0 Members and 602 Guests are viewing this topic.
wattsup
@Hello to everyone
It's good to see some are still pounding the pavement on this TK device. I think many have given this as much as they have and I really wish to congratulate everyone for all their hard work in getting this device to any level. In the recent past we have seen others come forward with other devices that we found to have fake attributes and had to work hard to bring these to the forefront so guys do not follow a phantom or illusionist. In contrast, TKs video has proven rather unique in that I have not found any basis to say his device is a trick (besides the rudimentary obvious things) and so, I can only summarize that TK is the real deal from the perspective we have today.
But then comes the problem of HOW IT WORKS. We have seen endless diagrams, endless builds, the SR slant, the Russian frenzy, we have seen and read many methods proposed and thus far nothing and no one has come forward to claim any solid technical guidance for others. So this is where we are today, again in a limbo, again having all the human resources that are still expending their life forces to gain a better understanding of a TK device(s).
So I will ask you guys one question that I am convinced when fully answered will provide a good direction for you and others to follow. The question is very simple, or is it. And that is...............
WHAT IS A SPARK GAP AND HOW MANY WAYS CAN IT BE USED?
wattsup
PS: I am convinced the answer is there in the spark gap and TK realized how many ways it can be used and found a way to use it that not only does one thing in particular, but two things, the latter not being well understood.
dole
Sorry, I did not resist.
Spark gap = gateway
(Theoretically: To whatever you can imagine, Practically: Still undeveloped)
d.
Shokac
NO, NO, NO
Kapanadze Spark gap use for automatic resonance. Spark gap automatic change frequency in RLC circuit.
I tested and proved!
captainkt
shokac your diagram 7116 is almost spot on, last night I basically fed secondary side of large transformer with 300watt inverter,200watt bulb on each output in series (to protect from hv) and then fed primary with high voltage from nst and variac one side of primary going to earth and one side of NST earthed. Much to my delight bulbs lighting everywhere (8x 100 across secondary winding of transformer) I was able to vary brightness from all off (including the 2 in series of inverter ?) to almost blowing.Had to close spark gap on hv to about 2 thou for best results. I now have to sort out a cheap controllable hv supply and work out if OU etc.All previous attempts at joining two frequencys have failed and ended up with blown bulbs and equipment. Now I have something to work with.Thanks and regards.
