dllabarre
Quote from: core on September 20, 2011, 12:46:07 AM
  Like all the other video's there's something that is always hidden. Ironically everybody talks about the coils being the secret but these coils are clearly visible.
  In the most recent video the high voltage module is visible, coil, and wires to the load. So the big question is 'What is in that plastic box that is SO obvious that it must be hidden?' It can't be just a circuit board as it would be hard to trace how the components are wired. We already see the high voltage module so we can exclude that. Forget the coil, if it were a secret it would be covered.
  There is something hidden in that plastic box. Something probably very simple. Whatever is in there was most likely inside the green box, buried in the Plexi-box unit and in the metal boxes of the Turkish unit.
  I imagine that it is something very familiar that most have seen already. It has to be hidden, if you were to see it you would probably realize you have been chasing your tail for a long time.
-Core
Stevip
What did you see in the plastic box with a cover on it?
I know you looked..   ::)
It "could" have been a couple batteries for all we know.
stivep
Quote from: Shokac on September 20, 2011, 02:16:19 AM
@Stivep
How many hours have passed since the TK told his guys to make the device, until you have it when you see it works?
Regards!
ps:
If someone has a book:
ANGRIST S W "PERPETUAL MOTION MACHINES" vol 218
AROUND 9.45 HOURS
By this time that man had to find  elements that  he did not have.
Coil utilized from previous experiments.
Please look at any other video from before (of TK) to see if you can find it.
Device was assembled not by TK but  the device contained "certain component made by TK"
WESLEY
xenomorphlabs
Quote from: stivep on September 20, 2011, 10:31:05 AM
AROUND 9.45 HOURS
WESLEY
Can't be from any of the available demonstrations i think.
The big coil has 8 turns and in the glassbox it has 5 and the small
coil is much longer than the one in the glassbox.
And greenbox coils had different dimensions too.
Also the interconnection is different.
But good that you stated the 9 hours time, i thought about that
the other day. Winding the coils alone would take longer.
The guy that constructed the device, must know at least enough about its function to make it work or possibly troubleshoot it, if it doesn't startup right away.
FreeEnergyInfo
http://www.realstrannik.ru/forum/39-kapanadze/102-analiz-replikaczii-ustanovki-tarielya-kapanadze.html?limit=18&start=3798#27917
эÑ,о уже обсуждалось и я пропусÑ,ил, или все-же есÑ,ÑŒ новосÑ,ÑŒ?
=SR=
Сердечник набран (склеен и обмоÑ,ан изоленÑ,ой) из Ñ,,ерриÑ,овыÑ... колец, Ñ,ри обмоÑ,ки,
- на одну приÑ...одиÑ, Ð'ысокое через разрядник;
- Ð'Ñ,орая со средней Ñ,очкой запиÑ,ана через гену 50 Ð"ц;
- Ñ,реÑ,ья съÑ'мная;
Земля виÑ,уÑ...ой через полый сердечник на нагрузку (лампа), на каÑ,ушку съÑ'ма ...
1. Сердечник набран из Ñ,,ерриÑ,овыÑ... колец.
2. Кольца склеены. Получилась Ñ,,ерромагниÑ,ная Ñ,рубка...
3. СверÑ...у слой изоленÑ,Ñ‹, поняÑ,но для чего?.
4. ПоÑ,ом намоÑ,ана каÑ,ушка на коÑ,орую посÑ,упаеÑ, Ð'ысокое напряжение, порядка 2КÐ' - 5КÐ', через разрядник. КоличесÑ,во виÑ,ков не счиÑ,ал.
5. Ð'Ñ,орой конец каÑ,ушки на землю, земля пропущена через полый сердечник на кольцаÑ... и уÑ...одиÑ, на баÑ,арею оÑ,опления (ЗАЗЕМЛЕНИЕ!!!) ... Mad Mad
6. СверÑ...у на каÑ,ушку с Ð'Ð' намоÑ,ана изоленÑ,а, поÑ,ом две полуобмоÑ,ки (16 виÑ,ков вроде), на коÑ,орые и рабоÑ,аюÑ, два Ñ,ранзисÑ,ора на радиаÑ,ораÑ... (12Ð' Ð¥ 50 Ð"ц и Ñ,ок приличный судя по оÑ...лаждению), мульÑ,ивибраÑ,ор Ñ,ам или чÑ,о ??? . Скорее полумосÑ,...
7. Ð'ысокое получаеÑ,ся при помощи ещÑ' одного Ñ,ранзисÑ,ора, он усÑ,ановлен сбоку усÑ,ановки на радиаÑ,оре, о чÑ'м говориÑ, сам авÑ,ор.
ЭÑ,о скорее всего блокинг с Ð'Ð' Ñ,рансом.
8. ТреÑ,ья , эÑ,о каÑ,ушка съÑ'ма, нагружена лампой и Ñ,рансÑ,,ормаÑ,ором 20 Ð'Ñ,.
9. Через Ñ,анс и выпрямиÑ,ель с Ñ,,ильÑ,ром образовано кольцо самозапиÑ,ки девайса...
Ну, и сÑ...ема запуска с накопиÑ,ельными кондÑ'рами и кнопками...
1. НеÑ,. Там не используеÑ,ся резонанс колебаÑ,ельного конÑ,ура и нагрузка не являеÑ,ся часÑ,ью него.
2. 50Ð"ц Ñ,,ормируеÑ,ся просÑ,ым способом к резонансу не имееÑ, никакого оÑ,ношения. КолебаÑ,ельного конÑ,ура Ñ,ам неÑ,.
Рекомендую всем выбросиÑ,ÑŒ из головы Ñ,,разу "резонанс колебаÑ,ельного конÑ,ура". Слово резонанс имееÑ, другой смысл в усÑ,ановке.
По поводу промышленной часÑ,оÑ,Ñ‹, в усÑ,ройсÑ,ве Капанадзе эÑ,о делаеÑ,ся элеменÑ,арно и менее заÑ,раÑ,но, чем при использования инверÑ,ора. Тем более процесс Ñ,,ормирования 50Ð"ц эÑ,о один из важныÑ... моменÑ,ов, сочеÑ,ающиÑ... в себе 2 Ñ,,ункции: Формирование синусоиды (не однополярныÑ... импульсов, а именно синусоиды), часÑ,оÑ,а коÑ,орой можеÑ, легко регулироваÑ,ься и более важная Ñ,,ункция, о коÑ,орой я не буду упоминаÑ,ÑŒ. ЕсÑ,есÑ,венно присуÑ,сÑ,вуюÑ, помеÑ...и вносимые вÑ,оричным полем, чÑ,о иногда влияеÑ, на показания приборов, часÑ,ÑŒ эÑ,иÑ... помеÑ... усÑ,раняеÑ,ся заземлением общего вывода Ñ,рансÑ,,ормаÑ,ора.
Хочу обраÑ,иÑ,ÑŒ внимание, чÑ,о с "каÑ,ушек" снимаеÑ,ся напряжение на прямую, без какиÑ... либо преобразоваÑ,елей, часÑ,оÑ,а 50Ð"ц. Любое подключение нагрузки , даже через дугу не позволило бы добиÑ,ься эÑ,ого, будь Ñ,ам резонанс конÑ,ура.
Порог не в напряжении, а в способносÑ,и создаваÑ,ÑŒ Ð'Ч поле, коÑ,орое сÑ,имулируеÑ, "Ñ,,ерромагнеÑ,ик".
для Ñ,,ормирования синусоиды используюÑ,ся мощные биполярные Ñ,ранзисÑ,оры PNP и NPN проводимосÑ,и, каждый на свою полуволну
домены эÑ,о и есÑ,ÑŒ магниÑ,ики. попов в резонанс с часÑ,аÑ,ой из искры, домены гоÑ,овы выполниÑ,ÑŒ другую Ñ,,ункцию, Ñ,оесÑ,ÑŒ повернуÑ,ся куда им прикажуÑ,, а приказываеÑ, им поÑ,ом переменное мегниÑ,ное поле с Ñ,оком 50 герц. в принципе Ñ,о часÑ,оÑ,а можеÑ, быÑ,ÑŒ к примеру и 400 герц.
Хочу уÑ,очниÑ,ÑŒ несколько моменÑ,ов:
1) Капанадзе в первом своÑ'м видео говориÑ, чисÑ,ую правду, единсÑ,венное, его поняÑ,ия и ваши могуÑ, расÑ...одиÑ,ься, НР: Ñ,оÑ, же резонанс.
2) Капанадзе правильно сделал, чÑ,о вывел разрядник на "улицу"(снаружи коробки), Ñ,ак как если разряд не загориÑ,ся, Ñ,о Ñ,,окус не удасÑ,ся, поэÑ,ому он на проÑ,яжении всего Ñ,,ильма волновался за искру.
3) Ð' усÑ,ановке используеÑ,ся два эÑ,,Ñ,,екÑ,а , Ñ,олько в комплексе они даюÑ, резульÑ,аÑ,. Ð"уга имееÑ, широкий спекÑ,Ñ€ , несколько из эÑ,иÑ... часÑ,оÑ, являюÑ,ся резонансными для "Ñ,,ерромагнеÑ,ика" , чÑ,о и вызываеÑ, определенные в нем процессы. Ð'озникаеÑ, поле. Но поле эÑ,о "мÑ'Ñ€Ñ,вое" и рабоÑ,у совершаÑ,ÑŒ не можеÑ,, поэÑ,ому подключаеÑ,ся вÑ,орой процесс. Ð' сумме эÑ,и два процесса и служаÑ, для получения избыÑ,очной энергии из Ñ,,ерромагнеÑ,ика и из воздуÑ...а эÑ,а энергия не береÑ,ся.
И еще : ФерромагнеÑ,ик можно предсÑ,авиÑ,ÑŒ как маÑ,ериал, где очень много мелкиÑ... магниÑ,иков, коÑ,орые в виду Ñ...ауса направленны в разные сÑ,ороны и не могуÑ, создаÑ,ÑŒ резульÑ,ирующее поле. Первый процесс позволяеÑ, им расслабиÑ,ься , вÑ,орой повернуÑ,ься Ñ,ак, чÑ,о бы все эÑ,и мелкие магниÑ,ики создали резульÑ,ирующее поле причем мощное. Если сказаÑ,ÑŒ просÑ,о, Ñ,о создаеÑ,ся мощный магниÑ, с возможносÑ,ью им управляÑ,ÑŒ. Ну, а дальше дело классической Ñ,,изики.
оди из процессов, эÑ,о с самого начала Ñ,,ормирование искры, для эÑ,ого нужно высокое напряжение. добившись искры, в искре мы уже имеем широкий спекÑ,Ñ€ часÑ,оÑ,, вспомниÑ,е, админ говориÑ, искра генерируеÑ,, и весь эÑ,оÑ, спекÑ,Ñ€ мы оÑ,правляем на каÑ,ушку, и одна или как сказал админ несколько часÑ,оÑ, имеюÑ, резонанс с сÑ,рукÑ,урным вещесÑ,вом в Ñ,,ерромагнеÑ,ике и эÑ,о вещесÑ,во мы засÑ,авляем резонироваÑ,ÑŒ, с помощью слабого элекÑ,ромагниÑ,ного поля создаваемого каÑ,ушкой, через коÑ,орую проÑ...одиÑ, весь спекÑ,Ñ€ часÑ,оÑ, из искры. я называю эÑ,о вещесÑ,во домен. из описаний мельниченко. когда домен наÑ...одиÑ,ся под дейсÑ,вием резонанса, мы можем легко повернуÑ,ÑŒ его в любую сÑ,орону, а эÑ,о уже вÑ,орой прцесс, при эÑ,ом заÑ,раÑ,им совсем небольшой Ñ,ок. повернув домены мы из Ñ,,ерромагнеÑ,ика делаем обычные магниÑ,, в данном случае обычный Ñ,,ерриÑ,овый магниÑ,. меняя направление Ñ,ока, мы меняем полярносÑ,ÑŒ магниÑ,а. здесь мы применяем для перемены полярносÑ,и магниÑ,а 50 герц, и чÑ,о очень важно эÑ,о должен быÑ,ÑŒ синус, Ñ,ак как Ñ,олько переменное магниÑ,ное поле можеÑ, создаваÑ,ÑŒ Ñ,ок в проводнике. и поэÑ,ому мы имеем уже не просÑ,о Ñ,,ерромагниÑ,ный сердечник коÑ,орый рабоÑ,аеÑ, в обычныÑ... условияк Ñ,олько на высокой часÑ,оÑ,е, а Ñ,,ерриÑ,овы магниÑ,, полярносÑ,ÑŒ коÑ,орого ма можем меняÑ,ÑŒ с часÑ,аÑ,ой какая нам нужна. к примеру, если мы при рабоÑ,е искры на вÑ,орую обмоÑ,ку подадим посÑ,оянный Ñ,ок, Ñ,о мы из Ñ,,ерромагнеÑ,ика получим посÑ,оянный магниÑ,, и он будеÑ, соÑ...раняÑ,ÑŒ свое дейсÑ,вие пока мы неоÑ,ключим Ñ,ок. чÑ,о Ñ...оÑ,елось бы оÑ,меÑ,иÑ,ÑŒ, в просÑ,ом случае имееÑ,ся в виду обычная рабоÑ,а просÑ,ого Ñ,рансÑ,,ормаÑ,ора, для Ñ,ого, чÑ,о бы повернуÑ,ÑŒ домены нам нужно примениÑ,ÑŒ очень большой Ñ,ок, Ñ,ак как домены сопроÑ,ивлюÑ,ся и Ñ...оÑ,яÑ, вернуÑ,ьсяв исÑ...одное положение. а вч из искры делаеÑ, домен послушным и он пересÑ,аеÑ, сопроÑ,ивляÑ,ся, и несÑ,ремиÑ,ся развернуÑ,ся в исÑ...одное сосÑ,ояние, а послушно поворачиваеÑ,ся Ñ,уда, куда нам надо, при эÑ,ом мы Ñ,раÑ,им намного меньше Ñ,ока нежели при обычныÑ... условияÑ... Ñ,рансÑ,,ормаÑ,ора. и Ñ,епер имея Ñ,реÑ,ью обмоÑ,ку, и переменно меняемое поля мощного Ñ,,ерриÑ,ового магниÑ,а в эÑ,ой самой Ñ,реÑ,ьей обмоÑ,ке мы получаем переменный Ñ,ок, Ñ,ипа просÑ,ого меÑ...анического генераÑ,ора, Ñ,олько Ñ,ам перемена магниÑ,ного поля происÑ...одиÑ, меÑ...аническим перемещением магниÑ,ов. и еще. повернув све домены мы имеем магниÑ, с максимальным магниÑ,ным полем превосÑ...одящее энергию на зÑ,раÑ,Ñ‹ по управлению доменами.
1) ПарамеÑ,рический резонанс
2) ЭлекÑ,рическая дуга
3) Многие думаюÑ,, чÑ,о невозможен выÑ...од часÑ,оÑ,Ñ‹ 50Ð"ц с вÑ,оричной обмоÑ,киÑ,рансÑ,,ормаÑ,ора усÑ,ановки Тариэля (в дальнейшем УТ) и эÑ,о Ñ,оже в корне неправильно! Хочу сказаÑ,ÑŒ, чÑ,о для Ñ,,ормирования синусоиды используюÑ,ся мощныебиполярные Ñ,ранзисÑ,оры PNP и NPN проводимосÑ,и, каждый на свою полуволну,а как эÑ,о рабоÑ,аеÑ, с Ñ,рансÑ,,ормаÑ,ором пока не буду говориÑ,ÑŒ.
4) Хочу сказаÑ,ÑŒ, чÑ,о 80% принципа усÑ,ановки видно в видео 100кÐ'Ñ, усÑ,ановки,чÑ,о нам мешаеÑ, поняÑ,ÑŒ?
эÑ,оÑ, генераÑ,ор на 50 Ð"ц преобразоваÑ,елем рабоÑ,аеÑ, с 12 Ð'ольÑ, в 220 Ð'ольÑ, 50 Ð"ц
А искра Ñ,уÑ, нужна, она для ввода Ñ,,ерриÑ,а в резонанс
Наконец-Ñ,о я нашÑ'л секреÑ, усÑ,ановки Капанадзе. Ð"оброÑ,носÑ,ÑŒ Ñ,ого чÑ,о я соорудил, повÑ,оряя зелÑ'ную коробку, не очень Ñ...орошая. Но даже Ñ,акая доброÑ,носÑ,ÑŒ даÑ'Ñ, выжаÑ,ÑŒ из усÑ,ановки 2.5 киловаÑ,Ñ,а. ЧÑ,о Ñ...ваÑ,аеÑ, и на лампы и на Ñ,елевизор и на выпрямиÑ,ель для самозапиÑ,ки. Рук моиÑ... не Ñ...ваÑ,аеÑ, чÑ,обы сделаÑ,ÑŒ доброÑ,ную каÑ,ушку Теслы из 2.5мм провода.
ОбраÑ,ный биÑ,,иляр рулиÑ,. Ð"енерация не срываеÑ,ся на качер.
ФериÑ,Ñ‹ я Ñ,оже не клеил. Я понял чÑ,о клей создаÑ'Ñ, зазор вредный в нашем деле.
Ð'оÑ, важная инÑ,,ормация!
Первые каÑ,ушки элекÑ,ромагниÑ,а для генерации магниÑ,ного поля, по крайней мере 0,5 Т. Ð'Ñ,орая каÑ,ушка - каÑ,ушка высокой часÑ,оÑ,Ñ‹ (часÑ,оÑ,а 21 МÐ"ц), ТреÑ,ья и чеÑ,верÑ,ая каÑ,ушки низкой часÑ,оÑ,Ñ‹, оно сосÑ,авляеÑ, оÑ, 45 до 55 Ð"ц.ТреÑ,ья и чеÑ,верÑ,ая каÑ,ушки могуÑ, быÑ,ÑŒ объединены в одну, или эÑ,о можеÑ, быÑ,ÑŒ связано с производсÑ,вом парамеÑ,ры необÑ...одимого количесÑ,ва каÑ,ушек увеличено.
КаÑ,ушки выбраны Ñ,ак, чÑ,о первая дейсÑ,вуеÑ, как каÑ,ушка элекÑ,ромагниÑ,а, создавая необÑ...одимое магниÑ,ное поле, вÑ,орая каÑ,ушка эÑ,о еще один исÑ,очник энергии, вызывая колебания базовой сосÑ,авляющей магниÑ,ного резонанса, а Ñ,реÑ,ий и, возможно, другими возбудиÑ,елями являюÑ,ся каÑ,ушки синусоидальной волны ...
ПросÑ,о оказалось, чÑ,о девайс SR и Капанадзе с Ñ,,ерриÑ,овыми кольцами даюÑ, максимальное скалярное поле. Не мудрено было и индикаÑ,ору сгореÑ,ÑŒ. На видео в Турции явно видны Ñ,орчащие сверÑ...у Ñ,,ерриÑ,овые кольца. Ð'сем извесÑ,ны направления силовыÑ... магниÑ,ныÑ... линий Ñ,ора - они образуюÑ, конценÑ,рированный векÑ,ор в ценÑ,ре. А лучше всего впиÑ,ываеÑ, скаляр - чÑ,о? Правильно!, каÑ,ушка, не имеющая собсÑ,венного скалярного векÑ,ора. Под эÑ,у каÑ,егорию оÑ,носиÑ,ся Ñ,олько одна каÑ,ушка - плоская Тесла. Не обязаÑ,ельно биÑ,,илярная. ЧÑ,о с успеÑ...ом мной было Ñ,олько чÑ,о испыÑ,ано и проверено. Между каждым Ñ,,ерриÑ,овым кольцом вкладываем плоскую каÑ,ушку. ЗаÑ,ем расключаем эÑ,и каÑ,ушошки по приросÑ,у напряжения. Сразу скажу, Ñ,ок просÑ,о красивый!!! ПракÑ,ически не влияеÑ, на поÑ,ребление оÑ, исÑ,очника. Пока намоÑ,ал Ñ,ри сÑ,упени - Ñ,ок и напряжение расÑ,Ñ'Ñ,! На поÑ,реблении сказываеÑ,ся Ð' ОÐ'РАТНУЮ СТОРОНУ!
PS: СчиÑ,аю, чÑ,о усÑ,ройсÑ,во Капанадзе полносÑ,ью раскрыÑ,о!
ОсÑ,алось сисÑ,емаÑ,изироваÑ,ÑŒ Ñ,еорию, некоÑ,орые неувязки и Ñ,еÑ...нические вопросы выясниÑ,ÑŒ. А Ñ,ак - в принципе Ð"ОТОÐ'О!
ОбращайÑ,есь кому надо, или чÑ,о-Ñ,о не поняÑ,но.
Ð"а, огромное спасибо Олегу_68, ТираÑ,,у, ОТÐ' (за ссылку на Ñ,,ильм Николаева)и многим другим друзьям и сораÑ,никам...
ЭÑ,о Ñ,о, чÑ,о наÑ...одиÑ,ся в Ñ,ени сÑ,аÑ,уи, чÑ,о нам на видео никогда не показывали, эÑ,о и есÑ,ÑŒ главный секреÑ, Капанадзе. И его слова (...вÑ,оричная каÑ,ушка. Ð'оÑ, здесь принцип как и у Тесла Ñ,оже....)
Я просÑ,о моÑ,ал - клеил виÑ,ки на карÑ,онные шайбы по спирали, поÑ,ом соединяем последоваÑ,ельно - начало-конец. Но оÑ,версÑ,ия в ценÑ,ре шайбочек надо сÑ,авляÑ,ÑŒ, чÑ,обы просунуÑ,ÑŒ виÑ,ки для предвариÑ,ельной коммуÑ,ации снаружи усÑ,ановки.
Ð"ля поклонников Ð'ровина!
Ð' качерном поле эÑ,,Ñ,,екÑ,ивносÑ,ÑŒ выше проценÑ,ов на 30-40!
Сейчас думаю по Ñ,еме модуляции.
Заземление необÑ...одимо, берÑ'м с верниÑ... колец. Оно играеÑ, роль "направления скалярного поля".
Просьба, не пишиÑ,е в личку! ЗадавайÑ,е вопросы публично. ЭÑ,о не Ñ,айна, эÑ,о свободная энергия.
Ð"а, съÑ'м с плоскиÑ... каÑ,ушек....
=m11=
Провел небольшой опыÑ, намоÑ,ал на Ñ,,ерриÑ, индукÑ,ор во всю длину поверÑ... 2 одинаковые каÑ,уÑ...и получились по 2 слоя каждая,одну на одну.На одну верÑ...нюю подал синус 50Ð"ц оÑ, генераÑ,ора на нижнюю лампочку на 6 Ð' 0.3А, подал вв порегулировал разрядник и лампочка загорелась.Если чÑ,о Ñ,о одно неподаÑ,ÑŒ синус или вв на выÑ...оде 0.Если в максимуме свечения поднесÑ,и магниÑ, к обмоÑ,ке Ñ,о он вибрируеÑ, с часÑ,оÑ,ой синуса если вв оÑ,ключиÑ,ÑŒ вибрация пропадаеÑ, и лампочка гаснеÑ,.Ð'ообщем Ñ,ема рабочая, SR поÑ...оже правду говорил.
СÑ,ержень короÑ,кий анÑ,ены на всю длину индукÑ,ор обмоÑ,очным проводом 0.8 поÑ,ом изоленÑ,а поÑ,ом одна обмоÑ,ка над ней вÑ,орая на нижнюю синус к верÑ...ней лампочка, на индукÑ,ор вв оÑ, сÑ,рочника, генераÑ,ор синуса слабый на микруÑ...е унч пиÑ,ание 5в.Задача была просÑ,о провериÑ,ÑŒ Ñ,еорию SR.
ЭÑ,о все мы наблюдали в магниÑ,оÑ,,онаÑ.... ОÑ,ключиÑ,е подмагничивание и попробуйÑ,е записаÑ,ÑŒ звук на ленÑ,у, ничего не выйдеÑ,, подключаеÑ,е подмагничивание уровень записи увеличиваеÑ,ся и при воспроизведении слышиÑ,е прекрасный звук, а без подмагничивания почÑ,и ничего не пишеÑ,ся.
Провел эксперименÑ,, положил Ñ,,ерриÑ,овый сÑ,ержень в качерное поле обычной Ñ,еслы, и подал на него импульс с ТÐ'С (блокинг генераÑ,ор). Так Ñ,,ерриÑ, подпрыгнул к оÑ,верÑ,ке, коÑ,орую поднес сверÑ...у, как будÑ,о эÑ,о неодимовый магниÑ, был. НамагниченносÑ,ÑŒ Ñ,,ерриÑ,а осÑ,алась.
При эÑ,ом на разряднике искра сÑ,ала пробиваÑ,ÑŒ безшумно, изменилось ее качесÑ,во - Ñ,акое впечаÑ,ление чÑ,о сÑ,ала "мягче".
сÑ,ержневой Ñ,,ерриÑ, превращаеÑ,ся в посÑ,оянный магниÑ, очень легко: подносишь к Ñ,орцу магниÑ,ик и подаÑ'шь на намоÑ,анную на сердечник каÑ,ушку(150 виÑ,ков ПЭЛ-0.35) Ð'Ð' импульсы (импульс). ОсÑ,аÑ,очная намагниченносÑ,ÑŒ явная: чувсÑ,виÑ,ельно приÑ,ягиваеÑ, оÑ,вÑ'Ñ€Ñ,ку (ну.не неодим, конечно, но Ñ,ем не менее) СоÑ...раняеÑ,ся долго-через двое суÑ,ок проверял-есÑ,ÑŒ.Намагниченный Ñ,аким образом Ñ,,ерриÑ, можно вернуÑ,ÑŒ в исÑ...одное сосÑ,ояние (размагниÑ,иÑ,ÑŒ), подав опяÑ,ÑŒ Ð'Ð' импульс на обмоÑ,ку уже не поднося посÑ,оянный магниÑ,ик, или сделаÑ,ÑŒ ему переполюсовку поднеся другой сÑ,ороной. ЭÑ,о проверено лично,пракÑ,ически,неоднокраÑ,но
авÑ,огена своей обмоÑ,кой намагничеваеÑ, в нужном направлений Ñ,,ерриÑ, - а Ñ,уÑ, разрядник ТРЯСЬ в индукÑ,ор (с правильным направлением ессно) - и Ñ,,ерриÑ, ХРЕНАСЬ и сÑ,ал магниÑ,ом S-N ..... а Ñ,уÑ, авÑ,огена погнала импульс в другую сÑ,орону - и Ñ,уÑ, разрядник ТРЯСЬ в индюкÑ,ор ..и перемагниÑ,ился МАÐ"НИТИК на N-S ..и Ñ,ак оно циклически smile (разрядов не будеÑ, видно, будеÑ, Ñ,иÑ...ая Ð"УÐ"А..ну Ñ,ак оно на вид выглядиÑ,) ..
