0 Members and 194 Guests are viewing this topic.
FreeEnergyInfo
Quote from: Choose username on July 11, 2011, 01:07:33 PM
Maybe I can translate you?
It was a fake vid. For what it was filmed? Delamorto is not the author, author is "ALGO" from realstrannik.ru (also known as "alibaba" from next-energy.ru). Delamorto only published his vid. Now for that it was made. De la morto pointed out two reasons for this:
1) Show to all of us, how easy somebody can cheat us. We spending our time (~2year) for understanding how work SpaceReason's (SR) device. But only few suggested that it could be ordinary fake. In many forums always SR SR SR... Maybe his device leads us astray. ALGO show us how easy SR could deceive us. ALGO put a thin copper wire (with the help of adhesive tape) to one of his 4 big bulbs. This wire delivered energy to the installation. 2 days later was published second vid and ALGO show his trick. If you interesting u can search it or ask freeenergyinfo. He should be kept this vid.
2) Delamorto said that also it was provocation against one man, He had to happen that this man will lost his nerve and will published electric diagram of his OU device. Delamorto did not specify who is this person. Maybe Kapanadze?))) Delamorto's hope was that this man wants to be a OU's pioneer and will hurries to secure his leadership. As a result we would have a working diagram.
Also es war ein Kindergarten)))
PS
Now ALGO is continued his research. Soldering, winding, etc. If he succeeds, he will certainly tell us.)
THANKS...
FREEENERGYINFO == FREEENERGYLT
LITHUANIA
TEKTRON
Quote from: 4q on July 11, 2011, 12:33:33 PM
DElamorto's schematic from ZIP file.
Interesting coil inside the ferrite tube... What does it do?
4q
WILD ASS UNDEREDUCATED GUESS...
"Depinning of a domain wall
Non-magnetic inclusions in the volume of a ferromagnetic material, or dislocations in crystallographic structure, can cause "pinning" of the domain walls (see animation). Such pinning sites cause the domain wall to seat in a local energy minimum and external field is required to "unpin" the domain wall from its pinned position. The act of unpinning will cause sudden movement of the domain wall and sudden change of the volume of both neighbouring domains. This causes Barkhausen noise and in effect it is most likely to be the source of magnetic hysteresis." wiki/Domain_wall
4q
PS
Thank you. It is a bit strange why sy expend his time to make a fake vids, scematics, etc. to provocate the forum members here (other people anyway interested in). So SR and CosmoLV info about ferro-magnetic-suspension were fake anyway?  If I undestand correct there will be sg genuine and real schematic, info, vid in the near future right?
tnx,
4q
ps. I read this site since 1997 when GIF animated burning fuel flames were here with Harti's portrait and the TEP project was on the scope (Jnaudin/Harti) not a forum with a f*cking fakemakers people here anyway.
bolt
SR (Cosmo) system is real, its a type of Ferroresonance.  HV excitation of the ferrite core causes saturation of the core into enhanced domain spin  which causes an electrostatic effect in the surrounding ambient.  This causes standing waves. The increase kinetic energy potential of the ambient electron energy which manifest as a powerful magnetic flux without hardly any input energy required. Typically COP >100.  In order to balance the phase the dipole needs to be balanced and modulated so that the o/p coil appears to be moving with respect to the magnetic flux then impinges a current on the o/p coil. There is no resonance as you know it to be its more excitation and its not parametric.  The load is pulled off the opposite side of the dipole as free energy while allowing the earth point to act as a pivot.  Here is a text book snip of the Ferroresonance phenomena.  Its VERY easy to get a large 3 phase transformer to go OU.
Ferroresonance or nonlinear resonance is a complex
electrical phenomenon, which may cause overvoltages and
overcurrents in an electrical power system thus endanger
the transmission plant, switchgear and the operational
personnel. Ferroresonant overvoltages on electrical power
systems were recognised and investigated as early as 1930s
[1]. It occurs when a nonlinear inductor is fed from a series
capacitor. The nonlinear inductor can be due to the
magnetic core of a wound type voltage transformer or it
may be due to the complex structure of a 3 or 5 limb three-
phase power transformer. The circuit capacitance can be
due to a number of elements, such as the circuit-to-circuit
capacitance or parallel lines, conductor to earth
capacitance, circuit breaker grading capacitance, busbar
capacitance, bushing capacitance, etc.
Ferroresonance should not be confused with linear
resonance that occurs when inductive and capacitive
reactances of a circuit are equal.
This last paragraph is so very important to understand this is where 99% of people go wrong. Can you spot the RomeroUK waveform? :)
poynt99
Quote from: bolt on July 12, 2011, 09:11:32 PM
Which one is it bolt (and why)? They all look interesting. ;)
