0 Members and 121 Guests are viewing this topic.
epwpixieq-1
Hi,
Here is the link were the translation was uploaded.
http://www.vfedtec.com/doc/kapanadze/
Also there the is .tex  file that was used to generate .pdf file.
Regards,
SS
sparks
  yes it does appear as a scaleup.  Have no doubts about the power of a constant 1 volt dc supply.  Energy is change in a field of interest.  Now the field of interest can be changed by a rise in electrical polarization once a day when we connect the battery to a load or it can be changed 5thousand times a second with the same amount of input or less.  The problem is that we measure input power and output power using a resisted circuit.  We are trying to effect change and change is being resisted so of course our power measurements are going to be screwed up. By increasing voltage and frequency we effect more change in a larger field.  One radio wave transmission effects or catalyzes the movement of countless atoms thousands of times a second in an expanding field whose radius can be millions of miles.  If we were able to collect the atomic response of the mass effected by the radio wave transmission of say 1 second and store it in a condensed field the size of the original "battery" then take this energy and put it through a resistance the resistor would instantly vaporize never mind get hot.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
forest
sparks,
you mean : one transmitter and thousands of receivers ? how to build one receiver which accomplish task of many thousands ?
sparks
@forest
  Good question.  If the spark gap is viewed as the transmitting antennae there needs to be alot of receiving antennaes placed about it. Not only that but all the antennaes need to be attached to tuned circuits or resonant circuits that store the gain of the many antennaes from the field.  Then all these tuned circuits need to be attached to the load circuit.  I believe this device could broadcast into a coil where each turn of the coil becomes a receiver.  The turns act as a resonant circuit if the capacitance and inductance of the turn is matched.  Each turn becomes a tuned receiver and the power is multiplied by the number of turns. If mass is vibrating at some fundamental frequency and the radio signal aligns the randomized atoms so that they are now vibrating in harmony.  The radio signal becomes the catalyst in the atomic reaction creating some order in the normally chaotic atomic lattice of the mass.  Neuclear magnetic resonance frequencies of various elements tells us something about the vibrational energy of mass at rest.
Think Legacy
Spread the Love
flathunter
Quote from: forest on September 14, 2009, 05:28:16 PM
sparks,
This is exactly what i've been playing with.  Here's a video:
http://www.youtube.com/watch?v=MS5TSZC3nEM
I'm gonna keep building more receivers, and keep adding more loads....but i need more space than my tiny flat.....next year i'll hopefully get a new place.
Thoughts and suggestions ALWAYS welcome  ;D
