Shokac
Quote from: stivep on August 24, 2011, 08:24:41 AM
Do we need 100Hz? or we need higher frequency than that?
another question is
Do we need only 2000V or we need more?
Wesley
1. This 100Hz is not necessary.
http://www.youtube.com/watch?v=uxQ99R4gOWY&playnext=1&list=PL63547D173F4A047A
1:25 min. Resonance frequency is 500Hz.
2. If use 2000V, spark gap resonante all frequency. You need only hi voltage for working spark gap.
Kapanadze use Spark gap for automatic resonance. Spark gap automatic adjusts frequency in LC, RC or RLC circuit.
stivep
Quote from: Shokac on August 24, 2011, 10:10:52 AM
2. If use 2000V, spark gap resonante all frequency. You need only hi voltage for working spark gap.Kapanadze use Spark gap for automatic resonance. Spark gap automatic adjusts frequency in LC, RC or RLC circuit.
[/b]
I just come back to my house for the moment
OK so what is the frequency of square signal you recommend?
How you would design  automatic resonance condition?
what do you think is the third  element of interaction  The Source  OF Energy?
Is that interaction in within area of NMR by means of nuclear spin resonance?
Is the secondary role of spark gap to allow us to use coil as load?
Wesley
PS: Lightning is DC but we are  able to hear ( on regular radio receiver) AC components of Lightning strike  because of rise and fall time of square DC impulse of lightning.
So if there was DC only we would have no AC components in it.
Now imagine Square pulse of HV that is = to very long DC amplitude length say 10 hours.
Than  the only change you can see that is an impact is rise and fall time of that impulse.
It is like lady telling you by blinking her eyes that she is ready and than you make your move ( react= interact= synchronize = resonate)
If you do not than you  still at the stage of high potential expectation.
Similar to one pulse NMR.
But this pulse is enough to see NMR signal of nuclear spin of interaction.
You see it..( in NMR) it works with low level of pulse amplitude and  that's all.
DC=resistance response
AC create impedance response
Without AC there is no impedance ..it does not exist as if it was never there. Never existed
TK made activation of phenomena that was like have never existed
Do you see similarity?
Shocac you are great man and I would like you to be one of the first..
on the top.
You deserve it.
For better to all of us.
PS#2
In  90's I was working on( and patenting)  Device that was able to "see" everything below ground level to the depth of 2km.Just by putting piezoelectric sensor on the surface of the ground.Than signal was converted by A/D and treated with FFA (Fast Fourier analysis)
It was called Passive  device... Well vibration from  earth sensed by probe was never passive.. nothing was passive... It was interaction with potentially
ready to interact piezoelectric foil. So if NMR from videos uses earth magnetic field and  not cryogenics than that might be a source of energy.
forest
May I propose well known approach I call : "investigation by elimination" ? What I mean is : write down all possible theories of TK/SR devices in item list. Then find at least one negative proof for each one.
By negative proof (sorry, can't find propar term due to my limited english knowledge) I understand clear and precise argument why particular theory cannot explain TK/SR device.Of course it must be self-explaining proof which everybody accept.
The last theory which remain will be the correct one.
Shokac
Read this 100000 times!
This is very important!!!!!!!!!!!!!!!!!!
HI Voltage and spark gap PUMP CURRENT in 220 Voltage (OR 110) Circuit vith small curent.
Electromagnetic flow secondary must be in phase with the electromagnetic flow in coils that is connected to the spark gap.
The secondary coil is circuit with a voltage and low current.
Kapanadze realized that the two electromagnetic flow is automatically adjusted.
