0 Members and 70 Guests are viewing this topic.
dole
I will, give me some time; I use to progress very slowly.
I've got good relation with one very kind person so I hope to combine little bit,
Ehhh, if this could work out somehow to be through….
I do not believe in the MIB an all that BS like “You cannot imagine what I was going through …”
Word for certain will not be the same, it can`t no longer, but who knows,
I was wrong 1mil times and it could be just another BS.
d.
stivep
Quote from: FreeEnergyInfo on October 11, 2011, 04:06:15 PM
FREE ENERGY !!!!!!!!!! ????????????
http://zaryad.com/forum/viewtopic.php?f=51&t=880
TRANZISTOR ....
http://www.155la3.ru/p411a.htm
http://freeenergylt.narod2.ru/kapanadze_2/
sorry guys.. I have problem with this schematic
take approximate length of the coil and  diameter of the coil
than go to
http://www.daycounter.com/Calculators/Air-Core-Inductor-Calculator.phtml
d (coil diameter in inches)3    (inches)
l (coil length in inches)   8 (inches)
n (number of turns) 25
L (Inductance)15.04011    (uH)
than go to
http://www.daycounter.com/Calculators/LC-Resonance-Calculator.phtml
Frequency:   (MHz)
Capacitance: 450    (pF)
Inductance:15.04011    (nH)
=61.2 MHz.
Frequency:   (MHz)  184 MHz
Capacitance:    50 (pF)
And because capacitor is in approximate  60% of its  capacitance
than:
Frequency:   (MHz)  91.9 MHz
Capacitance:    200(pF)
Lower resonance frequency  of LC circuit = 61.2 MHz
High resonance frequency of LC circuit =184 MHz
approximate frequency of LC=91.9 MHz
So the LC coil is in the FM radio frequency range !!!!!!!!!!!!!!!!!!!!!!!!
or to say local radio transmitter range for  traditional  FM broadcasting
Sorry ZARYAD group of MOSKOW nice trick.if it is a trick.
Do I deny it?
NO  I Do not........
there are two possibilities  that:
-it is  a HOAX?
or
-it is not HOAX
Till is proven otherwise.
Can I be mistaken? Yes I can.. time   will prove.. :)
Wesley
PS: for those  who are not familiar with FM modulation :It is a constant carrier.
say for just example:  Constantinople, 150 kV in Roumoules)
For most large stations in the VHF- and UHF-range, the transmitter power is no more than 20% of the ERP. so add effective 6-15Db for antenna gain and you will get enormous power signal level.
Every 3 Db of gain of antenna double the power
Example of  one of transmitters:
http://www.nautel.com/expectmore/pdfs/Nautel_NV40_web.pdf
  SP E C S N V 4 0
Analog FM Only
AC Input 50/60 Hz
Max power (kW)44
Moscow:Ostankino tower:
just oft one channel of TV
In 1997 for TV programme MTV - Ch. 38 transmitter 20 kW
.......... talking about FM at all........... just look at calculation
take  given output power and add gain of antenna in "db"
Effective Radiated Power (ERP)
http://www.csgnetwork.com/antennaecalc.html
please put in that table  for example 20 KW
than you will get 48 549.65543 W     ERP
FreeEnergyInfo
