0 Members and 401 Guests are viewing this topic.
xenomorphlabs
@T-1000: Just out of curiosity, what kind of flyback did you use?
An old TV flyback or something else?
T-1000
Quote from: xenomorphlabs on October 15, 2011, 09:10:03 PM
ТÐ'С-110Л - any other rated on 25kV can do without integrated diodes and capacitors.
Just make sure to put it into ferromagnetic resonant frequency... :)
dllabarre
Quote from: T-1000 on October 15, 2011, 08:33:53 PM
We posted most basic circuit for people to get replications successfully done over entire world. Adding complexity for perfomance is only after you fully understand on what each element in circuit does and when it proves in practice already.
For those who started replicating our setup and have difficculty with coils:
We used 1 meter x5 2mm diameter wire (makes multistrand wire) for caduceus coil and 5 meters of 2mm diameter for each secondary coil. So the mass of each secondary coil = mass of primary coil. The caduceus coil is winded from the middle of 1 meter multistrand wire (so 50 + 50 cm). Winding goes on 2 opposite wire ends intersecting each other on each 180 degrees.
Start winding secondaries on top of insullated caduceus coil from the middle of the tube with left hand windind on one and right hand winding on second, wind both at once. After you get coil done, get HF ferrite rod from old radio receiver, put it inside of tube int he middle. After correct tunning it should start heating up, so where ferrite heats up, you need insullation between pieces of ferrite.
Good luck!
P.S> For lower output it can be done with air coil in beginning - this is what you should get in electrostatic resonance. Also putting paper on spark path from secondary coil end will not burn paper - the discharge just goes through it. This is a sign of cold electicity you need. You can even touch it and won't get hurt (just avoid doing that on flyback HV wires!!!) The flyback transformer core is grounded for better efficiency, can work without ground too.
What is the size of the form you used for the coil?
What is the diameter and length of the coil form?
This will determine how "spread out" the caduceus windings are and how many turns I get on my coil.
How many turns did you get on your caduceus coil?
What was the material of the coil form? Paper or PVC or some other material?
Thank you
DonL
AbbaRue
@T-1000
Which coils are using the caduceus coil.
The one before the AV Plug or the one tuned by the Variable capacitor?  Or both?
You stated "for each secondary coil"  which sounds like you mean more then 1 coil.
energia9
I personally do not think that the caucadeus coil what Strictly makes it work...
BuT it would be good if every little detail would be written down so we can understand every single bit of the circuit.
