0 Members and 49 Guests are viewing this topic.
DimaWari
@xeno
Hmmm... Probably you were right.. SR said "Dead Magnetic Field" if I recall. And by using HV sparks you will be able to disable or reset the effect?
thanks xeno for the info...
Waves
And Tesla said " dont let energy go to space". In  caddeus coil is not magnetic field.
Jury1
Quote… " dont let energy go to space"
That's right! In the bifilar coil, greatest electric field, magnetic field is zero )))
IMHO Naudin uses the skin effect - GDP_Driver  -  sin(F=5,822KHz A30V)…
xenomorphlabs
Quote from: DimaWari on September 10, 2011, 04:19:58 AM
@xeno
I think the sparks by themselves play no big role in the glassbox device, SR uses a continous spark-gap but also creates a tension around the caduceus coil with the HV winding.
As was observed acoustically, the glassbox device runs even with the sparks being very irregular. It is the high "tension" around the coil that seems to be important.
The primary if looked at as a capacitor gets charged with HV and then if the voltage is too high (set by the gap distance) it discharges like a safety spark gap.
This all makes perfect sense.
I have a hard time bringing the 3rd coil into the context however.
The fact that it is wound "normally" and around a pipe-like former leans towards
a magnetic coil that should inductively couple to "something" (whatever that is).
Another possibility is that this 3rd coil is being fed with an independent signal that he does not want to inductively couple to the horizontal coil. The placement to each other would be optimal for that.
The 3rd and the horizontal coil are anyway "coupled" through the load due to the 2 cables going to the load coming from these 2 coils.
EDIT: I forgot to consider all possibilities.
The 5 turn coil could very well be a so-called balun/RF choke.
Like here: http://k8ld-qrp.blogspot.com/2011/04/building-vertical-antenna.html
http://www.ebay.com/itm/RF-CHOKE-BALUN-160-6-meters-/170660393454
http://home.comcast.net/~ac9ts/pics/choke.jpg
http://ce3rkw.net23.net/30-40m_choke_balun.jpg
In that function it would not interact with the other coils like i hypothesized earlier.
It would also protect the transistors and associated circuit  that it directly connects to at the rear of the glassbox from interference.
That would be also in keeping with the TK patent and seems to be its most likely function.
forest
that black coil could be modulator coil to get required output frequency like 50Hz, would be important to trace all connections between coils !
overall setup looks very similiar to Don Smith method with clever modifications (Hendershot coil !) - that's interesting , if it works then Don Smith coil can be placed directly in the same place
very useful info . thanks
idea is now very very simple  ;D
