0 Members and 54 Guests are viewing this topic.
wattsup
Does anyone know anything about high voltage full wave bridge rectifiers. I am trying to put a fwbr on the secondary of my feed supply MOT which is high voltage in order to work with high voltage DC with the diagram I made a few pages ago to follow the Tesla Ozone Patent replacing the rotary switch with a spark gap. Well so far with AC the there is no spark but the bulb which is off the primary of a second MOT is lighting up really well. I want to do this in DC because the patent is using DC and in the past I had made up to 1500 vdc with an input of 12vdc but that was way back and the output had no amperage, only reactive.
I think that with this set-up, I will arrive at the conclusion that the coils are not suitable for the task and from there can start experimenting with TK type coils but at least make the base method as Tesla. But first  need to get the spark gap going.
wattsup
I tried a standard fwbr on the MOT secondary and nothing happens.
Magluvin
Interesting twist there Cosmo. I can see that if the twist is just once per turn, that it emulates 2 turns of 1 coil of the bifi next to eachother and then 2 turns of the other coil, then 2 urns of the first.
Would be strange if there is something to it, as in some advantage.  ;]
Thanks for showing. I havnt seen this before.
Mags
xenomorphlabs
Quote from: Magluvin on September 09, 2011, 08:03:22 PM
Mags
If you don't see an advantage in that winding technique, you might wanna research Caduceus coils (Smith Coils).
SR193 used the same technique in his coils by the way.
DimaWari
Thanks Cosmo. Its worth investigating.. could be he was using two tensor coil? One was transmitter and the other was receiver..
Jury1
Thanks wings for your answer (Reply *7212)
Interesting application GDP panels)))
http://jnaudin.free.fr/html/bluespike.htm
I liked the publication  Niels Jonassen - «The Atmospheric Electric Circuit».
I consider that processes in troposphere play a major part in reception of the response of environment.
Important electrical processes are occurring not only in the troposphere but also the upper layers of the earth.
GDP panels  To me has reminded - Bifilar Coil Patent No. 512,340
