0 Members and 201 Guests are viewing this topic.
Macmep_L
Hello.
It is technical forum, please publish technical details about device of T.Kapanadze.
FreeEnergyInfo
forest
FreeEnergyInfo posted very valuable info in russian which need to be read by everybody.
MasterPlaster
Translation ( curtecy of Bablefish!:
the http://www.realstrannik.ru/forum/39-kapanadze/102-analiz-replikaczii-ustanovki-tarielya-kapanadze.html?limit=18&start=3798#27917
this has already been was discussed and I did pass, or all - is the news?
=SR=
Core is collected (it is glued and wound [izolentoy]) from the ferrite rings, three windings,
- to one comes high through the discharger;
- The second with the midpoint is fed through to gene 50 Hz;
- the third detachable;
Earth [vitukhoy] through the hollow core for the load (lamp), to the coil of output…
1. Core is collected from the ferrite rings.
2. Rings are glued. Ferromagnetic tube came out…
3. On top layer insulating tapes, understandably for which?.
4. Is then wound coil which it enters high voltage, the order of 2[KV] - 5[KV], through the discharger. A quantity of turns was not considered.
5. The second end of the coil to the earth, the earth is passed through the hollow core on the rings and departs to the battery of heating (GROUNDING!!!) … Mad Of mad
6. On top to the coil with VV it is wound insulating tape, then two half windings (16 turns like), on which work two transistors on the radiators (12[V] X of 50 Hz and current decent judging by the cooling), multivibrator there or that ??? . Half-bridge is faster…
7. High is obtained with the aid of still one transistor, it is established from the side the installation on the radiator, author, speaks about than.
This most likely blocking with VV by trance.
8. Third, this is coil of output, it is loaded with lamp and transformer 20 W.
9. Through [tans] and rectifier with the filter is formed the ring of [samozapitki] of [devaysa]…
Well, and trigger circuit with storage [konderami] and buttons…
1. No. The resonance of oscillatory circuit there is not used and load is not part it.
2. 50[Gts] is formed with simple method to the resonance it has no relation. There is no oscillatory circuit there.
I recommend by all to reject from the head phrase “the resonance of oscillatory circuit”. Word resonance makes another sense in the installation.
Apropos commercial frequency, in the device this [Kapanadze] is done elementarily and is less expensive than with the use of an inverter. That is more the process of the forming of 50[Gts] this one of the crucial points, which combine in themselves 2 functions: The forming of the sinusoid (not single-pole pulses, namely sinusoid), whose frequency can easily be regulated and the more important function, about which I will not mention. Naturally are present interferences [vnosimye] by second field, which sometimes influences readings of instruments, the part of these interferences is removed by grounding the general output of transformer.
I want to focus attention, that from “the coils” is removed the stress on the straight line, without what or converters, the frequency of 50[Gts]. Any connection of load, even through the arc would not make it possible to attain this, you be there resonant circuit.
Threshold not in the stress, but in the ability to create THE HF field, which stimulates “ferromagnetic material”.
for the forming of sinusoid are used powerful bipolar transistors PNP and NPN of conductivity, each to their half-wave
domains this is magnets. priests into the resonance with [chastatoy] from the spark, domains are ready to fulfill another function, to [toest] it is turned where them they will order, and orders them then variable [megnitnoe] field with current 50 hertz. in principle that the frequency can be for example even 400 hertz.
I want to refine several moments:
1) [Kapanadze] in its first video tells clean truth, only, its concepts and your can disperse, NR: the same resonance.
2) [Kapanadze] correct made that was derived the discharger on “the street” (outside the box), since if discharge does not catch fire, then focus will not succeed; therefore it for the elongation of entire film worried about spark.
3) In the installation two effects are used, only in the complex they give result. Arc has wide spectrum, several of these frequencies are resonance for “the ferromagnetic material”, that also causes the processes specific in it. Field appears. But field this “corpse” and work accomplish cannot; therefore the second process is connected. In the sum these two processes serve for obtaining the excess energy from the ferromagnetic material and this energy is not taken from air.
And still: Ferromagnetic material can be represented as the material, where there are very many small magnets, which in the form of Hausa [napravlenny] to the different sides and cannot create the resulting field. The first process makes possible for them to be weakened, the second to be turned so that all these small magnets created the resulting field moreover powerful. If we say simply, then powerful magnet with the possibility to govern it is created. Well, and is further the matter of classical physics.
[odi] from the processes, this from the very beginning forming of spark, for this is necessary high voltage. after attaining spark, in the spark we already have wide frequency spectrum, you will recall, [admin] speaks spark it generates, and spectrum we this entire send to the coil, and one or as said [admin] several frequencies they have a resonance with the structural substance in the ferromagnetic material and this substance we force to resound, with the aid of the weak electromagnetic field of that created by the coil, through which is passed entire frequency spectrum from the spark. I call this substance of blast furnaces. from the descriptions of Melnichenko. when domain is located under the action of resonance, we can easily turn it to any side, and this of the already second of [prtsess], in this case let us spend entirely small current. after turning domains we from the ferromagnetic material we make usual magnet, in this case usual ferrite magnet. changing direction of flow, we change the polarity of magnet. here we use for a polarity reversal of magnet 50 hertz, and that very importantly this must be sine, since only alternating magnetic field can create current in the conductor. and therefore we have no longer simply ferromagnetic core which it works in usual [usloviyak] only at the high frequency, but they are ferrite the magnet, whose polarity mA we can change with [chastatoy] what to us it is necessary. for example, if we with the work of spark on the second winding give direct current, then we from the ferromagnetic material will obtain permanent magnet, and it will preserve its action thus far we by [neotklyuchim] current. which would be desirable to note, in the simple case is intended the run of job of simple transformer, for the fact that to turn domains we should use very high current, since domains [soprotivlyutsya] and want [vernutsyav] initial position. and hf from the spark makes domain obedient and it ceases they [soprotivlyatsya], and it [nestremitsya] they will be developed into the initial state, and it is obediently turned there, where to us it is must, in this case we spend considerably less than the current than with the normal conditions of transformer. and [teper] having third winding, and alternately changed of the field of powerful ferrite magnet in this very third winding we obtain alternating current, the type of simple mechanical generator, only there change in the magnetic field occurs by the mechanical displacement of magnets. and still. after turning [sve] domains we we have a magnet with the maximum magnetic field exceeding energy to [ztraty] on control of domains.
1) Parametric resonance
2) The electric arc
3) Many think that is impossible the output of the frequency of 50[Gts] from second [obmotkitransformatora] of the installation Of [tarielya] (in further [UT]) and this also in the root is incorrect! I want to say that for the forming of sinusoid are used [moshchnyebipolyarnye] transistors PNP and NPN of conductivity, each to their half-wave, but as this works with transformer will not thus far speak.
4) I do want to say, that 80% of principle of installation it is evident in video of 100[kVt] of installation which us does prevent from understanding?
this generator of 50 Hz works by converter from 12 volts in 220 volts of 50 Hz
But spark is here necessary, it for the introduction of ferrite into the resonance
At long last I found the secret of installation To [kapanadze]. The quality of the fact that I built, repeating green box, not very good. But even this quality of [daet] to squeeze out of the installation 2.5 kilowatts. Which is sufficient to the lamps to the television set and to the rectifier for [samozapitki]. The hands of my are not sufficient not in order to make a high-quality coil Of [tesly] from 2.5[mm] of wire.
Opposite bifilar taxis. Generation is not torn away to [kacher].
[Ferity] I did not also glue. I understood that glue of [sozdaet] clearance harmful in our matter.
Here is important information!
The first magnet coils for the generation of magnetic field, at least 0,5 [T]. [Vtoraya] coil - high-frequency coil (frequency of 21 MHz), the third and fourth coils of low frequency, it is from 45 to 55 [Gts].[Tretya] and the fourth coils can be united into one, or this can be connected with the production the parameters of the necessary quantity of coils increased.
Coils are selected so that the first it acts as magnet coil, creating the necessary magnetic field, the second coil this one additional energy source, causing the fluctuations of base component of magnetic resonance, and the third and, possibly, other agents they are the coil of sine wave…
Simply it turned out that [devays] SR To [kapanadze] with the ferrite rings give maximum scalar field. It was not ingenious and to indicator to burn. On video in Turkey are clearly visible [torchashchie] from above ferrite rings. The directions of power unit magnetic flux of torus are known to all - they form the concentrated vector in the center. But best anything does absorb scalar - that? It is correct! , the coil, which does not have its own scalar vector. Under this category relates only one coil - flat Tesla. It is not compulsory bifilar. Which successfully by me was recently tested and checked. Between each ferrite ring we pack pancake coil. Then [rasklyuchaem] these [katushoshki] on increase in the stress. I will immediately say, current simply beautiful!!! In practice it does not influence consumption from the source. It thus far wound three steps - current and the stress of [rastet]! Consumption it affects TO THE REVERSE SIDE!
PS: I consider that the device To [kapanadze] is completely opened!
It remained to systematize theory, some discrepancy and technical questions to explain. But so - in principle IT IS PREPARED!
Be turned to whom must, or something is not understandable.
Yes, the enormous thanks Of [olegu]_68, To [tirafu], [OTV] (for the reference to the film of Nikolayev) and to many other friends and to companions-in-arms…
This that which is located in the shadow of statue that to us on video never they showed, this is a main secret To [kapanadze]. And its word (… second coil. Here here principle as in Tesla also….)
I simply twisted - it glued turns to the pasteboard washers on the spiral, we then connect in series - beginning- end. But opening in the center of [shaybochek] it is necessary to [stavlyat] in order to push through turns for the preliminary commutation outside the installation.
For the worshippers Of [brovina]!
In the [kachernom] field the effectiveness is higher than the percentages by 30-40!
Now I think on the theme of modulation.
Grounding is necessary, [berem] from the [vernikh] rings. It plays the role “of the direction of scalar field”.
Request, do not write in [lichku]! Pose questions publicly. This is not secret, this is free energy.
Yes, output from pancake coils….
=m11=
Was conducted small test it wound for ferrite inductor full length above 2 identical [katukhi] they came out on 2 layers each, one to [odnu].[Na] one upper gave the sine of 50[Gts] from the generator of lower lamp to 6 [v] of 0.3[A], gave the substances of [poreguliroval] discharger and the lamp of [zagorelas].[Esli] that the one to [nepodat] sine or substances at the output of 0.[Esli] in the maximum of glow to present magnet to the winding that it vibrates with the frequency of sine if we substances open vibration it disappears and lamp [gasnet].[Voobshchem] theme worker, SR similarly truth he spoke.
Rod short of [anteny] to entire length inductor winding wire 0.8 then insulating tape the then one winding above it the second to the lower sine to the upper lamp, to the inductor of substances from [strochnika], the generator of sine weak on [mikrukhe] UNCh the nourishment of 5[v].[Zadacha] was simple to verify theory SR.
This we all observed in the tape recorders. You will open magnetization and try to write down sound on tape, nothing it will leave, you connect magnetization recording level it increases also during the reproduction you hear excellent sound, and almost nothing it is written without the magnetization.
It conducted experiment, placed ferrite into the [kachernoe] field of usual [tesly], and gave to it pulse with [TVS] (blocking generator). So ferrite jumped to the screwdriver, which presented on top, as if this the neodymium magnet was. The magnetization of ferrite remained.
In this case on the discharger the spark began to break through noiselessly, changed its quality - this impression that it became “soft”.
pivotal ferrite is converted into the permanent magnet very easily: you will bring to the end magnet and you [podaesh] on the wound around the core coil (150 turns [PEL]-0.35) VV pulses (pulse). Remanence is explicit: it sensitively attracts screwdriver ([nu].[ne] neodymium, of course, but nevertheless) remains for long- through two days checked -[est].[Namagnichennyy] thus ferrite it is possible to return to the initial state (to demagnetize), after giving again by VV pulse on the winding no longer of [podnosya] a constant magnet, or to make to it reversal of polarity after presenting by the other side. This is checked personally, practically, repeatedly
autogen by its winding [namagnichevaet] in the necessary of directions ferrite - and here discharger [TRYAS] into inductor (with the right direction [essno]) - and ferrite OF HORSERADISH and became magnet SN ..... and here autogen it chased pulse to the other side - and here discharger [TRYAS] into [indyuktor]. . was reversed magnetism MAGNET on N- S. . so it cyclically smile (discharges it will not be evidently, it will be quiet ARC. to.[nu] so it to the form it appears):.
