0 Members and 148 Guests are viewing this topic.
Bruce_TPU
Quote from: Shokac on May 27, 2011, 04:52:14 PM
Look this Kapanadze pattent:
Negativ is conected only to source and to ground, but positive conected to coil (free ions maker) and collect free electrons from air with HV discharged or from ozon coil tube.
Free electrons maker is AC HV, but out is DC 300-400V.
Now compare to witch vaccum tube.  ;)
Hi Shokac,
Very good indeed!   ;)  I follow you.... Ozone is O3, an allitrope of oxygen, so we are back to atomic number 8.  Electricity (HV) produces the ozone within the ozone generator, which produces the ozone, which is fed into a tube (dissapates to rapidly just to be in air).  This then, would ALSO give an endless supply of negative electrons, flowing to the positive plate, as long as the ozone kept coming into the reactor chamber, and then use the power off of the positive plate straight to output, and it would be rectified like a triode rectifier, producing DC.  VERY similar to the other reactor with the transformer.
What I like about this, is you take your gas producer (ozone generator) with you, so you never have to worry about running out of negative electrons (free electrons).  You then loop back the DC power output, to keep the ozone generator working and your in business!
Find a tube, glass, or aluminum or high quality stainless steel, something that the ozone won't react with, and that is where you have the created ozone enter.  That is where you have your tungstun (or HV arc) and positive plate.  A couple of batteries to keep the plate positive and to get the ozone generator up and kicking and your in business!   8)
Nice...
Cheers,
Bruce
EDIT:
Positive plate on the bottom picture could actually be a coil of high potential, say 300 to 400 vdc to "attract" the Negative electrons, then to output.
Shokac
Quote from: Bruce_TPU on May 27, 2011, 11:45:17 PM
Hi Shokac,
Nice...
Cheers,
Bruce
EDIT:
That is, in principle, was my idea.
It is still only have to prove it.
ElectricGoose
Paulo Correa already achieved all this (again) in 1996.  As usual, the technology remains unused.
Here are the patents and schematics.  Plenty of reading.  No need to guess and make wild theoretical speculations which seems to be rampant here.  Next, people will be suggesting that litzing wires is the answer to OU!!!   :D
http://www.rexresearch.com/correa/correa.htm
Plasma can be bent so many ways though.  Correa's method is not the be and end all of it ....however it is a good starting point.  Read first, save yourself some bench time.
stivep
Testimony of Wesley :
As of today  5/28/2011
I would like express some of the concerns in regards to Tariel Kapanadze.
1. I have extremely strong bases to my statements.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2. I'm not trying to be take sides but to be very precise in wording and expressions and do not represent TK or his opponents.
3. I'm not directly standing facts but rather use  different wording   because of obvious reason.
Many of people treat Tariel Kapanadze as  only the source of possible advantage, benefits  and so on.
Many of these people put the bad words about
his personality,
his look
his level of intelligence
his  knowledge
his trustfulness
And doubts of his technology.
I have bases to say that
his technology works!! 100%
his wishes are very positive in nature.
he is not!! heavy drinker, and he has never been one.
He is the person of brilliant memory I would name it photographic memory,but not only.The special ability of immediate connection of facts.
If we take as an example facts in nature, His special ability, will be revealing his absolutely extraordinary and fast processing and connecting facts.
Do not ever judge man  based on his external appearance !!.
he is looking at  all of you guys,
Many of you brought him  bad experience, untasty  or ugly interaction, And in his mind why he should do it for you..
Many of you did not deserve it.
Look at your comments.. some of them angry from the fact that they personally can not benefit from it NOW!!
THEY DO NOT CARE ABOUT TARIEL KAPANADZE!!
They have no respect to him at all.
Yes I understand frustration and frustration of mine as well.
If Yes SHOW IT!!
One of great people in this forum is Shocac.
This is the man I believe is the way  You all should be!!!!
You want him to  show you his secret?
What can you do for TARIEL?
What............
You want action one way? Leave pure man in his cage?Let him die and you do not care to help him out?
Show me how many of you declared help to TARIEL!!!
does it sound ugly?
So why in the world Tariel should understand you if you do not have understandably of him ......him personally!!!
You see his face and you comment that he will die  and you will be  left with another 20Years fallowing steps of Stanley Mayer. and others..
For those who just think about themselves  I say  SCREW YOU!!!
I have proposed to TK help disregard the fact of whether he will decide to publish it for  free or not. I will give him from myself $1000.I know it is not a lot but 100 people from entire world donating  this amount will bring real difference to his present life.
Even $2  coming from many of you will do as much.
Try to understand man frustration seeing every day foxes ,liars,
unspeakably bad characters.
Yes He wanted to make money out of it ..who would not?
You want to make it for yourself and friends of yours and others to make some money out of your work... who would not?
So what is the difference between you( the good People - God People) and him?
The difference is NONE!!
With understanding Tariel Kapanadze as unique one of his kind human that can  make all of you happy All human race in general.
Can you manifest your wiliness to help TK?
Inside Tariel is kind and very sensitive but incredibly disappointed  man.
Yes His willingness is to do not hold it to himself!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
"It is not what your TK  can do for you but what you can do for TK!!!" and if you just show it you will  help yourself as well.
Wesley
PS:
You have one unique chance in your own life to see the change that was unavailable to us humans ever in the history of human life and you about to see it. Think about it?
Imagine......
just image yourself being able to see what never anyone from your friends  family and  family ancestors was given chance to see.
the space travel  is small comparing to this man invention.
Thank you very much to the members of this forum and other people who understand my not very much sophisticated English I was not born with it.
