0 Members and 178 Guests are viewing this topic.
mikhail
mikhail
FILEs 1
              Method and means of removing freebie.
                                        I beg your pardon, gentlemen, for the frequent use of the word
                                        "Freebie", but, by God, such a capacious synonymous with this definition
                                         until I find.
Introduction.
                     This work is based on the ideas of Andrei Melnichenko, made in his
                     correspondence.
What freebie will take?
Before you understand where to shoot a freebie, let us first briefly repeat and one-off "the studied material.
Repeat.
Andrei Melnichenko method is very simple and is as follows.
               If you create the conditions for common-mode of addition of the amplitudes of the vibrational
               process, the addition of the amplitudes will occur linearly.
               In this linear addition to a linear increase in the amount expended
               capacity of each individual in the fluctuation, and the resulting
               the resulting output will be equal to the square of the sum of the amplitudes
               fluctuations.
For example: if we put 10 on the amplitudes of 1 volt, a power of 1 W, we obtain
                     10 V and the costs of all this is 10 watts.
And if in this case does not "slam the ears", and "shlopnut" all these 10 Volt, remove halyavushku for 10 in a square, that is 100Vatt!
                     Spend 10 - got 100!
                     Spend 100 - got 10 000!
                     Spent 10 000 - received 100 000 000!
                     And so on.
But before you get a freebie must understand, what is and what is its first fold.
Moreover, this problem will haunt us always and everywhere, not only in the initial process of obtaining CE quantum of power, but to somehow remove and dispose of.
As just a definition as "Quantum freebies", it is not for a nice phrase, but it is in fact so everything applies:
in production is a quantum principle of freebies!
If we consider the resonances (resonance - a result created the conditions for common-mode folding of the amplitudes of oscillation), resonance LC circuits, the freebie may postpone or on containers, or on the inductance.
Time out for a complete freebie determined "Interim quantum pumping freebies", whose value consists of a period of time determined by the quality factor
system and the frequency of the original pump, which coincides necessarily the case with a resonant frequency circuit.
In considering the LC circuits Q-factor system - a quality factor of the contour.
This is an indicator of the Interim quantum pumping freebies, saying to us that after some time the system will go into saturation, in this case in response to then continue to take "ripe" Khalyavko.
If we remove the energy before this time, then anything short of, if later - then lose the time during which a given system would be to build the next portion of freebies.
If we drive the EM waves in a line or coax and create the conditions where the standing wave, as a result of addition of common-mode amplitudes, then the freebie will emerge there: in the line or coaxial cable.
If there are conditions for the formation of voltage amplitudes, we obtain the stress response.
If there are conditions for the formation of the current amplitude, the resonance current.
Adds the amplitude of charges - charges resonance.
If you add up the mechanical vibrations in the ultrasonic path - the acoustic-mechanical resonance.
Adds amplitude stools - stools resonance and so on.
But in any case receive the CE capacity and energy will be quantized, in portions, - rent, these portions should be immediately after reaching the maximum amount of amplitude fluctuation, defined quality factor of the system.
Unfortunately, it is a fact that each of the system has a "ceiling" for accumulating freebies, determined solely by its intrinsic portion of the pump - the quantum.
So freebie can be removed from any system that provides common-mode amplitudes and the addition of possessing good quality.
If we consider the LC circuit, the capacitance of the system is not only a capacitor C, and Q-factor and the contour, allowing for the same capacity with the usual amplitudki that will define their sum as a "quantum freebies.
Quanta freebies.
1. Interim quantum pumping freebies.
Consider the entrance to the resonance of the resonant system, which is a serial oscillatory circuit LC, excited by an external generator frequency, the frequency of which coincides with the frequency of the contour.
Connection diagram circuit looks like Figure 1.
                                                               Fig.1
      Curves of growth stress on the tank look as Fig.2.
        Fig.2
When you turn the key S and entering the path in response to the tank circuit begins to take shape amplitudki pumped by the generator G.
Them to lay down just enough, which is equal to the contour of Q Q.
The final addition will occur over time equal to or TQ Q \ F, where T and F and the period of the oscillation frequency of the pump and the resonant frequency of the contour, respectively.
This is a specific value of each resonant system in isolation, constant and for different systems entirely his own, different.
Consider it.
                                                     Ap = TQ; Ap = Q \ F
And if you say in other words, the Transitional quantum - this time the transition process of entering the resonance system in the beginning of the final resonance.
Of course, we would like to Transitional quantum as small as possible, that is, in short.
But here we are confronted with a certain paradox in the fact that the higher the quality factor of the path, which ultimately is the guarantee of a higher denomination of freebies, the system becomes more inertial.
To lower it, inertia, you can only rate the pump, as high as possible improving it.
That is why Andrei Melnichenko prefers LC contour lines or waveguides, which can create conditions for resonances.
A Kushelev generally "useful" with their crystals in the optical range, Viktor Stepanovich Grebennikov flew on its platform almost at the x-ray ...
However digress.
What can be noted above.
mikhail
file 2
for there can be noted above.
And the main thing is that after the expiration of time of a quantum system, the amplitude of the fluctuations of the resonance reaches its maximum, you can safely remove a freebie, do not arrive and wait is futile.
How?
How to do it in a principled and detail, so be it, partly discussed below, but not yet moving away from theory.
I personally know of two ways.
The first way - cyclical.
When the amplitude to the maximum interrupt response downloading "on the side" of the portion Khalyavko, which managed to obtain and, in our case, dispose of the charge capacity.
The second method - continuous.
A continuous method for the removal of freebies - it aerobatics to the first cyclic, a bit unusual, which is based on the transformation time as seen here until it prematurely, let's at least "vedem in the first, the cyclic.
I'm not scolding over the fog of mystery, just a few things to be considered here, represent commercial interests, and agree, simply because everything is here to negotiate, it would be, at least, stupid.
Therefore, the essence of the first, the cyclic method is to allow time for the pumping of the resonant system to its saturation, to suspend the process of discharging Ñ...алявной energy, then re-start the process of entering the resonance, again to merge, without giving him a resonance, even set, and so on the cycles.
Structurally, it can be solved through the device threshold voltage, the same dynistor who simultaneously to freebie has not passed through the same generator G, to disable the key S.
It looks like this, Fig.3.
        Fig.3
Naturally, we are profitable to those switching occurred as often as possible in time, in this case, the light bulb as the load per se, will merge more energy, ie power per unit of time.
That is why we are interested in the fact that the resonance system was as short as possible a Provisional quantum, and that is why we are interested in the process of discharging freebie was just as short as possible.
2. Cardinality Ñ...алявной quantum pumping power.
When reaching the maximum amplitude of the resonant oscillation, the resonant system achieved a "ceiling" of the pumping capacity of the master oscillator G.
More power to accumulate will not be reaching a certain portion will "hang" at the resonant frequency of the system, fueling a little bit of energy from the master clock running on the system losses.
Therefore, if we decided to "shlopnut" that ultimate of their increase in the amplitude, then at the same time we can get only a portion of power proportional to the square of this amplitude.
                            Here lies freebie!
We call this portion of power more than a simple name like "Quantum Ñ...алявной power" not to repeat such a long title of this paragraph.
How it happens?
Enjoying Fig.4.
        Fig.4
To discuss in detail the schedule with a minimum of mathematical masturbation, I must employ the concept of energy, not power.
The fact that the painted area is characterized by half-value of energy, not capacity, because that energy - it is the power at the time.
But I draw your attention to the fact that the temporal duration of each shaded area is the same, the growth of energy is in a temporary move, as the same frequency master oscillator and the resonant frequency circuit. Therefore, if we take the ratio of these energies, we can safely say that this attitude becomes automatic power ratio.
Here on what grounds I employing the notion of such a power.
Pay attention.
Numbers 0 - a power fluctuation, which is issued specifying the generator.
Rooms 1,2,3,4 - is the system's output at resonance for the Interim photon at Q-system, equal to four!
Number 5 - a Quantum Ñ...алявной power gained "doveskom" numbers 0 to each subsequent number - 1,2,3,4.
In principle, a freebie you can start pumping with the first issue, but is it worth throwing the king to bribe preference, when clearly convinced that his partner naked ace.
And now attention, Number century!
At the pump number 5 total power expended
Where to p - coefficient of proportionality, depending on the specific folding
                   amplitudes of the resonance system can be expressed as L \ 2; C \ 2, 1 \ R and
                   others.
             Ug - the amplitude of the fluctuations of the master oscillator.
             Q - Q of the circuit.
A power khaljavnogo quantum based
Now the power ratio.
Just want to know how many Ñ...алявный quantum greater than the sum of quanta generator pumping away at his creation.
What to prove
                                    Exactly Q times!
Amazing!
In other words, if I want to get the full freebie exceeding my expended on its creation of the initial energy of 99 times, I must reach Q resonance system of 100 units!
Question.
And why not round 100 times, but only 99?
Because the round in Nature are only fools; hundredth part I have to return the master oscillator to maintain the process!
         Trutch one part - get a freebie at 99 parts!
That is power!
Just take your breath away!
Lyrics.
I was able to understand and explain the process of getting freebies in the first place and above all - for yourself.
All this happened as a result of intensive work aimed at addressing this issue and not without a "feed" the ideas of Andrei Melnichenko.
And then I have deliberately raised in explaining all this "people" only a parameter called tension.
And all the logical tool to deal with the "spinning" only about the voltage, so on what grounds surfaced sequential circuit LC - as the stress response.
In this case, we remove a freebie with a charged resonance tank.
But at issue is the inductance.
For certain reasons expressed above, I can not touch this topic in earnest.
But I want to throw and "seed in the masses" on the inductance, so the only two words.
Power is removed from the inductor looks like
In this capacity "mixed up" talk, so we need all the logical tool to address the issue of inductance "to hold a current.
Further, it was noted the "ceiling" on the accumulation khaljavnogo quantum capacity, which corresponds to the inductance.
By increasing the nominal value of inductance to improve Quant Ñ...алявной power, we will lower the resonant frequency increases time quantum pumping freebies and seemingly come to a standstill.
But we have a whole subsection of the electromechanical park as electric motors and generators. Here high resonance frequency is not needed, especially if aimed at industry in the 50 Hz.
Thus, both as an adaptation of the transition moment of the transition of society into Ñ...алявную energy, large commercial interest are the various samokrutyaschiesya Freestuff motors and generators.
Very promising direction represents an energy capsule
N. Hulya, who proved that, of all existing energy storage devices - flywheel "in front of the entire planet!
He worked construction and methods of removal flywheel energy with them.
Extraordinarily talented man, but did you go, for his active work on them, flywheels, even thought it could not come to the idea Ñ...алявной pumping energy of the flywheel.
Extraordinarily talented and Tariel Kapanadze.
It is with the filing of its units, including the famous green box, a movement began among the masses of the engineering environment.
But the first was nevertheless Andrei Melnichenko!
And, thank God, that he managed to stake out the idea of freebies international patents, patent Russia as the short - has not paid his grandmother on the extension, take the idea of everyone - do not want to!
I'm surprised our modern Russia - there is no country in the world, which so selflessly itself flikaet.
And before Tariel Kapanadze take off my hat and bow my knees in gratitude for what he did what he did!
Hard work on practical devices in between underworking daily bread, has reached its goal - it all works!
Sadly only one.
All of his patents are sewn with "disguised".
In all of them based on the idea of Andrei Melnichenko.
Tariel patent - Method!
But Andrei Melnichenko - Method!
Catch the difference?
Modalities are many, but one method.
As soon as Andrew hire one or two polutolkovyh of patent attorneys, as they will win the lawsuit to protect copyrights and Tariel, coupled with the Turks, will unfasten nekhilyy grandmother to the author.
Incidentally, it is waiting for every fan Khalyavko, organize production for their release.
But I think that there is a way out of this situation.
If all this is aimed at the needs of mankind, there is no sense of "man" to squabble among themselves.
The fact that the market for these devices - this is our entire planet.
Works and grandmothers have enough for everyone.
Therefore, I would like to advise Andrew: to soothe his "golozho .. S" pride and make commercial contacts with Tariel, share ideas with people - something no risk - copyright law for you - needs to be done so that the "masses" began to work for you! Wasting time!
Authority and attendants enough and authors, and the working masses.
                            No need to repeat the path N. Tesla!
All this should not be secret, as secret in the first work on the weapon, that is, to the war.
If it knows how to make people of one state, it will know how to do the citizens of the second.
Wars will be constrained by the same potential to potential belligerents.
But all of this rat race, compared with what it all opens up for exploration of outer space, protect our planet from the threat of strikes by large cosmic bodies, then that's certainly not to be freebies!, Preserving and increasing habitat - Nature!
It's time to practice their brains and look at old things look different.
This will give just one example of a relative.
In this paper, I began to "pour" about photons, the pump and so others ...
What, Lord, do not remind you of?
Yes! Lasers!
Each laser is a potential green box.
Only those with busy, it never comes: turn of the light beam output at its pre-charged!
This is not a laser efficiency is low.
This low "paravozny" efficiency of its pre-pumping systems
mikhail
file 3
Freestuff nightlight.
As I promised, some consider the principles of electrical circuit for the extraction Khalyavko, for example, design and calculation khaljavnogo lamp.
If the task light bulb filament at 220, then immediately be taken into account the time that the dynamic range of this offspring of Edison is very low.
That is, if it is brightly lit at a voltage of 220V, it is already at a voltage of 150V lights in polnakala.
It would be foolish Ñ...алявную all the energy stored in the capacitor, to pass through the load - a light bulb, thus discharging the capacitor to zero.
Therefore, there is a proposal to nourish the bulb from the buffer capacitor, where we will pour a freebie.
This will allow the food chain bulbs transferred to another temporary move and to nourish its stable discharge pulses, the duration of which may not coincide with the length of time of a quantum pump, provided the same capacity: capacity of a capacitor circuit and the capacitance of the buffer Konder.
Furthermore.
Buffer Konder should be charged with voltage above 220, say, up to 300V, with a further drain the charge to the load through the current limiter to increase the dynamic range of light bulbs.
It looks like Figure 5.
        Fig.5.
Then, if you decide to take a freebie with a capacitor circuit element type dynistor threshold, the charge of the vessel to be increased to 600V, as dynistor off with equal voltages on the Konder, it is necessary for us to 300V, subject to the same nominal capacities, Fig.6 .
        Fig.6.
Now, at face value Sp expect inductance L of the resonant frequency of the contour, we select, or make their own generator, power supply to it.
This looks so Fig.7.
        Fig.7.
I was a little simplified the scheme of calculation that we will not yet turn off the generator during the discharge Sp. There is not going to introduce new supply chain support from the generator output freebies, because it is not problematic.
Connect only the battery with its charging capacitive divider C1 and C2.
In fact, on such a gift, as oily concept, it still does not go.
Again, the main thing to understand from what considerations to the calculation, the rest of practice for each case: to wind the coil, pick Konder and so forth.
Therefore, hold rough calculations that, if I may say, "a course".
Let's start with the load and the Provisional quantum freebies.
These bulbs.
P = 25W
U = 220V
I = 0,1 A
R = 2,2 kOhm
Based on the load current transistor and diode is chosen from considerations of current flow in the 0,2-0,3 A voltage is higher than 300V, with a stock "just in fire.
The value of resistor R to the transistor current limiter
At the rate of 0.75 in his opening over the base.
Now the face value of the buffer capacitor Sat
To remove the flashing lights under the impulse of its power, in our case it is not thick inertia thread kilowatt Banduras like Kapanadze, pulse repetition rate discharge freebies should be above 50Hz.
Therefore, there is no reason to charge for all Sat 25W, but only by at least 25: 50 = 0,5 W, but has the power to 25W light bulb on prointegriruetsya of these portions.
Par Konder Sat from these considerations
20 microfarads is not bad, but still too much. We have an opportunity to reduce its value, a decrease of the Interim quantum freebies.
We go to the issue on the other hand, the outlet side of our circuit at resonance.
Suppose we have "turned onto the wrong side" and reached Q-Q, equal to 100 units.
Here the amplitude of the frequency of the master oscillator should be 600V: 100 = 6V, which suits us perfectly.
Knowing the conditions for reducing the quantum of the Provisional freebies - increased frequency, "tknem finger at the sky" and take the value of the resonance frequency of 10 kHz.
Then Transitional quantum yield system khaljavnogo saturation is equal
Add to it the time spent on overcharge Sp to Sat Let us calculate the travel time of the current recharge through the internal resistance dynistor - they work within to the same 10 kHz, which represents travel time of the
The concentration of energy in such a small time interval is large, can do dynistor knock, so equates times Provisional quantum freebies eventually charge capacitor resistor R2. Its nominal
  Then the time of overcharging bypass capacitors will be equal to the same 0.01 seconds, after which the system will re-enter the resonance. Thus, the preparation and firing "khaljavnogo pulse will be spent 0.02 seconds, which is 50Hz.
Excellent, temporary conversions missed, now on energy.
Free discount the power collected on the condenser Sp, given that he has the same denomination as the capacity Сб, 20 microfarads will be equal
Such discrete bursts of Ñ...алявной capacity in 1 sec will be 50, ie
                                                    3,6 x 50 = 180W.
Given the fact that the capacitor Sp merges only half, then it will
                                        Merge in the same load 180 - 45 = 135Vt.
Not bad, but with a resonant frequency slightly overdone.
We should not have to heat the space surrounding us energy, although Ñ...алявной.
Therefore, these 135Vt must "negotiate" with 25W.
This can be a decrease in Q-loop that we quite at hand, a decrease in the amplitude of the master oscillator, which is also not bad, immediately lowering nominal capacitor, and most importantly - a decrease in resonant frequency, which entails an increase in size inductor - it is bad!
Nevertheless, see: on some crappy original six volts and twenty microfarads capacitance, we climbed a hundred Tues!
That's why Kapanadze was so tenacious green box - it does not measure the freebies!
So the options are many, go for it, gentlemen!
Conclusion continuation.
Everyone has read and entered into these lines immediately ask questions.
Well, well.
It accumulates quantum freebies understandable.
It was withdrawn this freebie with a resonant quantum system - is also understandable.
But whence freebie from?
Is that violates the law of conservation of energy?!
Frankly, gentlemen, these same questions plagued me.
But I have a certain working hypothesis, which consists in the fact that there is "implicated" Time.
And if the Lomonosov viewed energy conservation law with a "linear perspective", then there is a clear "nelineyschina" which "take a look" very problematic!
Roughly speaking, energy can move through time.
But, for God's sake, do not have these primitive type of reasoning that the energy of tomorrow turned into today, but tomorrow it will be no additional бредяÑ,ина ...
Speaking of travel time in a local space, then as, for example, explained that in the same locale can be set oscillating processes without interfering with each other and not interacting with each other?
The same comb frequency spectrum!
But is this Lokal introduce an element of nonlinearity, immediately went to the interaction with the creation of new, in the same locale, oscillatory processes.
    Nonlinear Processes in Nature and portions of energy quanta - the world!
And here I am expressing the same concerns that were expressed not by one party to the Forum.
If the law of conservation of energy remains in force, he is deeply do not care how we Makar hapnuli energy - linear or nonlinear!
Once she came here, then gone somewhere.
But that's where this "somewhere"?
I believe that continued discussion on this subject - is futile, because we do not have elementary of developments on this issue.
Still ahead, and it seems to me, gentlemen, that the basis for this posited.
mikhail
But be warned --- electronic translator can some words do not translate well as it should and not in the sequence :'(
