0 Members and 18 Guests are viewing this topic.
electricme
EHT Probe ;D
Kit Number K2559
Currently it is going for $45 Australian
Try here to go to the web site http://www.altronics.com.au/index.asp?area=prod&grp=429&pg=0&list=2&sort=alpha
For those who need the direct link, take a look here http://www.altronics.com.au/index.asp?area=item&id=K2559
jim
dllabarre
@T-1000 & Stivep
Tariel's Green Box unit has the load (bulbs) connected to the ground wire and the ground wire showed 22amps.
I'm curious as to why is it that you don't need to connect the ground wire to the load?
What is different?  I want to understand everything about this device of yours.
Thank you for any explanation
DonL
forest
Quote from: dllabarre on October 20, 2011, 11:12:29 PM
@T-1000 & Stivep
DonL
In green box video I believe once gound was changed to buried radiator only one bulb was lighted.Would be interesting to see how this new circuit behave with two bulbs in series or parallel at output and with/without ground connection.
energia9
i have some questions about the spark gap tube again, because i have seen they either contain mercury with some nobel gas, or they are radioactive, i found  spark gap tubes on ebay and their pure source of gamma rays was 11 mR/h.  it contains 226 Radium,
we are sure that the device do not require a spark gap tube to operate?
Thank you.
AbbaRue
This site sells 1000V 6A diodes for 30 cents each and if you buy 100 they go down to 25 cents each
http://www.futurlec.com/DiodesPower.shtml#6ASeries
All placed in series that;s 100kV for 25 dollars.
Or $6.25 for 25kV.
