0 Members and 610 Guests are viewing this topic.
ramset
While where waiting for Wesley to "get Everybody By the Balls"[the Bad guys]
GK just pointed this out at Poynt's place [OU research]
Ismael Aviso  [Phillipino OU elec car Guy}
Has A TK Coil in his unit,See here
http://freeenergylt.narod2.ru/ismael_aviso_car/
Chet
Thanks Grandma
Tito L. Oracion
Quote from: ramset on August 22, 2011, 04:00:03 PM
Chet
ok!
we don't actually need an inverter to invert voltages, thats too bulky  ok ;)
stivep
Some of you have asked me which direction to go.
I gave you  one of directions you asked for.
NMR is interaction with  third element Material Under Test (MUT)
Nothing is for free, so say there is no water  used as  MUT but we use another material.. and you have resonance NMR.. Energy from that material instead of just dissipate is simply feeding the system.
Till the energy is consumed.
So all you have to do is to find right material, right interaction
Could  two mixed frequency interact with nuclear spin  of MUT?
Well this is the concept of NMR.
Do we have to  deal with MUT that has finite energy?
The answer is NO.
Well if material MUT was used by John Hutchisin as interacting factor similar way as MUT in abstract I've mentioned than you have partial answer.
wow.. did I say to much? For those familiar with gentleman I've mentioned above and not lazy enough to go  by  my previous 3 posts understanding of historical events snapped to  controversy of "Towers" will be somewhat
shocking.
In IF  of Radio receivers and transmitters..
You have  mixers..Those are different concept mixers.
But any interfering third frequency ( not paid by us ,sunlight, cosmic rays,ocean sound-converted to signal , wind converted to signal, or movement-friction of air particles, any other sources of signal, lightning, cloud electrostatic discharges, and may others ) may interfere and mix with the end output product.
How about if interfering party is overwhelming mix product because of its potential.
Than it will become dominant yet still in need of "door to be open"
Like wind activity indoor of your LR.
Did we pay for it? Certainly we did not.
So say we are mixing in NMR resonance product of spin interaction with helical or maybe "vorex" shape of nuclear response.
and
the MUT is energy reach.
In calorimetry   we should see absorption of energy level  of MUT in NMR or any kind of interaction  that will involve energy exchange or energy differentiation .
Wesley
Ps:
In one of the links I have included Abstract of ferrite based material and statement showing replacing of Fe by Ma  using just right frequency at given amplitude.
If such thing can happened that it was because of NMR .....and they say  it.
It took them 35 years to declassify  that documentation.
You see destruction to the metal by   use  of right Frequency .. with NO FOCUS  BEAM of plasma.
Did You think Why It has happened?
I would like you to analyse MNR
I  would like you make NMR on your own table
Just follow set of 11 videos from the previous post. Sequencing one by one.
Let me know what you come with...
This set of videos is unique NMR that uses earth magnetic field instead of
Cryogenics.
You do not have to pay for that as well.
forest
imho ferrite core device has only weak connection with TK it's rather TPU and VTA based
stivep
Quote from: forest on August 23, 2011, 01:07:23 PM
You are right.
Grey Iron is ferrite based material.
So if factor of Frequency (at given other parameters)could affect  and  destroy molecular structure  ( in NMR) that we may say about a level of interaction available.
By factor of  level of interaction available.
We assume possible force and magnitude of forces of interaction.
And by assumption  me may apply such  potency of expected magnitude to become kinetic force affecting interaction with any other MUT.
Than we exclude MUT that is non promising leaving on the table only what you think  might interact.
Wesley
PS:
If SR used NMR effect than it was possible that NMR might  interract with ferrite at given permeability, to the certain energy level. (he said only 150W)
But when you look at videos from my post before than you will see 3 coils.(NO FERRITE) One of them was  strange...
Than on the drawing you see two coils vertically and the guy says
that these coils must be winded this way that magnetic field is opposite... for me that is counter and clockwise...
Like in Tesla drawings.
The coil of strange winding made on flexible  plastic is actually two coils.. giving XYZ of Cartesian geometry.
Notice that magnetic field of earth is the factor interacting with NMR .
PS#2:
Energy factor PF is the level over the time which stands for consumption.
From that perspective the shortest the impulse the higher is energy  potential .Another words if potential energy is to be  in impulse of 1 microsecond than total power of that impulse might be in hundreds of KW region as if the same potential  energy
could be having power of watts only.
Let's use another example..
You might  pickup something heavy  with rapid lifting and short time to hold.
Than the time you are able to hold it  stays about your energy reservoir
From that moment it is just pure energy consumption.
So if you had to lift it 10 times for short time .. you would do it easier than
Hold  it to consume the same energy.And after that you  have no longer ability to perform again.
or
You know that there is no need for you to lift it more than one time.
Now all of energy is directed to one impulse only.WOW now we have one big impulse..
Relatives of this is snapped to time and area of impact.
Say needle with potential energy converted to kinetic one of
1kg is heaving the same effect as 1000kg on iron rod of Fi=1"
on the same surface.
than total KW power  per area is equal but energy level to make the same work is different.
As far as flyback ..what is important is shape of square wave.
After flyback it is more sign than square. Than if you assume that when you have ratio not 1:1000 but 1:10 than you see that your transformer is performing better square.
Ok so than we think about starting  delivery of square signal from say 200V level instead  form 10V level. to primary of flyback of ratio 1:20 that = 4000V
But square of it is much closer to perfect  one than  one coming from regular TV flyback.
Generally to make initial 200V square is not difficult at all.
So How do we do it.
The simplest way is to buy from ebay amplifier for few dollars.
Say Trek 601B
or HP461A,HP462A much better is HP 465a - this one does not have BNC but banana connector perfect. Than connect it to your 10V  1transistor generator.
Another approach would be pulse forming network PFN  this is super shape solution  but there is the catch. Frequency of the PFN has to be known prior to purchase. If it is made  to work with 100hz to few KHz it is waste of money even if it looks gorgeous .. Do not buy it. The frequency we are interested with the most is 20-100kHz ..another frequency range suggested is arround 600-850KHz.
There is none of PFN I know about that would cover  these two ranges in one unit for Square Wave.
Important factor is impedance matching network
What we have to understand that most of devices on the market is made for 50 OHm impedance of resistive nature.
Well our  load is somehow complicated.
If we talking about coil that Flyback is connected to  than this coil is the load for Flyback AND THAT IS INDUCTIVE LOAD  and impedance  of that coil should be 50 Ohm  with respect to commercially made elements.The difference is made by adding spark gap.
The next step would be to find out if we really need 50 Ohm?
Well No we do not need it..
The only consideration is to make impedance match by tuning structure to resonance.
The only moment  that we might have spark gap in NMR is if it is used to form the pulse.
Usually forming pulse is done with  very low energy levels i traditional NMR.
and is not using spark gap not HV.
remember that in traditional TK suggested chain of reaction is:
- generator at low voltage square impulse
- voltage amplifier ( if you wish to start from level of square  at 200V)
- HV transformer 1:20 ratio
-secondary of  HV Transformer is connected to spark gap and this spark gap is  just creating HV impulse that is triggered by impulse of flyback..
Ideally all we need is spark creating our square wave..
So if You know of any other possible way or technique    to trigger spark that it starts  giving you nice clean   regulated interval of spark.. than nothing before I have described  about pulse creation is important any longer.!!!!!!!!!!!!!!!!!!!!!!
So modified NMR might be the way to couple to OU.
Another limitation is the core of transformer if it is ferrite (not Permalloy 1000hz max)
Than for permeability of 2000 you can go easily to 15kHz.
The better the square at the HV  the better the result as you dealing with brought range of  sign wave components in  single square impulse  is made from.( whan you make FFT(fast Furrier)
Than you see sign wave components. Filters make only part of these components to pass true.. so energy level of such signal is close to sign wave.. Flyback is a filter as well.
that is where you have loses..
But you do not care about the loses after you are able to feed back generator from OU.
The key point is that first you have to have short burst signal impacting "small area" of MUT than when you see response  you no longer care about impulse at all.
It is like first intercourse after that there is less energy needed as barrier is no longer there. :)
Statement to memorize
Subiect
-measurement signal output from secondary winding of transformer
Result
If that impulse shape differs from impulse delivered to primary than
-it is directly proportional to the energy dissipation
-the HV transformer ..reacts always as filter with respect to input square.
-frequency spectral component of input square wave has always more energy
-Frequency spectral component  of square signal (analyzed in Spectrum Analyzer) represents total power delivered so if we are able to see non perfect square at secondary we know that all of the missing components represents losses.
Spark made  fire.. Look at the energy level of spark..
The spark could interact with energy storage  wood..
The whole secret of OU is just to use storage that we do not have to pay for.
It is here and nobody  is charging for it.for. Unless some of governments will start to charge for use of fresh air? :)  ))))))))
Ps#3:
Pulse forming network is important for power transfer and impulse shape
Sphere Gaps
http://home.earthlink.net/~jimlux/hv/sphgap.htm
Quote:
"A spark gap will have a very repeatable breakdown voltages for a given atmospheric conditions. For mostly mechanical reasons, uniform field gaps (using, for example Rogowski or Bruce profile electrodes) are not used as much as sphere gaps where the spheres are quite a bit larger than the gap. There isn't a convenient analytical expression for the breakdown voltage as a function of sphere diameter and gap, as there is for a uniform field gap, however, there is a lot of empirical test data, and sphere gaps are by far and away the most common way of measuring high voltages with a spark gap."
That is another factor important in our project.
the general information  in broad view is given in link:
http://home.earthlink.net/~jimlux/hv/hvmain.htm#TOC
