0 Members and 928 Guests are viewing this topic.
Yucca
Thanks Thaelin and Goat for the horizontal ground rod info, I'll look into doing this.
@Jesus and All,
Here's a pic of my finished HV supply along with a schematic. For the 100ohm 0.5W resistor you can of course use 2 * 200ohm 0.25W resistors in parallel which are easier to come by.
At 20V PSU it takes just under 600mA (so close to 12W) but the arc is tremendous at over 3CM! And what's more amazing is that the transistor is only barely warm despite only a small heatsink.
Dare I try and take a digital photo of the 3CM spark? Maybe I will at a distance using zoom on the camera.
Yucca
youtube vid of it running, I always keep at least a couple of meters away using zoom so it's a little shaky:
http://www.youtube.com/watch?v=Eg2prMlRm7U
flathunter
Quote from: Yucca on July 30, 2009, 10:56:42 AM
OK Jesus, I'll hand draw a schematic and photo it tonight along with the finished supply, I've just finished putting it on a board. It runs real nice at about 20kV using just a small 9V battery.
9V battery??  It sh*ts on my 12 V battery 30 kv power source.  I'm gonna make one!
Great video, great link, keep up the great work!
Yucca
I can only recommend it flathunter, I've had this thing singing for 30 mins and the heatsink was maybe 20 degreec C over ambient, never have I seen 12W being dissipated at multi kHz with so little heating in the switching transistor!
I think this 13005 Transistor is something real special, less than a buck a piece from ebay china.
Quote from: Thaelin on July 30, 2009, 09:07:39 AM
Down convert anyone?
Yes, I think the term "down convert" will be a major term used in the eventual theory of operation of this device. The magic will probably happen at a really high impedence level in the aether itself perhaps originating in the scalar field which then couples to the RF electromag field and then this device might be able to tap into that oscillating field without damping the origin? Down conversion could well be the important piece of the puzzle. A bridge between two worlds so to speak.
nievesoliveras
@Xenmorphlab
I do not have oscilloscope. I even dont know how to use it.
Thank you @yucca !
Your circuit is excellent for trying with my next flyback or with the one that I built with what was left of the damaged one.
I will search for the transistor you are using. The 2n3055 I am using gets hot quickly, with the ignition coil it does the same.
I will not use it with the ignition coil, I will wait for the 13005 if I can get it.
The photos are what is left of my flyback.
The transistor gets hot even with this configuration.
Jesus
