0 Members and 61 Guests are viewing this topic.
AbbaRue
Quotebulbs hanging among trees DID NOT BLINKED, then second bank - STILL NO DIM REACTION
This happened with my Argon Discharge Tube experiments:
No matter what load I put across the output, the input power level never changed.
This indicates that the output does not come directly from the input,
but from tapping into the reaction created from the input.
IN the Argon tube, I put DC current across the plates until the Argon broke down.
The breakdown produced an AC wave.  I filtered this wave through 'an AC' capacitor in series with the output.
This only allowed the AC wave to pass to the output, but stopped the DC.
Maybe the Coax. cable others suspect is functioning as the filter Capacitor which stops DC and only allows AC through.
If that is the case, then any type of HV cap would full fill this condition.  Coax just provides a cheap 6KV capacitor.
romerouk
The coax cable is just a cheap way to replace the copper tube, nothing more.
Romero
xenomorphlabs
Quote from: romerouk on October 13, 2011, 09:40:50 AM
Romero
Romero, can you explain which copper tube are you referring to from which device?
The coax cable is present in the green box device as well as in the
aquarium device (3rd coil).
dole
Quote from: Jury1 on October 13, 2011, 01:40:54 AM
What conditions must satisfy the system so that the interaction occurred with the environment? - It (the system) must be open... This system should use capacitive coupling for work. Electromagnetic induction should not be used in this system.[/IMHO]
Unidirectional primary pulse to highly damped oscillation causing in the secondary resonant circuit capacitive amplification
and discharging by third circuit in a desire frequency through the load, back feeding source by use of Lenz’s force only.
Quote from: forest on October 13, 2011, 01:56:26 AM
Now you can ridicule this theory.  :D Now your time to tell me HOW is that possible ?
“The current energy, on the other hand, is preserved and can be recovered, theoretically at least, in its entirety."
So we just feeding it back to source. Naturally with some louse but those are insignificant.
d.
Magluvin
Romero
Hmm, interesting.  Also there is more surface area with the braid(shield of coax) than a copper pipe for skin effect.  So the coax is a primary winding.
Mags
