamorto, at this time I dont know who did it)
cosmoLV
Quote from: Choose username on April 15, 2011, 06:20:02 PM
NEW SR !!!!!!!
One Russian guy  :)
i hope it not publish schematics for now, it is to early now, very big problems by that step can be made. But someone tell that he are ready to publish it... ehhh...
too fast it is, too fast
Keep your chakras opened :)
