0 Members and 94 Guests are viewing this topic.
TEKTRON
was not proper hyper link... too many chrs for one line. copy and paste on address bar.
bolt
Quote from: mrclean on July 07, 2011, 05:48:35 PM
THANKS MAN, oh hey actually i heard that the normal power factor NSTs are operating at 60hz & that only the smaller high power factor ones make Khz,,, (correct me if im wrong)
Better voltage could only be better, but the freq can very easily be lowered... as u prob know?
But if im getting 10-20 AMPS out as seen in vid 8 & 9, with 1.7 Amps in :D....without high freq... then its gonna kick some serious ass with it :)
Any opinion on the vid?? i am open to advice!
Here is my advice DON'T RELY on meters!  The spark gaps at that voltage completely screws up any meter unless you take some serious measurement precautions.  Get a car battery and inverter. Measure the real DC current and volts going to inverter then use the inverter to run your rig. Make sure this is long way from the rig better in the next room then use mains extension cable.   Even JLN was 100% fked up due to using 15 dollar energy meter even when i suggested use and inverter and car battery. One month later after many replications and false hopes JLN bought  a commercial filtered RFI watt meter and the results showed a large power LOSS!
Output. Use a water heater or kettle. THEN you can measure time to heat up say 2 pints or 2 litres of water and measure the energy used to raise from room to boiling point. There really is no other way when dealing with such a mess of HV RFI.
I have not seen ANY kapagens show OU when measured in this method.
mrclean
Quote from: bolt on July 08, 2011, 12:30:12 AM
AWESOME MAN, GREAT INFO, & I ACTUALLY WAS PLANNING ON AN INVERTER CIRCUIT & BATTERY/SUPERCAP! THANKYOU!
cosmoLV
Quote from: mrclean on July 07, 2011, 11:03:58 AM
hi guys, cant seem to get much response on this.
--couldnt find a Smith replication thread.. yet it is similar to the Kapa using induction
Here is my recent work on Don Smith
http://www.youtube.com/watch?v=op8HzKc5yao
Just wondering if anyones workin on this, or any input from anyone. Im doing this with very little knowledge, i want to use the Kapa system layout, but with the Smith coils. Its going well.
BTW how the F do you start a topic?
Don Smith is nothing more like this:
Keep your chakras opened :)
TEKTRON
Quote from: stivep on July 07, 2011, 11:28:06 AM
link does not work!!!!!!!!!!!
can you correct it?
Thank You
Wesley
It's just the old "Funeral for a Radiator" vid. LOL
