0 Members and 174 Guests are viewing this topic.
LtBolo
Quote from: core on April 19, 2011, 09:53:15 AM
Member LtBolo ask CosmoLV directly on this thread the purpose of the ferrite rings (paraphrasing). Does anyone remember Cosmos answer? It was a direct answer that had LtBolo surprised.
Not even sure I remember. ;)
I see 3 possibilities for the ferrite.
1. Per the Michel Meyer-Mace patent, Fe56 to Fe54 transmutation with release of power.
2. Per Dollard, power generation through change in inductance due to ferro-resonance or other disruption of the ferrite medium via electrostatic or magnetic action caused by a spark discharge.
3. Per Stiffler, an antenna to gather cohered energy.
If I recall, Cosmo suggested #1 and #2 at different times and in different ways. It seems pretty obvious that #1 above would likely result in degradation of the medium eventually. No clue how long. And I think I recall Cosmo expressing frustration when someone cited the Michel Meyer-Mace patent...thus violating 'Dress Code' by revealing too much. And I'm pretty sure I remember a reference to parameter change at some point, which is #2 above. It's all a bit fuzzy at this point though.
Personally, I am on the broadband energy coherence bandwagon right now. That would explain a number of devices very nicely, does not require ferrite (although it can play a role), explains the need for either a spark or very sharp edges, it uses resonance but not necessarily in the way it is normally thought of, explains the need for bifilar coils, and a handful of other things.
MrPayback
The man who's corn I find most delicious ( d. ) showed you most everything you needed to know regarding this subject. He did it in a covert way so as to not attract attention. Those that are awake, noticed and replicated Tesla's hairpin and from there the possibilities for understanding and creation are limitless.
For example  - When he showed you the copper pipe with the nail he was teaching you how to convert radiant energy. Hector also wrote about this and claimed that the outer tube and the inner tube must have the same mass AND must be the length of the wave you are converting to fully convert.
When he connected the end of the copper coil to the MOT he showed how the cold electricity potential can be given direction in order to increase output. There were many subtle lessens that people may have missed.
REPLICATE AND UNDERSTAND THE HAIRPIN AND you are half way there. You have to destroy the positive energy in order to absorb the negative. When you have both, the ball goes from bouncing off you hand upwards to the ball bouncing off the floor. Bouncing the ball of the floor takes far less work since it is being bounced from two opposite potentials.
LtBolo
Quote from: MrPayback on April 19, 2011, 11:31:24 AM
We started with the hairpin. It was fascinating, but did not appear to demonstrate free anything. The hairpin is simply a way to generate a high frequency standing wave in a low inductance, yet high Q, resonator. Fun stuff. Most so-called 'cold electricity' effects can be explained in terms of being high-frequency.
Free energy isn't in implementation methods, although understanding those methods is likely key to producing results. The looming question remains: Where does FE come from, and how does it get from there to here?
core
Quote from: LtBolo on April 19, 2011, 11:22:01 AM
The answer was 'Parameter change' the number 2 above. I think this was sometime in late October. You may recall rather jokingly telling CosmoLV that we was 'slipping' because he gave you a direct answer.
One of the things that Tariel spoke about very early on was a 'Resonator'. I don't recall the interview exactly but it took place around the time of the 'Green Box' video. The question was something like 'Where does the energy get collected?' The article stated he pointed to the 'Green Box' and said 'from the resonator'. The resonator was inside the Green box.
Oh well time will tell.
Respectfully,
Core
core
Quote from: LtBolo on April 19, 2011, 11:41:52 AM
I think I even uploaded an old book written in the 1900 or so regarding the Lecher arrangement. If I can find the book i'll uploaded again for those interested in a very detailed explanation of 'Standing waves' that are produced from this arrangement.
Respectfully,
Core
