0 Members and 490 Guests are viewing this topic.
ramset
HHMMMmmmmm
I'd be happy to see the "Really Bright Light" that Mr.PayBack Spoke of,running on "Cold Electricity"!!
That's all, just that one little thing,{teensy even,Maybe weeensy!]
Would be Nice....................
Chet
Thanks Grandma
core
Quote from: stivep on April 18, 2011, 09:11:53 PM
Kapanadze DID NOT USED FERRITES AT ALL ...................Period. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
This has been well known for the better part of 8 months. This was stated on the Next-energy, 001-lab, Energetic, and this forum. Also Tariel himself has stated 'No' to ferrite BUT did not dismiss the use of iron. So we go round and round. From the beginning there should of been a separate thread for 'ferrite' based devices. As a matter of fact CosmoLV stated in October that his ferrite based device had an output of 400 watts or so. He also stated that the max output is around 600 watts with a very well tuned unit.
As far as the Turkish unit and the 24" spark. OLD NEWS again this was well known since last year that the large 'spark' was just for show and that the natural operation of the unit was with a wire connected were the spark is.
The problem is that it takes time to read a long thread. So people generally ignore the past and re-post as if original. Member LtBolo ask CosmoLV directly on this thread the purpose of the ferrite rings (paraphrasing). Does anyone remember Cosmos answer? It was a direct answer that had LtBolo surprised.
There is a lot of good stuff written on this thread last year. Most if not all of the stuff written this year is just garbage. More then one person has already written that this thread has gone to $hit. The only thing left to do know is clean off the work bench and get ready to work on June 20th. Maybe the Moderators can lock this thread and a new one, specifically dealing with the project on hand, could be started. This one has been well polluted recently with false anomaly after the other.
Hopefully on the next thread, if there is one, better 'thread management' can be implemented. This will go a long way in defeating the anarchy that typically prevails.
Respectfully,
Core
core
Quote from: ramset on April 19, 2011, 09:35:16 AM
HHMMMmmmmm
Chet
Why are you doing this? It's sad I think you lost a lot of credibility.
-Core
stivep
One of the members has ask me that question
QuoteTiger2007 lied about his device?
Wesley's response:
No he did not lie
He never stated that this device will work for ever.
(Well  the only punishment of Tiger is the one that comes from me ... I said  nice trick.)
For 100% I will know after me or someone  will make replication
For me it should work till the capacitor is discharged.
3Hz my friend... How much time do you need considering that the only moment of discharge is width of pulse.
What we do not know is what is capacity of capacitor.
But we may assume current and we know  the voltage.
Question:
How much  time do you need for 12 litters of water to flow  vertically down if the thickens of the pipe is 1 mm inside diameter.?
Than starting  from that assumption
calculate speed of light as speed of electric current in the conductor
knowing that some of electrons will travel hours...
........yes hours
before they will reach distance from point A to point B and the distance is............. 1 meter .
surprised?
maybe you ,,, not me..
Wesley
MrPayback
HHMMMmmmmm
Chet
Mary,
The camera does not pick up that extreme white light but you can see the reflection on the white table does convert some of the light.
