0 Members and 92 Guests are viewing this topic.
Thaelin
   Wasn't sure I wanted to add this but what the heck.
   The nand gate is what is called one of the building blocks
of the digital world. Input a and input b must be hi for the
output to be low. All else will be a hi output. Common knowledge.
Cmos is used for its open collector outputs to handle power and
used less to run.
   Now if you take the same circuit in Tigers schemat, take the
nands and replace them with a high speed cmos inverter, you have
the same thing less wires. I would say that he used that specific
chip as it was what he had. Inverter is one input and one out, but
still the same circuit equivalence. Just have to match up the timing
aspects of the two chips rise time/fall time and delays.
3 cents
thay
AbbaRue
Does anyone have the patent number for that Tesla Ozone gen. circuit mentioned above?
the_big_m_in_ok
Quote from: AbbaRue on April 30, 2011, 08:07:39 PM
You're thinking of this one?
http://rpmgt.org/588177.html
--Lee
khabe
Found very interesting article from Russia,
All what now presented at schools and universities entitled as “Periodic system of chemical elements of D.I.Mendeleyev”, is forgery.
The main distortion of the Table, carry of " zero group ” Tables in its end, to the right, and introduction of so-called "periods".
Such kind (only at first sight â€" harmless) of manipulation is logically explainable only as conscious elimination of the main methodological link in opening Mendeleyev: the periodic system of elements in the beginning, a source, i.e. in top left to angle of the Table, should have zero group and a zero number, where the element "X" (on Mendeleyev â€" “НьюÑ,оний” (is it Newtonium?(khabe)), â€" i.e. a world ether settles down. Moreover, being unique constituent of system an element of the Table of derivative elements, this element "X" is argument of the Table of Mendeleyev. Carry of zero group of the Table to its end destroys idea of this fundamental principle of all system of elements on Mendeleyev.
These changes it Table have been made right away after Mendeleyev death (1907 ?) by hes friend B.N. Menshutkin - ordered by "Worldwide scientific community".
The new paradigm relativity required refusal of idea of a world ether; and consequently this requirement has been erected in a rank of dogma, and D.I.Mendeleyev's work has been forged.
http://www.glubinnaya.info/science/mendeleev/mendeleevtable.htm
For confirming the aforesaid, we shall ask to speak to D.I.Mendeleyev:
“... If analogues of argon at all do not give connections apparently, that it is impossible to include any of groups before known elements, and for them should open special group zero... This position argon analogues in zero group makes strictly logical consequence of understanding of the periodic law that is why (the facility in group VIII obviously is not true) it is accepted not only me, but also Braizner, Pitshini and others... Now, when began to not be a subject to the slightest doubt, that before that I the group in which should place hydrogen, exists zero group which representatives have weights of atoms less, than at elements I of group, it seems to me impossible to deny existence of elements of easier, than hydrogen. From them we shall pay attention at first to an element of the first of some 1-st group. It we shall mark through “y”.
You need to find someone to translate, my English is no good,
cheers,
khabe
AbbaRue
I found pat. 588177 but it doesn't have the same text or image as this one, so I figure it must be another pat. number.
