0 Members and 132 Guests are viewing this topic.
the_big_m_in_ok
epwpixieq-1 said:
Hi,
I have translated "kak_rabotaet_Kapanadze.doc", as found here http://www.hvlabs.hu/zpe/Gruz/ ,  form Russian and would like to post it to the forum.
The .doc file file you did post is in Russian Cyrillic.  All the other files I tried on your posted entry loaded and ran with IP or Operating System software plugins.  No problem there.  They work.
The problem is that the file is around 1MB. Do you know where I can post it so the interested people can have access to it.
You haven't uploaded it yet?  If not, can the file be split into .doc sections and uploaded individually?  They would run easier that way.
--Lee
lltfdaniel1
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
MasterPlaster
Quote from: epwpixieq-1 on August 24, 2009, 01:33:32 PM
I have translated "kak_rabotaet_Kapanadze.doc", as found here http://www.hvlabs.hu/zpe/Gruz/ ,  form Russian and would like to post it to the forum. The problem is that the file is around 1MB. Do you know where I can post it so the interested people can have access to it.
try scribd.com
Thaelin
   There is an upload directory here on OU. Put it there.
thay
kukulcangod
Excuse my lack of expertise but isn't this kapanatze circuit resembling a scaled up Joule Thief? the resemblances are many my jt works great with my 2 volt earth battery lightning up leds and also using concrete aluminum copper batteries, so if that was the case how can we scaled up ? so replacing the transistor with and air gap and adding a secondary winding to a huge toroid? then getting  even bigger anodes and catodes buried into the ground, what I thing would be missed in any case will be the addition of some sort of an energy loop ala Bedini sending pulsating energy to the ground and in between we would capture that ripple effect with magnified energy in between, that's how I understand resonance will be working ,also the jt works best with the proper capacitor . There's something going on with this energies cause my dry concrete batteries are generating solid values after 15 days at the time of this post ,also it is simple to see how by connecting and disconecting the earth battery
causes a higher output of energy .
best tegards
