0 Members and 510 Guests are viewing this topic.
energia9
Quote from: xenomorphlabs on August 31, 2011, 12:11:27 PM
Without posting your entire circuit, it's impossible to understand what went on in your set-up.
Things like that get reported often (the impossibility to replicate), you probably hit an earth standing wave, then moved your clip leads a millimeter and went offtune.
Until you don't know exactly what the parameters of your circuit are, you are literally working in the dark.
Let's hope one day you can replicate it.
The lamp was lit as long as i have not touched the coils, i left it like that for half an hour or so while the signal gen was with its pos neg lead were away from the coils, about 1.5 meter away, i saw that distance did not disturb the light, brightness did not change at all. anyone explain this? im still thinking for 1 year now why did this happen and i still dont have my answer. any professionals around who can explain?
something i nearly forgot to mention is that at the time i did not have a high voltage transformer so i made 1 out of ordinary 220-12v volt mini transformers, i dissasembled them and made 1 like in the picture below which give me around 400 volts total connecting the signal generator
there is a mistake in the drawing where i say 0.4 volts 5 miliamps in, that was measured coming from the signal generator before the disconnection ,
wattsup
@energia9
Here is  one in a series of youtubes I did on pulsing coils that may show some of your effects. At 1.2mhz, one wire lighting of LED is common.
http://www.youtube.com/watch?v=P5zXe_iJzXc
I once held the pulse generator terminals with my fingers and a coil with an LED lit up 5 feet away from me. I never was able to re-do the effect. It was the weirdest thing ever.
wattsup
energia9
Quote from: wattsup on August 31, 2011, 04:19:56 PM
@energia9
wattsup
wattsup, i did not have any kind of connection to anything with my two leads, pos neg,  they were separated and thrown away from the coils.
very nice to hear you have experimented in this field too.:)
stivep
@energia9
wattsup
Please concentrate on that what I say here. It is important to do not waste your time or to properly  isolate known science art from unknown science art.
Nothing special and nothing unusual I have seen on that video.
1.Every LC parallel or series resonant circuit is RLC circuit
2.Every coil, capacitor and most of resistors are RLC series and parallel resonant circuits at the same very time.... even if not connected to any other R or L or C and represent single electronic element of R or L or C.
3. Every coil, capacitor or most of the resistors have their own self resonant frequencies!!!!!
4. Every coil, capacitor or most of the resistors is resonating in self resonant frequency.. of
-series equivalent resonant circuit,
-parallel equivalent resonant circuit,
-combination of series, parallel resonant circuit . AT THE SAME VERY TIME !!!
BUT....
each  one of self resonant frequencies is different.
each harmonic of that particular self resonant frequencies is fed by energy of primary resonant frequency.
5. series resonant circuit "wants to" blockade every frequency other than main self resonant frequency  allowing maximum of amplitude only at that frequency
6.parallel resonant circuit "wants to" blockade  only one frequency and all of other frequencies  are allowed to pass.
What is filter and how it  differs from  resonant circuit.
The answer is: IT IS NOT DIFFERING AT ALL.
Coil or capacitor or most  of  resistors can be a filter even is it is not connected to any other R or L or C.
What is counterpoise of an antenna:?
It is a BALANCE  to main or primary of active resonating element.
example- every antenna must obey laws of conservation energy
"Dipol antenna " placed horizontally looks like this
http://en.wikipedia.org/wiki/Dipole_antenna
Say in the positive part of sign wave left arm is   active and right arm is counterpoise -at that particular very time.
Vertical antenna  ( say your car radio antenna ) weep  is  active and body of your car is counterpoise. (For HF frequencies is not that  easy..)
LW antenna ( Long wire) is a single end of wire connected to TX ( transmitter or generator)
generator body is than counterpoise to the antenna.
But overall length of the wire must be able to resonate at  frequency of choice, and additional tuning coil( and/or resonant circuit RLC) might be required to adjust counterpoise ( body of  generator- metal box ) so the counterpoise becomes balance
to that active  wire and represents  electrically equal balance to the active element.
Got the picture?
You just playing with antennas.
One of them is connected to transmitter  - generator
Second one is connected to receiver LED.
Wesley
PS:
Efficiency of an antenna:
If your "dipole" type of antenna is 40m long it will be 1/2 of 80m wave=3.8 MHz That antenna will resonate at 3.5 MHz. and take most of your roof and back yard length.
Now - You take this antenna and coil the wires
This antenna will than be on your table small and convenient and  it will be theoretically the same exactly antenna .
but there is the catch!!!
efficiency of that antenna a will be  very small.
That is why you guys are trying to connect straight wire to the radio to have better reception of  the radio wave.
every antenna  can be   used as transmitting and receiving antenna .
some of car antennas have small coil at the bottom or in the middle.- that is  for being able to keep electrical length of antenna and at the same time have height of that antenna smaller so it will become convenient in every day  driving.
BUT IF YOU STRAIGHTEN THAT COIL YOU WILL HAVE BETTER RECEPTION.!!!!!!!!!!!!!!!!!!!
Although there is one catch:
The capacitive component of that coil is part of resonant circuit, so when you pull that wire and the coil become straighten than electrical length of that wire my push it to resonate at different frequency than previously designed.
Also bandwidth of that antenna will become more narrow.
In general for FM radio this is not important. That antenna is broad band FM antenna with unacceptable parameters for professional.
You can as well put piece of wire instead of THAT ANTENNA AND WILL WORK AS WELL.
And the reason  for it is  the signal strength is so big that many times you could  put just  one centimeter  of wire and you will still be able to receive something.
That is what you doing now my friend.. just playing with known art.
http://en.wikipedia.org/wiki/Random_wire_antenna
Is it worth of your time..?
YES it is..
It is like trying to trying to open the door  with your nos...You may experience something that others will never find out.And that may lead you to discover elements of mechanism of your nos playing with the handle.
Rest of the world decided to be uneducated in this area  or simply never thought about it.
But if you try to open the door that is already open than you have to create imaginary door. That leads you to graphics and art of graphics.
There is no motion that does not bring you to interaction and evaluation of that interaction..(within area of your 6 senses)
However there is ignorance to factors of interaction qualified as non important
