0 Members and 205 Guests are viewing this topic.
gyulasun
Hi e2matrix,
Would like to tell you that every wrist-watch service shop have got a low frequency oscillator that drives a coil, this coil can be any kind, mainly with soft iron core, many watch service men use a simple open core transformer driven from the 50 or 60 Hz mains (with current limit). The purpose of this low frequency drive is to check the inside mechanical clock work and blow  any dust away with compressed air while the wheels turn faster than 1 Hz.
Some years ago I personally witnessed such speedy turning by a normal (solenoid) coil, used by a service man in his watch repair shop.
I do NOT want to speak against the properties of a Caduceus coil, nor against the Hyper Dimensional Resonator shown in the video. ANY pulsed oscillator with especially open core coils can AFFECT sensitive electronics due to its near-field radiation. I just wanted to clarify the effect shown in the video can be produced with "normal" coils/oscillators, this should not be connected to a special property of the Caduceus coil type.
Thanks,  Gyula
From other Planet
@stivep, T1000 and team:
Thank you very much for the great work and sharing ur results with people, hope it will make world little bit better place to live for all!!!
I have some questions:
- How you measure input of 5W(?) into device, you are 100% sure its not more? (don't want to doubt functionality of device!) I'm asking cause many know meters can lie, especially when hv and high frequencies is involved
- The HV diodes, would it be possible to put like 80 1kV 1 A in series, as this seems to be the cheapest solution? (Saw them u use on ebay and there price was about like 40â,¬=~50$ for one)
- What is min/nominal voltage of the spark gaps?
PS: I have not much money, but also would donate some Dollars/Euros for TK, guess almost everyone here will do
xenomorphlabs
@T-1000 : Got another question concerning the power supply in your circuit.
From the looks of the isolation transformer secondary you have a winding center-tapped with a distribution of 8:80 Volt.
That would create an enormous DC offset for the transistor stage and the following flyback with no decoupling caps used. Is that intentional? Seems to be made special note of in the schematic.
Normally people try to avoid such DC across their transformers. You do that to saturate the transformer core deliberately?
In the case that the isolation transformer puts out 8V and 80V instead of 220 Volt then your power consumption would be less than 5 Watts if the optimal current is 0.025 A as mentioned in the schematic.
So can your confirm what voltage you use to supply to the driver stage?
Thank you.
T-1000
Regarding electronic watch over caduceus coil - nothing magical, the main element in electronic watch is quartz crystal for 1Hz frequency(pjezoeffect) and seems it affected and is a caused illusion of "time warp"... :)
Regarding power input - the input is not able to handle 150W load and would burn out.
Regarding question about TT winding center-tapped with a distribution of 8:80 Volt - in Tesla coil you expect to see even less windings on primary and it is not conventional electrical step up transformer. It is almost electrostatic machine with ion flow instead of electron flow in secondary coil.
electricme
@T-1000
Just want to thank you for making the circuit and posting it, however, is there any chance you might alter the colours of the background from black to white? and make the wires black.
I managed to print it, but the whole page was black, me being an invalid pensioner, I need to concerve ink here.
I also tried to open it using Foxit Reader, but it said format error: not a PDF or corrupted. Any chance of making the pdf to be read from Foxir reader?
Measuring high voltages
As an above poster has mentioned previously, this device can make life unpleseant if you accidently contact a high voltage part.
I don't usually post recomending this or that but this is an instrument (very cheap) that everyone here could use to fault find the high voltage sections on the Kapanadze Device.
There is a High Voltage probe that has been made by Silicon Chip magazine in Australia, it is called EHT Probe, it appeared in the Aptil 2010 issue, you can take a look at it here http://www.siliconchip.com.au
It basically is a single strip of PCB, with 80 X 10Mohm 0.5 watt resistors in series, and a 25 turn trimpot to calabrate it spaced apart for safety.
The output plugs into the DMM via banana plugs.
This can be bought from Altronics (Perth is the head office) in Australia in Kit form.
jim
