wattsup
That winding seems to be exactly a reverse bifilar or counter bifilar that requires an overlap at each turn. Now if you do this and alternate your pulses, you will create a virtual generator. There should be a coil under this one also since alone, such a winding would seem pointless.
wattsup
FreeEnergyInfo
xenomorphlabs
Quote from: wattsup on September 14, 2011, 11:45:44 AM
wattsup
What you describe is what SR did.
The one Kapanadze has seems to have 2 parallel wires but on top of each other that cross over once (or twice on the backside?) per turn but wound in the same direction (CCW).
So 1st turn wire 1 is outside, wire 2 is inside, 2nd turn wire 1 is inside and wire 2 is outside and so forth.
Bit different than normal caduceus, more like enhanced caduceus but has the nodes too just bifilar.
So twice as many demons and ghosts will be conjured by this evil coil and jump out of the wall :D
wattsup
Quote from: xenomorphlabs on September 14, 2011, 12:22:33 PM
So twice as many demons and ghosts will come jumping out of the wall :D
It simply looks like you take a wire and find the center point. You start there under the core then come up from both ends and cross, then go under again, then come up and cross again. This gives you two winds with reverse polarities. If the start end is joined then this could be counter bifilar bucking mode so you only need one input pulse.
As for the demons, I'd take a 400 volt demon any day. lol
wattsup
