xenomorphlabs
Quote from: Shokac on September 05, 2011, 02:13:41 PM
No, electronics use for make HV, and for make inverter. (Device without inverter or 220V)
Filter = Condenser
First frequency adjuster = Spark gap
Frequency stabilizer = RC circuit (T=RC)
Second frequency adjuster= Adjustable Spark gap (Green box)
Think simple!
Okay then, good luck shifting the phase and synchronizing the signals with the simple components )
stivep
Quote from: Shokac on September 05, 2011, 02:46:09 PM
Read this
http://www.capturedlightning.org/hot-streamer/TeslaCoils/MyPapers/spark1/sparkgap.html
Pay attention to the current
... The power of these bursts is remarkable. Early testing has shown that, even at low voltage levels, these bursts may reach many hundreds of amps at the ~50MHz frequency. By far the most powerful burst is the very first one.
Typical scope photos often show this as a vertical line that occurs just at the beginning of conduction. My equipment has not been able to measure the level of this spike with great accuracy but it appears to be around 400 amps which is remarkable considering the relatively low 2000 volt spark gap setting. ...
Shocac my friend...
this what is below is for you attention!!!
Wesley
stivep
Quote from: Shokac on September 05, 2011, 08:08:14 AM
This is the basic principle on which I work. I try to sync the primary and secondary. Synchronization should be 50Hz. Or 220V source set in the oscillation frequency of the primary (HV), and then back down to 50Hz.
?!?!Or 220V is DC?!?!
Tesla use DC in secundary circuit. (Second pictures). http://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes08.htm
:)     !!!  :) desni
Wesley
Choose username
#  DEAR COLLEAGUES!!!        #
#  Now you can download full version (and better quality) of Kapa's GLASSBOX show (!!!) #
#  Do it here http://uploads.zaryad.com/users/ionshare/tariel/                                     #
xenomorphlabs
Cool, that is indeed a much longer version.
Thanks for the link !
Gives some good views on the glassbox that contains "simple" components and no electronics ;)
