0 Members and 207 Guests are viewing this topic.
TheCell
@T-1000
1) flyback must be in resonance with not fully saturatеd core.
Is this a strict must ? for I want to use the flyback transformer of a plasma globe.
Thanks for the hint to energia9.
A small incline in output power could be accepted.
2) I don't understand the driver stage .. how currents flow ...
captainkt
@The Cell, tried a plasma globe, 8inch contained osc and small flyback, got quite good results much better than expected from such a small unit,
had two spark gaps firing one prim and one sec and a 150 watt bulb about a quarter alight,the coil /ferrite had a slight buzz to it and I did get transfer to secondary winding.
Only problem then was reliability after about 15 mins fiddling with caps etc the mosfet gave up. Will try to buy a larger more robust globe from somewhere.
Keith
xenomorphlabs
Quote from: AbbaRue on October 19, 2011, 11:48:05 PM
So please stop posting foolish warnings about it.
So that is reason enough for you to turn ad-hominem and restrict freedom of speech?
Doctor, where is the "foolishness" in simply quoting from a wikipedia article
that clearly states that the reagent can have a toxic effect?
Most medicine has side-effects.
http://en.wikipedia.org/wiki/Calcium_hypochlorite
@TheCell:
You are right, i wondered about the uneven number of pnp and npn transistors too. The circuit does not work as expected in the simulator:
bboj
I use the stuff MMS 2 on myselve. It works as advertised. No side effects noted except for the bad taste.
