0 Members and 517 Guests are viewing this topic.
MrPayback
Quote from: scratchrobot on April 16, 2011, 06:50:23 AM
Who is helping them? I think he is helping us and everytime he does people start talking negative about him. I personaly see more thruth in the space invader story than in the bible.
scratchrobot
1. If I want religion, I'll give up logic, reason and accountability and join a cult like all the other morons.
2. If I want space invader stories, I'll rent a copy of Star Wars.
CosmoLT is openly discouraging the sharing of information on this subject and you support that? See point #1.
He posts a fake schematic every few days and it has been going on for months. The latest just got posted in this thread under one of his multiple usernames such as CosmoLT and FreeEnergyInfo. Maybe that should be FreeEnergyDisinfo?
And furthermore, you don't need to keep posting the Wiki one page at a time. It only dilutes and buries useful posts.
They are not using 50HZ as claimed. They are using anywhere from 140KHZ to 500KHZ depending on the ferrite. Tiger explains it well here:
Procedure of the determination of the frequencies of the resonances of cores.
How do you do gentlemen.  To me enter many questions employing the procedure of the determination of the frequencies of [rezonanasov] of cores.  There are many forms of the resonances:  magnetostriction, acoustic resonance, it is magnetic - nuclear resonance. There are other varieties. That resonance, where the gear ratio factor of core is most effective, interests us - this can be any of the enumerated resonances or their combination, without the special equipment, we in practice cannot determine what type of resonance we it is utilized accurately, but we can be disposed. By us the following instruments will be necessary for this:  1 . the signal generator of square pulses on the interesting us frequency band. It is good, if the adjustment of porosity is allowed, still must be smooth reconstruction over the range. 2 oscillograph for visual monitoring, it is desirable, that according to it it was possible to determine frequency.  3 frequency meter, if by oscillograph it is not possible to measure frequency or if high accuracy is necessary.  If the signal generator of high quality, there is no need for frequency meter.        In the radio amateur's practice two methods are accessible, it is better to use both. Let us allow there is a core with the locked magnetic flux, for example ring from ferrite or P descriptive halves from [TVS] or another form of core, on the large very many of difference.  For the beginning it is necessary to be determined with the frequency range, which it approaches for our purposes. It is desirable, that it was sufficiently wide. Method 1.  We wind around the core by any wire several turns and connect to the square-wave generator. Generator must issue sufficiently high signal amplitude, to us it is necessary from 5 volts and it is above. To the same coil we sit down the probe of oscillograph and it is observed picture. Most likely we not [uvidem] beautiful square pulse, then it is necessary to play a little by porosity, if there is no this adjustment - it doesn't matter. Us interests not pulse itself, but small ringing (dying oscillations) behind the trailing edge. We increase picture and we measure the frequency of this ringing. Then we change the oscillator frequency and we again measure the frequency of ringing. If measurements coincided, everything is good. Let us change the number of turns and it is repeated procedure. If measurements again coincided, then everything is excellent. We measure this frequency and we make outline under it.  If instrument does not make it possible to conduct such measurements, there is another method. It also sufficiently precise and makes it possible to reveal the harmonics, on which also it is possible to work.  Method is number 2.      At the opposite ends of the core we twist two identical windings. To one let us give signal from the generator, here the quality of signal is not separately critical. To another winding we connect oscillograph and it is observed after the signal amplitude, changing the frequency we find such, at which there will be the greatest amplitude. We measure this frequency. We change a quantity of turns of both   windings we repeat operation.  If the measurements of frequencies coincided - everyone, we found frequency necessary to us.  A change in the quantity of turns of windings guarantees against the error. It is possible to randomly measure the resonance of the wound coil. This excludes this method. Necessary to us frequencies (harmonics) there can be several.  So it is possible to select most suitable.
On April 13, 2011. tiger2007
energia9
Quote from: MrPayback on April 16, 2011, 12:01:42 PM
CosmoLv is obviously a lier...  if he would wanted to help, he would have done it long time before when he started blabbing about his rubbish schematics which are not even correct....
i have smiled on your 1 sentence :
this is soo true.      and in this case  there are a couple of religions like Cosmos ,  its like we all wait for one thing promised by a liar.
just like in religion...
cosmoLV
Quote from: energia9 on April 16, 2011, 01:36:38 PM
when you see schematics you all understand and why i need to lie? (you already are the Guru of the WORLD and you know how it works? will you? ;) stay cool
i do not stand for ANY Religion, religion is sickness of human kind â€" just to be clear. ;)
Today all your wishes about Free Energy will be clear, just take care on resources and some videos from this Positive Man who are explaining what where and why...
Next step will be to make improvements â€" he has some different things and problems with Output but this is not big thing... This Ferrite like i say in may video, are toy â€" nothing serious, but what we can do together is to make it without Ferrite, i have ready make some start point on this â€" what i will release in that video â€" if you already it see or not see jet somebody or i will share with you and together we make real device. Because like i say Ferrite is not so big deal, but anyway the principle is the same...
ou...! Yes and thanks for "Good" words â€" very interesting to read  ???
Keep your chakras opened :)
