0 Members and 81 Guests are viewing this topic.
T-1000
Quote from: FreeEnergyInfo on September 21, 2011, 10:42:27 AM
DELAMORTO COIL....
http://www.youtube.com/watch?v=XnfnxI0LQvw
http://www.youtube.com/watch?v=Vb9fDMC22FA - here is origin of this post. Romanov explained everything in that video, you can replicate it easily. Needs translation to English from Russian.
dllabarre
He (Tesla) matched the total weight of the primary and secondary windings so the two would be in a state of resonance.
So if I take it one step further and factor in 1/4 wave length I have:
6 awg 79.65 lbs/1000 feet
12 awg 19.8 lbs/1000 feet
If I use 12 awg for secondary at 4 times length of primary = 19.8 x 4 = 79.2 lbs
The total weight is the same and I create a 1/4 wave length effect.
All in resonance.
Comments anyone?
DonL
T-1000
Quote from: dllabarre on September 21, 2011, 11:10:50 AM
All in resonance.
As it was been said by Tesla - wire diameter does not mater, the mass matters. Also for primary it -must be- lowest impedance coil as possible - that's why Tesla coils have primary made as pancace bifiler coil made from tube.
Also, the diameter of secondary affects voltage/current so wider wire you put, less voltage/more current you should get (theorically) because primary acts as high pressure pump and secondary as collector tank.
Tesla was always saying about aether/electricity effects to be same as pressurized gas effects. So same physics laws there. With gas if you put high pressure over small valve into high capacity tank, it dissipates energy and cools down. Look on how fridges work :)
P.S. forgot to mention - with HV capacitor discharge you create that high power(pressure) because capacitor discharges -entire- amount of stored energy over shortest period of time. This creates high energy spike what's been utilized in Tesla coils. And to charge capacitor you need highest frequency low current HV as possible so capacitor gets enough of timeframe for next discharge period. The spark gap acts as valve for timeframe when certain voltage (pressure) on capacitor is collected.
scratchrobot
Quote from: dllabarre on September 21, 2011, 10:16:23 AM
"The primary and secondary coils masses must be equivelent for electrostatic resonanse (Tesla's rule)"
Masses meaning physical weight?
Like for primary 1 lb of 12 awg and for secondary 1 lb of 22 awg?
DonL
Yes, maybe suface area is also important?
dllabarre
Quote from: T-1000 on September 21, 2011, 11:31:35 AM
Good point.
Thank you
