0 Members and 90 Guests are viewing this topic.
xenomorphlabs
Quote from: forest on September 08, 2011, 03:37:20 AM
Primary is Tesla coil with iron pipe core, that's sure for me. Secondary at 90 degrees lying on bottom of box. Tariel stated it is not connected with primary which is interesting. There is also black cylinder device in the center which looks a bit like a big electrolytic capacitor from industrial inverter.
The black cylinder has thick wire wound around it and is hollow.
EDIT: Forest might refer to the other cylinder right at the glass wall.
That's actually the only thing in there, would the tube/pipe in the middle be out of iron that exhibits enough mass to produce the hum.
The primary "Inside" is thin like sheets, less like a pipe.
It might be no magnetic effect that TK uses it for, note the electrical connection to that sheet/pipe .
Also i have a hard time to actually recognize any windings/wire on the primary.
There is something that looks like copper sheet, maybe like a single turn winding?
Or is it a tubular capacitor made out of copper and aluminum (only my interpretation)? And in case it has windings, i smell negative inductance on that thing )
Choose username
It`s interesting:
translate from 22min 00sec:
(guests=GS, Kapa=TK)
TK22.00: when we will repair the electronic starter, the spark will not be here. Also not to be this noise,
listen- it is almost unheard now, because device is entering normal mode. But small noise you can hear, if you get closer.
GS22.20: I hear small noise from the rear of the box.
TK22.25: Because here is a very big load.
(At 22.30 unexpectedly the spark began to clicked very often)
TK22.31: it starts to regulate itself.
GS22.33: there is something wrong!!
TK22.34: no no, nothing wrong!
GS22.35: look - it is a smoke from the bottom!
TK22.44: let's we give it a rest
GS22.45: overheated...
TK23.01: i will check it all
GS23.12: maybe it is so, because your fan was off..
TK23.12: the fan should not work until the temperature will not increase (thermostat)
another interesting moments:
TK05.18: ..and there, from the third coil we take so many elecricity, how we need.
Really i don't want to say this, but i will say that the main effect is there.
(Tariel draws attention to the fact that the coils should be located so, and not the other way,
because the interaction of electromagnetic fields is needed.)
At the 10.10 Tariel suggests that if he put the battery other way round - device must stopped.
But it did not happen  ;D
From the 11.46 TK tells the guests about Tesla's electrocar, and say that probably such box
was used by Tesla installed under the seat.
One of the guests ask TK "What happens if right now we tear the grounding?"
TK19.29: once it was so, my assistant did it. Only the electromagnet was burned, and
nothing more.
(aha! electomagnet is used inside! but for what? hmm..)
At the 19.45 talk about the kapagen's stability with the working load. It can be low
and high. But at the traditional power plant, disappearance of the load is a accident situation.
Inside the box we can see many printed circuit boards. Some users at the russian forums
(who repaired old USSR TV) identified vertical unit,HV, etc... This PCB don't look as altered
or as resoldered. For this reason many people assume that this is a usual camouflage.
xenomorphlabs
@chooseusername:
Thanks for the translation. I wonder how you understand TK lol,
he speaks with weird accent.
Yeah half the stuff in there is TV trash.
The upside down board right in the middle of it probably has the inverter circuits on it.
I like the expression "normal mode" haha.
So the third coil with the thick black wire is the actual output coil as it seems he wants to indicate. At least explains the wire diameter choice.
You can track back one of the wires that exit the glassbox to the load right to
that 3rd coil. The other exit wire comes off the end of the big coil. Remarkable hehe.
So there is actually 2 output coils if you think about it (if that is a 2-phase signal that he puts out to the lamps at all).
About there being an electromagnet, well any coil is technically an
electromagnet.
Well and this noise explanation is weird, because the spark gap's sound
is clearly identifyable. But he pointed also out that the noise fades away.
xenomorphlabs
The primary coil is possibly wound with flat copper sheets.
But that is a speculation, the close-ups are still not too revealing
about that. At least you can't see the typical wire relief poking through
the insulating tape.
So if there is windings on there at all, it could be "flat wires".
This would strongly indicate capacitive effects being used.
Choose username
flat copper sheets i see here too!
i forgot about last news: Tariel's wife left him, he is still ill, and his friends (or assistants) have no more contact with him. Giya (our connecting link with TK) does not appear more in Skype :'( It is so already abt. 4months(((. I think there is something strange (( Seems this secret will die with him
