0 Members and 212 Guests are viewing this topic.
yssuraxu_697
Hi, lately theres been much talk about gas-core transformers and other tech that has to do with vacuum, gas etc.
I think what is missing from discussion - simple and cheap as possible "proof of concept" experiment(s).
Many ppl are telling that they have made successful experiments in the field but actual info is hard to find and is mostly theoretical. So maybe present a simple and easy to replicate test?
Not just schematic but some pics and video also. This would motivate many more ppl to join in and start working in that direction.
forest
Consider the possibility that we can speed up electrons (or rather something they pass called charge)  in metal or composite like ferrite the same way. Gas core transformers are great but slightly mess with overall picture.
ramset
HHMMM
I recently had a freind say something about using Carbon monoxide?[claimed it was the gas used in some OU engines[Gray motor]]
I'll look for the info
Here is a cheap vac pump
http://www.harborfreight.com/catalogsearch/result?q=airconditioning+vacuum+pump
I/ve used them and they do what they claim [14.00]
Chet
PS
Mr. Abbarue
PLEASE share your experience with the Correa Tech!  It will help to advance our understanding ,and maybe we can figure out why it stopped working?
Thanks Grandma
wings
Quote from: yssuraxu_697 on May 30, 2011, 04:25:44 AM
http://tech.groups.yahoo.com/group/freeenergysurprise/
Bruce_TPU
Quote from: AbbaRue on May 30, 2011, 02:07:15 AM
About Light bulbs.
I read somewhere that they used to use Argon in light bulbs but modern light bulbs are filled with pure nitrogen.
Once you remove the oxygen, the nitrogen doesn't react with the tungsten, and it's dirt cheap.
The only bulbs using an inert gas are those halogen bulbs, and the outer glass tube is actually quartz crystal.
I'm glad to see this thread has some life again.  I spent quite a bit of money on parts for this project.
I hope we finally see a breakthrough replication soon.
I also spent months experimenting with the Correa's Argon abnormal discharge tube.
I got 2.5 times as much output as input, but for some reason the tube works for a while and then stops.
I also tried Heleum and it works too.  But again the tubes I built only work so long and then stop.
Then I have to re-vacuum them out to get them working again.
I can give more details on my setup if someone wants to build there own.
If you could post a schematic, but I believe now, as Shokac, that a vacuum is not needed at all, if using ozone!  As a  matter of fact, ozone production requires natural air.  And as long as the homemade cap (aluminum and glass) has air it will not stop making ozone.
So, your schematic could be used as the test bed (since the concept works, and we are removing vacuum and changing perhaps only a few parts), but without the vacuum and we replace the filament with HV ozone production.
Thoughts?
Cheers,
Bruce
