0 Members and 586 Guests are viewing this topic.
dllabarre
Funny...
A couple months ago I mentioned Tariel using ozone and everyone dismissed it, practically laughed at me.... ::)
If you look at Tariels GB video you'll notice the ends of the coil are covered with the "paper towel" holder ends (though not air tight) but he could be producing ozone in his coil to enhance getting energy from the ground through his ground wire.
DonL
ElectricGoose
Here's something to jump start you in the direction of Ozone - Electrical power generation (link below).  In the end, it won't be THE answer you are looking for though.  No singular thing is.  The truth is that to have 'free' energy you need to acquire knowledge and apply a whole string of principles after which you end up with more power out than in.
So many folk here think that the Gray tube or that some magical device is the answer to mind blowing power 'generation' all on its own and yet you would recognize with your own REASONING this cannot be if you just sat quietly and pondered on FACTS that are known.
Consider Einstein.  A smart fellow who published over 300 papers covering everything from the Zero Point to Unified Field Theory, Wave Particle Duality, Relativity and beyond.  The brain literally boggles as to his clarity of mind and ACCURACY without having to perform barely a single experiment.  Was he helped by aliens or sentients?  Of course not!  Yet he could see with greater clarity into the extremities of the Universe and what makes everything tick by employing EFFICIENCY OF MIND.  One method Einstein would employ to attain his accurate endgame was by Gedankenexperiment (from German) or 'thought experiment'.  Today's best detective agencies in the world emlpoy similar methods to catch criminals.  A 'thought experiment' allows you to hypothesize utilizing KNOWN variables EVERY possible outcome to a certain situation.  THIS IS COMPLETELY DIFFERENT FROM WILD SPECULATION.
http://en.wikipedia.org/wiki/Thought_experiment
Thought experiments are very useful because you narrow the field and then employing Ockams Razor, whatever remains (no matter how implausible) MUST be the TRUTH.
Thought experiments have uses in everything from day to day life, to science, crime fighting and performing of problem solving where the physical experiment would be impossible (due to danger or expense).  I encourage you all to try change your mindset in problem solving because this will enable you to 'see' without actually having to peform many costly experiments.
This now brings us back to the topic at hand - Gas tubes, Vacuum tubes, Gray tubes, spark gaps etc.
For every ying in nature there is a yang and the reverse applies.  Some simple examples are - Water can be disassociated into its gasses and yet those gasses can be recombined (the reverse) to recreate water.  The same is true with electricity and the various ways to generate it.  Electrical current stored in a battery, can be oscillated into magnetic fields to turn a motor.  THAT very same motor can be reversed and turned into a generator to push magnetic fields across the wires and then drive current back to the battery.  Yes, you know this but do you show that you fully understand that these basic principles effect EVERYTHING???!!
Do you know what a gray tube, vaccuum tube have in common?  People using them at attempts to 'create' free energy are merely REVERSING the light globe.  What happens when you run current into a light?  It hits the filament, the filament heats up inside the inert gas, electrons are free (some return to the tungsten filament) and all the energy is converted into LIGHT and HEAT right!  OK.  Now REVERSE this and you have the gray tube!!  Glass enclosure with inert gas, high power LIGHT source (this comes from the spark gap where the electrons are freed) and then they will be rectified by the anode and cathode.  See...its not that hard....no wild speculation no wondering, its FACT.  A vacuum tube rectifier works this way except it uses a filament rather than a spark gap.  The gray tube is just a supercharged version.
But WAIT.  There is more.  What else are these 'tubes' really??  They are merely HIGHLY efficient batteries/caps whereby instead of having a liquid electrolyte, it is emploted in a gas and the electrons travel from one plate to the other.  HOWEVER (oh no!) what happens with all batteries?  Either the electrolyte breaks down, or other materials are consumed.  There is no free energy in ANY battery and every time you convert energy there are LOSSES.
If this wasn't true, then the vaccum (inert gas) would protect light globes and the filament forever!!  Why do you think old light globes become black?  Why do you think vaccuum tubes were replaced?  Because they had short life spans and things they were used in like TV's and radios kept breaking down!  THATS why the other member who posted his experiences with his tubes above said "for some reason they stopped working after awhile".
The bottom line is that we cannot escape the energy CONVERSION FACT.  You must expend some material in order to 'make' energy of another type even IF that first energy source is ground currents.
Thats the abbreviated nutshell regarding tubes.
Here are the patents for one Ozone conversion device.  Its a waste of time though.
http://www.nuenergy.org/pdf/patent.pdf
http://www.nuenergy.org/iw/2005/perreault2005.htm
Bruce_TPU
Quote from: dllabarre on May 30, 2011, 03:02:00 PM
Funny...
DonL
Hi Don,
I was not following the thread closely at that time.  It would appear that you had some very good insight.  I certainly agree that using a deep earth ground should assist, since we have negative electrons traveling to a positive plate.  So perhaps a combination of the ozone and earth.  Or perhaps as Shokac thinks, only the ozone.  Either way it would seem a very good place for experimentation.
Cheers,
Bruce
ramset
Mr.Goose
A Battery? I beg to differ!
Quote From link below
"Canadian Breakthrough in Power Generation
Non-Polluting Electrical Power from Pulsed Cold Plasmas Delivers More Power than it COnsumes "
http://www.rexresearch.com/correa/correa.htm
They call the Correas "Plasma Physicists"
This is their Sandbox ..................
@AbbaRue ,Can you share any specifics on your experiments?
Thank you
Chet
Thanks Grandma
