stivep
Talking About Energy
Thank You Shocac
Here is  something interesting :
Examples of NMR in Ferrite  replacement of metal compound in within the ferrite by ion  caused by FREQUENCY!!!!!
at the same time energy level of ferrite has changed. everything is done by changing frequency of oscillation
De-Classified technology of US Army.
It took them 35 years to make it public.
http://www.sciencedirect.com/science/article/pii/0022369771900369
Nuclear magnetic resonance studies of Mn55 in the Mn substituted hexagonal ferrite Ba2Zn2-xFe12-yMnx+yO22
Purchase
R. L. Streever, T. R. Aucoin and P. J. Caplan
Institute for Exploratory Research, US Army Electronics Command, Fort Monmouth, N.J. 07703, U.S.A.
Received 22 December 1969.  Available online 6 May 2004.
Abstract
The nuclear magnetic resonance (NMR) of 55Mn has been studied in single crystals of the planar hexagonal ferrite compound Ba2Zn2-xFe12-yMnx+yO22 for values of x + y of about 0·5. The spin echo spectrum at 4·2°K shows a broad line extending from about 300 to 470 MHz which has been identified with Mn+3 ions (replacing iron) on octahedral sites and two relatively narrow lines at 555 and 585 MHz which have been identified with Mn+2 ions (replacing zinc) on the two types of tetrahedral sites which occur in this structure. Both Mn+2 lines are observed to shift to higher frequencies with externally applied fields which is consistent with this interpretation. The Mn+3 lines have also been studied at 77°K and the Mn+2 lines in the range between 77 and 200°K. The hyperfine fields and the temperature dependences of the resonance frequencies for the Mn+2 ions on the two types of tetrahedral sites can be consistently explained in terms of the different electronic environments of the two sites. It is concluded that a large percentage of the Mn ions in the compound are replacing Fe as Mn+3. From the relative integrated intensities of the two Mn+2 lines, it is found that the Mn+2 ions are substituting onto the two types of tetrahedral sites with roughly equal preference
What we have here is presence of NMR that is NOT focused energy but energy of two  frequencies  placed at  certain respect  of one next to the other.
We may understand that just the presence of these two frequencies at given amplitude is enough to transmutate or mutate structure of solid metal of Grey Iron is also ferrous material. Used with addition to build Many  High Buildings in lower Manhattan . Unfortunately some of them becomes damaged "beyond reasonable level"   in the time period of about 10 seconds
What  looks like instantaneous transmutation and conversion of approximately  206 x 206 feet wide structure.
In NMR you have one frequency spin in Z axis tilted like  spinning child Top
  at given amplitude and the second one at 90 degrees in phase in theoretical XYZ Cartesian  3 dimensional geometry pattern.
It would be nothing special in that fact if we skip  fact of lack of presence  OF DIRECTIONAL  CONCENTRATION OF THE BEAM. There is none. NMR (or MNR other name for it) is
STEADY MAGNETIC FIELD  and another one that is with of very small power ( modulator) and structure  is made of two coils and electromagnet.
You may make NMR experiment right on your table.
The point of confusion might be a cryogenic magnet.. well.........
It is used in NMR spectroscopy..and only for the reason that resistance of
copper is lower at this temperature, energy distribution is with greater impact pulse wise)
Also magnetic nuclear response is more rapid.
One skilled  with art may take pieces of puzzle and put them together in different form.
You do not need NMR  you need to "Get them by the balls"
Generation of metalâ€"ligand cluster ion beams through pulsed discharge ionization and ablation
Purchase
Ansgar Brocka, David L Cedeñoa and Carlos Manzanares Ia, ,
a Department of Chemistry, Baylor University, Waco, TX 76798, USA
Received 10 November 1998;    accepted 30 July 1999.  Available online 28 February 2000.
Abstract:
Pulsed capacitor discharge ionization in supersonic expansions was investigated for the production of intense beams of molecular cluster ions from seeded and ablated compounds. A pulsed discharge based on a triggered spark gap switch was designed and used as a method for ionization and ablation. Several combinations of nozzle geometry and electrode arrangement in front of a pulsed valve, were made to optimize the intensity of the ion beam as well as its composition. The cationic metalâ€"ligand complexes Cu+â€"(methanol)n, Cu+â€"(acetone)n, Cu+â€"(toluene)n, Cu+â€"(water)n, and Al+â€"(water)n were synthesized by ablation of the metal from metallic discharge electrodes in a discharge gas mixture of helium seeded with the ligand of choice. The cluster mass spectra of the expanded plasmas show little background ion signal besides the metalâ€"ligand species. Charge exchange processes in the expansion guarantee high ionization yields of the desired species and account for low backgrounds. Changes in the successive binding energy of Cu+â€"(water)n clusters n = 1â€"4 are clearly observed in the cluster mass spectra as step formation. A similar pattern found in Cu+â€"(acetone)n suggests the same trend in the successive binding energy as known for water.
Now you put  two of the quotes together and you  might of get to shocking conclusions.
http://www.drjudywood.com/articles/dirt/dirtpics/JonesedDust.jpg
look exactly left hand side in the middle!!
(vertical structure is missing while horizontal with staircase at 45 degrees is free falling down unaffected . Vector of energy is exactly at the center of the  horizontal square (approximately 206 by 206) feet, facing down.
So again MNR
-2 coils,
heaving two magnetic fields modified.(vertical Y  PRECESSION left hand spin)
http://hyperphysics.phy-astr.gsu.edu/hbase/nuclear/imgnuc/larmorn.gif
http://www.youtube.com/watch?v=7aRKAXD4dAg( one of videos NMR)
-2 sources of frequency and amplitude signals.
(one is week- modulator,  another one is strong)
-1 DC component(I'm not sure if it is representing BIOS or steady magnetic field)
Do you see any clues to TK?
The dial at the picture is connected to rod made of dielectric material and at  the end there is variable capacitor say 30 pF.
Do not go deep in it you may do not need it. concentrate on titles of chapters and drawings.
for some of you who  want to find more about it:
http://www-keeler.ch.cam.ac.uk/lectures/Irvine/chapter3.pdf
http://www.physics.usyd.edu.au/super/life_sciences/AN/AN6.pdf
https://mail.google.com/mail/#sent/131da7eb30194ca1  Pulse forming
http://www.physics.rutgers.edu/ugrad/387/nmr.pdf
This link is the easiest way to understand components and  function served
In section Apparatus is listed what do you need to play with it and how.
One of the components you see on the pictures .
http://webcache.googleusercontent.com/search?q=cache:vg5rKqMRjT4J:www.teachspin.com/instruments/pulsed_NMR/the_instrument.shtml+CREATECH+NMR+Oscillator&cd=2&hl=en&ct=clnk&gl=us&source=www.google.com This is experiment "at home" and does not require all of listed apparatus.
Look at Fig. 3.2 If the magnetization vector is tilted away from the z
axis it executes a precessional motion in which the vector sweeps out a cone of constant angle to the magnetic field direction. The direction of
precession shown is for a nucleus with a positive gyromagnetic ratio and hence a negative Larmor frequency.
http://www.phys.ufl.edu/REU/2009/reports/AntonioLorenzo.pdf
A solid state marginal oscillator for NMR detection
Figure 2. Detailed electrical diagram of the marginal oscillator circuit.
Conclusions:
TK    does not deal with Ion beam or any from of narrow concentrated plasma but he deals with spark gap
NMR  does not deal with Ion beam or any from of narrow concentrated plasma but might deal with spark gap in impulse forming module.
US Army NMR  does not deal with Ion beam or any from of narrow concentrated plasma may deal with spark gap in impulse forming module  but at frequency of 555MHz it is  impossible to have anything more than continuous and modulated plasma in the spark gap. Interesting...
-does  deal with Ion beam or any from of narrow concentrated plasma they  deal with spark gap discharge ( pulse forming module)
Example from the picture  of collapsing structure in Manhattan may  deal with vector of Ion beam or any from of narrow concentrated plasma exactly from the horizontal center down.Instant "evaporation" of the center vertical structure stands about forces causing it.
(I'm not speculating here about origin of the vector of force for "safety reason" :)
, Understanding of the conclusion is entirely up to the reader.
I'm protected by law of Fredom of  Speech by Constitution of USA )
Pictures below shows  3 connectors Source  BIAS and RF.
SR used  at least  two of them
generator=(RF)
modulator=(signal)
BIAS might stand for  presence of magnetic field =(NMR and SR and TK experiments)
Wesley
DreamThinkBuild
Hi FreeEnergyInfo,
Thank you for that video. I like that design, is that a gyroscope rotor? Spin that heavy mass up to speed and the small Lenz from the coil can't stop that freight train. :)
stivep
Quote from: FreeEnergyInfo on August 22, 2011, 11:01:12 AM
Free energy , no coment ....
http://www.youtube.com/watch?v=U8AC8T5cvm4
http://freeenergylt.narod2.ru/muller_dynamo/
ORGINAL VIDEO ..
http://www.youtube.com/user/axis306#p/u/1/gECwKzRw-gs
http://www.youtube.com/user/axis306#p/u/3/H0Awqk9zOjw
I have question:
Does it not look like at the bottom on the left hand side there is battery that keeps it moving around?
Or if  not what is it? :)
Example:
20 girls ( 15 year old) pushes the small car, after the while there is a need for only two girls  to compensate losses to unity level.
After the while with increasing speed there is a need of one finger of one girl to  compensate losses to unity level.
TK - deals with overunity based on concept of initial energy delivered in similar fashion.
for free energy it must be OU present. If not we may the most deal with unity only.
concept of OU MUST!!!! represent coupling to other source of energy such as:
If we have valve on the big pipe of water than small amount of energy is needed at one time only to release the flow. We do not care who pay for the pump energy as we do not care about  Average over the entire earth=164 Watts per square meter over a 24 hour day from the sun
Wesley
PS:
when accelerated OU is associated with extra energy from girls power.
At the progress of acceleration  for OU  there is the need  of less and less energy from girls power.. to keep the speed and motion.
Vector of the motion is of OU the same fasion as your own ou when you spend $10 with the nice girl but you still have $90 in your pocket to feed the  motion of situation so it does not stop. :)
When the bank is empty than there is no more motion in any of these instances. Unless you switch your initial OU to the pocket of that girl pocket. From now you have OU and she is paying for it becouse she is from now so attracted to you.
In reality it is us man (male) who is always paying for  OU of girl :)
That is at my believe OU  of TK . Switching to "sounding" resonating and surrounding  source of energy by attracting it.
Law of conservation of energy is still present.
Voltage of the experimental structure does not stand anything!!
It is a power in Watts that stand about .....and Power Factor.
Connecting  bank of LED's for short period of time does not stand  anything as well. It only says about temporary load of consumption = fraction of accumulated mechanical momentum of the flywheel.
stivep
Introductory NMR & MRI: Video 03: How the Terranova-MRI works
http://www.youtube.com/watch?v=GjLvu1hOAAA
Please look at the the construction of the coil of NMR
starting from  time: 2.53 of that video
concentrate on shape of coil #2 ( middle coil)
-May you suspect clockwise and counterclockwise winding?
-What is the function of the coils?
-What about respect to Cartesian XYZ was mentioned in that explanation ?
-What is the frequency of Nuclear Resonance from that video and how that relates to TK frequency of oscillation.?
SR did use ferrite pipe and coils... How many coils did he use?
TK did not use  ferrites            ... How many coils did he use?
Introductory NMR & MRI: Video 09-1: Introduction to k-space
http://www.youtube.com/watch?v=XJvVnlMv1LQ&NR=1
look from:1.57 minute
There is comment about winding.. for me it is clockwise and counterclockwise
at 3.31 minute  is explanation of magnetization process
at coil called "later"( right side ) you see (phase helix ) sign wave of resonance  inside.
at  4.47 you see dumping wave very much like one we see at all of our TK experiments. And this one  Vladimir Utkin was explaining us how to reverse so it is growing in amplitude instead of vanishing with time (impulse relaxation)
at 7.48 minute it is the statement  of response of Material Under Test (MUT)
in our case that would be response of surrounding  us energy coming from environment by means of interaction  in subatomic level between particles.
Maybe the key to any energy level is in this  very moment.
That guy has no clue about such application.As many of you could not foresee application of shiny bolt found on the driveway  to fix something different 5 years later.
Phenomena of TK was for him to just not throw it away.Play with it and  think.
at 9.08 minute he say that he is not interested with signal at all.. ( and that is where he is going in wrong direction by our application.)
But you can see that "someone" modified his comment as if they did not want that expression and articulation to be there.!!! interesting...
NMR Excitation, Dephasing and Spin Echoes
http://www.youtube.com/watch?v=KtWnmFg-u5g&feature=related
This short animation shows the process of NMR excitation in the laboratory and the rotating frame, as well as the dephasing that occurs from field inhomogeneity and the formation of the Hahn spin echo
What we see on it is the time stop and than action. Similar to  charging capacitors of SR device and pressing the start button.
It is explained as the time needed to stabilize of the structure (MUT) before it is ready to responds.
As I said in the past I have earn great  respect to one individual over the time.There are many of you who are brilliant as well. I just happened do not go across  them so close.
Shocac my friend it is time for you to take stand
Wesley
