0 Members and 572 Guests are viewing this topic.
xenomorphlabs
@captainkt: That's a valuable observation then. The high frequency bands not at all synced/phased with the LF 50 Hz band. What you got there is probably not a case of resonance, but has a beneficial effect on your load.
I remember reading about HV/hi frequency lighting low-power-rated lamps in pure Tesla coil set-ups.
Good Luck with further experiments.
captainkt
@Xenomorphlabs,Yes I agree there may not be resonance, what kept me playing TK was two months ago I built a Tesla coil air core with primary at each end 100 watt bulb in series in centre then fed mains voltage to ends of both coils. I then used a car coil set up with variable oscillator to pulse secondary at one end with other earthed, I went through a few frequency's up and down to see if I could alter the brightness in any way suddenly the bulb exploded and I could put my finger in and touch the filament. I have shattered and melted and fused dozens of bulbs in the past but this was different , sent me deaf for ten minutes.Tried to replicate next day but fail when mosfet gave up.Spark gap seems more reliable and certainly plays a big part in my latest circuit. Regards
captainkt
@Wattsup, If you put one earth after coil and one before T2 secondary then the circuit identical to the one I modified last night 7116,this is brilliant happy experimenting. Regards
energia9
once i have posted on this thread, i could light a 1 watt lamp at the secondary after disconnecting signal generator, not many of you have looked into it. i still wonder what have caused that apparatus, i could not replicate my own experiment after,
things i observed were much like kapanadzes device,  frequency it operated at was 1.2 mhz,  and i held signal generator probes away from the coils and the Lamp did not respond,  (lamp did not dim at all)
Any explanation why did this happened and why i couldnt replicate this second time?
i keep thinking i allready had the answer to the tesla device that time.
xenomorphlabs
Without posting your entire circuit, it's impossible to understand what went on in your set-up.
Things like that get reported often (the impossibility to replicate), you probably hit an earth standing wave, then moved your clip leads a millimeter and went offtune.
Until you don't know exactly what the parameters of your circuit are, you are literally working in the dark.
Let's hope one day you can replicate it.
