0 Members and 911 Guests are viewing this topic.
Bruce_TPU
Quote from: ElectricGoose on May 26, 2011, 11:41:10 PM
@ everyone else.
If you ever want a hope of figuring something out yourself, don't wait to be spoonfed some nonsense by people posting erroneous pictures and videos with dubious claims.  ASK the why's and wherefores and reason it out.
Shokac has nothing more than a Gray Tube with a spark gap working on the PRINCIPLES of a Vacuum tube but it is not OU by itself and it still requires an input.
Do any of you understand the principles of vacuum tubes??  Certainly not those that are running off and thinking they are any more efficient than modern day semiconductors!!!  Why do you think they made modern semiconductors in the first place and chucked the old vac tubes away???  OMG, never in these forums has a truer word been spoken that " A little knowledge is truly a dangerous thing".
If you don't know the PRINCIPLES of how to CONSERVE energy so as to create an over efficient device, you will certainly not be able to accomplish it with a antiquated vacuum tube.
Anyway...whatever
Hello ALL<
Unless of course, you understand what was posted and actually READ the article and understood what Shokac was driving at...
You feed the negative electrons from the wire connected into the physical earth, to the positive plate, along with that of the battery to jump start the system.  Simple, elegant!   ;D
I had to use my phone to access it.  Brilliant concept and makes perfect sense!
Cheers,
Bruce
Shokac
This is not my reactor, bat i thing ih this way.
This is reactor from Mrs & Mss Correa.
Bruce_TPU, you are the Brilliant. This is my idea, but I replace filament with HV arc (much more free electrons).
Filament in the vaccum tube use for heating, and for making free electrons. Read simple explanation in Navy instruction link
Kapanadze make free electrons from air, and pump in to Electric circuit. Circuit must have min 300 - 400V (DC)
Free electron make from AC HV discharge or from ozone generator. (Look this picture http://peswiki.com/images/d/d9/TMZ_black-box_Kapanadze_bulbs_300.jpg and look how looks coil. Seem like ozone generator coil)
Pirate88179
Quote from: ElectricGoose on May 26, 2011, 11:29:39 PM
Bill, just because they call them 'vacuum' tubes doesnt mean they have a hard or soft vacuum.  It's a term.  Same how they make light bulbs.  They REPLACE the oxygen (which is counter productive) with an inert gas like Xenon or Argon thereby 'evacuating' the oxygen.
There IS a GAS in there.  Just not oxygen.
"A vacuum pump removed the air from the bulb, a slow but crucial step.  Lead-in wires that would be connected to the electrical current  protruded from the glass bulb."  (Quoted from the following link)
http://www.enotes.com/how-products-encyclopedia/light-bulb
I don't see any information anywhere that says there is gas in an incandecent light bulb...just a vacuum.  That is why they implode because they are under a vacuum.
All of the books I own on Edison only mention a vacuum and no gas.
TEKTRON
Quote from: Pirate88179 on May 27, 2011, 04:02:32 AM
This is a good read. Don't forget to read the whole thing and turn the page ::)
modern light bulb construction:
http://home.howstuffworks.com/light-bulb1.htm
BTW Edison was not the first inventor of electric light bulb:
http://www.coolquiz.com/trivia/explain/docs/edison.asp
Pirate88179
Quote from: TEKTRON on May 27, 2011, 04:31:00 AM
Excellent, I stand corrected.  However it is still a vacuum, correct, and not pressurized?  I just broke a bulb last month and it imploded indicating a vacuum is why I ask.
Thanks for the info.
