0 Members and 250 Guests are viewing this topic.
wings
Quote from: Bruce_TPU on May 28, 2011, 04:41:18 PM
Ok!  So, like I had it yesterday.  A good place for folks to begin to experiment, I think.
Those links were more for others to see how easy ozone production is.   ;)
Cheers,
Bruce
this is close to the Tutanka device:
http://www.energeticforum.com/renewable-energy/7995-sell-plans-reactor-fuel.html
"1- I have named MHD tesla because in fact I have extracted energy from air"
http://www.energeticforum.com/renewable-energy/5400-tesla-air-mhd-electrical-generation-device-2.html#post130301
"Tesla use radiant energy name for protect what have understand.. Radiant energy = free electrons. HV capacitors are electron batteries and electrons are released in secondary load circuit. Isn't present voltage potential but only pure energy. Don't exist DC or AC field but ONLY pure energy. Tesla have found that, using high voltage at high frequency and capacitors you can have access to an next energy level.. pure energy current without voltage. Tesla have found also that for increase efficency is possible change arc discharge method and use high voltage/high frequency directly on molecules like air for obtain more free electrons. More free electrons more pure energy. You don't obtain any shock because in fact you obtain only an natural energy source. You can see that from Tesla Radiant Energy youtube video, you obtain two electron flow and you can summ these with an electric short circuit.
Hairpin circuit in fact is ONLY an electron loop!
Dr. Aspden have designed an special generator, no more different from Hairpin circuit, the main difference is that use tubes (and air) but you can replace DC power with AC every using high voltage and high frequency.. in all case you need to "tune" the tubes for obtain free electrons from air (and also Nox and Ozone) but you can use ONLY nitrogen and you can re-use that more and more times. Important thing.. you need NO EARTH in your circuit or your electrons go out from there."
Bruce_TPU
Quote from: wings on May 29, 2011, 04:02:11 AM
Hi Wings,
Yes, I suspect very similar.  But it sounds like his reactor is recombining molecules to produce his micronic fuel, that he claims will burn better then gasoline.
This concept Shokac and I have been speaking of is similar in some of it's regards.  But no need for water, salt, nitrogen filter, etc.  But, I had actually suggested nitrogen earlier because of it's atomic number is lower (7) then that of oxygen and would actually work better.  But the cost of the filter etc, makes common air much more attractive.
The only thing needed is HV, and HV is cheap.  Not much amperage required.  And the output is indeed amperage.  So, if you have 300 to 400 volts DC on your positive plate and add that amperage, you are left with a heck of a lot of wattage.  What I LOVE about this concept is it is so close to the way the TPU works, though the PROCESS is completely different!  Very cool stuff!
Cheers,
Bruce
wings
Quote from: Bruce_TPU on May 29, 2011, 08:14:40 AM
Hi Wings,
Cheers,
Bruce
some pictures it works also with radioactive materials ......
http://peswiki.com/index.php/Directory:Resonant_Nuclear_Reactor
http://www.rexresearch.com/nucell/nucell.htm
Shokac
Quote from: wings on May 29, 2011, 08:38:31 AM
Wings, I try this, but if you wont polarized electrode positive & negative, you need very strong electromagnetic field. Energy for create very strong electromagnetic field is HI. And you don't have OU device.
AbbaRue
About Light bulbs.
I read somewhere that they used to use Argon in light bulbs but modern light bulbs are filled with pure nitrogen.
Once you remove the oxygen, the nitrogen doesn't react with the tungsten, and it's dirt cheap.
The only bulbs using an inert gas are those halogen bulbs, and the outer glass tube is actually quartz crystal.
I'm glad to see this thread has some life again.  I spent quite a bit of money on parts for this project.
I hope we finally see a breakthrough replication soon.
I also spent months experimenting with the Correa's Argon abnormal discharge tube.
I got 2.5 times as much output as input, but for some reason the tube works for a while and then stops.
I also tried Heleum and it works too.  But again the tubes I built only work so long and then stop.
Then I have to re-vacuum them out to get them working again.
I can give more details on my setup if someone wants to build there own.
