0 Members and 115 Guests are viewing this topic.
xenomorphlabs
Quote from: Magluvin on October 13, 2011, 05:25:17 PM
Probably a good guess.  Most of the time, copper tubing is used as a primary.  ;]
Mags
TK refers to the high voltage coil/cap thing as "primary coil" in the aquarium video.
Since the coax coil carries high voltage as well, it is likely to be also a primary.
Technically there are 3 coils in the new device, so it can get a bit confusing
determining their names.
nightwind
Quote from: stivep on October 13, 2011, 03:40:07 PM
Well my friends it looks like  the history files are being created just  right now  as we speak... at this very moment... At this very time I'm writing this words.
Wesley
Can you elaborate on that? Thanks
wings
Quote from: xenomorphlabs on October 12, 2011, 09:24:58 AM
After reading the TK patent for the first time, i was under the expression that the weird way in which the function is described could be due to translation issues for the patent application.
Yet, assuming that this is accurately describing the operation principle, it is the only source of info on the matter.
Attached is the core pieces that talk about the different fields involved.
3 (!) kinds of energies are mentioned. Nothing new in regards to heavyside etc.
I still have a hard time adapting this patent to a simple device such as the new TK device. He states that there is indeed (at first) high frequency in the second bobbin, but is then corrected to the operating frequency.
Maybe that is what is happening in that PVC box.
After all the red cable is going to the PVC box and closes through the ground via the lamps.
Question is if "stabilizing the difference of 2 magnetic fields" means essentially "cancelling 2 different magnetic fields" or having them at a constant "deltaB" at the same frequency like 2 curves with a phase offset.
And more importantly how would you achieve that ? ;)
Somewhere in this long thread a user made an interesting comment on the possibility that TK makes use of "beat" frequencies : http://en.wikipedia.org/wiki/Beat_%28acoustics%29
They would have a constant difference between them.
The resultant waveform could be calculated to be 50 Hz (e.g. 50050 Hz and 50000 Hz) and would still contain higher frequencies which would need to be removed just as described in the patent by isolating the beat frequency somehow.
see opposite coils
http://www.youtube.com/watch?v=kvIUq9aCKIU&feature=autoplay&list=ULpQ0FyFaPqJQ&lf=mfu_in_order&playnext=2
stivep
Wesley
Yes I can
Successful replication of OU device
150W output  around 5 W input.
By:
International  group of  people including me.
http://www.youtube.com/watch?v=nJBpNKSsdqw
Wesley
leo48
QuoteYes I can
Big Wesley.. ;D
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
