0 Members and 158 Guests are viewing this topic.
xenomorphlabs
So the FOTM theory is now that SR`s core contained half ferrite rings and half dielectric material rings? If so, there is no indication for such a construction from the photos of the core except fractions of millimeters between the ferrite rings of air/glue.
4q
Has somebody checked the Tesla patent No. 514,168 ? http://www.teslauniverse.com/nikola-tesla-patents-514,168-generating-electric-currents
I think it would be OU. I read it several times and I cant understand why Tesla patented it if it wont be OU. The energy path with today's physics is evidently lossy: Generator -> transformer -> Tesla's hairpin circuit with controlled SG -> transformer -> load instead of generator -> load. And everythin placed in an oil tank with stirring to remove heat and make better insulation.
This full patent is unreasoned without proof of OU...
4q
penno64
Hey Madsatbg,
Any progress ?
Penno
p.s. dont know why dole went quiet
stivep
Quote from: slapper on July 16, 2011, 11:29:42 PM
whoopsie - gota fix something :(
http://www.overunity.com/index.php?action=dlattach;topic=7679.0;attach=54595;image
there. image fixed :)
Still working on it:
http://www.ece.unm.edu/summa/notes/Measure/0046.pdf
Please understand
1. word- "antenna" as load.Say string of light bulb at total purely resistive 50Ohm.
2.in all of his papers he is using wording Half Space
that means  that his main approach was application of ferrite  and insulator sandwich where insulator in  sandwich is taking proportional space causing magnetic field to extend to dielectric portion of structure.
Carl E .Baum  previous link about sandwich  was his too.
http://www.ece.unm.edu/summa/notes/Measure/0039.pdf
in here: transient lenses - causing Lensing effect
Someway difficult material.
page 6 gives you again sandwich.
page 12 gives you symmetry of sandwich and stays about cylindrical waves.
Compare now figure 5.1 from page 16
to
http://upload.wikimedia.org/wikipedia/commons/7/79/Barkhausensprung.gif
and
than come back to
page 18 chapter VI  Concluding Remarks
From that you will clearly understand that Baum was trying to take control over E field and B( or H) field.
We remember that both are at 90 degrees.
That control gives us OU. by limiting influence of BEMF
look at remarks: "for transient-lens geometries the desired wave geometries will be more like free space."
http://www.farr-research.com/Papers/ssn371.pdf
page 34
QuoteIn the high-frequency (early-time) limit, the peak
voltage scales as Zc 1/2  , where Zc  is the
local characteristic impedance of the line.  This  has the effect of maintaining a constant peak
power.  Thus, for example, a 1 MV signal at 10 Ω
becomes a 4.5 MV signal at 200 Ω.
  This additional voltage must be considered in the design.
/so we increase impedance and we get more voltage.
and
QuoteIX.  Conclusions
We have summarized here much of the design criterion that is necessary to design
coaxial unzipper type baluns for high powers and fast risetimes.  We have shown why it is
advantageous to perform the unzipping at low impedances.
We have provided dielectric strength
data for most of the common insulators one might use.
A rule was derived for predicting the
risetime of this class of baluns.
Finally, a  two-dimensional finite element analysis was
performed at various points along the cross section,
in order to calculate the impedance and the
peak electric field.
Ultimately, the goal of a balun is to provide a suitable feed for an antenna.  One approach
for developing a suitable antenna for output of an unzipper-type balun is to us a lens Impulse
Please  also analyze  magnetic domains videos
main page is:
http://wn.com/Domain_wall
Wesley
Ps: I did not draw my conclusion as of yet.Asking for any suggestion if anyone has one.
I think we approaching means of control
as related in
http://www.umbrellatech.lv/downloads/files/Design%20Of%20Device%20-%20final.pdf
we are evidently dealing with  means  of coupling  device  electromagnetic  energy
with surrounding environment
the device might be acting as valve
so
some of theory about how EMF works in different environments may help.
especially if it is ABOUT SANDWICH,AS STATED BELOW
http://www.jpier.org/PIER/pier44/12.0306051.pdf
title:
THE SURFACE IMPEDANCE OF A HOMOGENEOUS
TM-TYPE PLANE WAVE AT SKEW INCIDENCE UPON
AN INCLINED ANISOTROPIC HALF-SPACE
4q
I did not get in it  as of yet.
QuoteHas somebody checked the Tesla patent No. 514,168 ? http://www.teslauniverse.com/nikola-tesla-patents-514,168-generating-electric-currents
xenomorphlabs
Where is the "sandwich" aspect in SR`s core (see pic)???
The tiny layer of air/glue which is a fraction of the thickness of the
dimensions of the ferrite rings is not really what that pdf is talking about.
