0 Members and 204 Guests are viewing this topic.
energia9
Quote from: xenomorphlabs on October 21, 2011, 10:48:17 AM
Would it be possible for you to explain what the experiment shows, what you are measuring there and where in your set-up the caduceus coil can be found?
Or do you suggest to repeat the experiment with a caduceus coil instead of solenoids?
@Energia9:
To replicate WMT device my budget is too low at the moment.
HV vaccum variable caps are simply too expensive.
Got a couple of monitor flybacks that will do the job, the smaller HV caps,
could chain some diodes and wind the coils already.
I am experimenting with a different approach towards the TK devices
without high voltages as a single source being transformed and no ferrite cores simply because i cannot positively identifiy ferrite or iron as a core material in TK's latest device and the aquarium device.
But am looking forward to finally getting the components together to
also verify Stivep's build.
High voltage Variable caps - i made one out of a tunable radio cap, i put it in mineral oil, and the voltage cannot jump across now.  CHEAP
http://www.ebay.co.uk/itm/Vintage-twin-ganged-radio-tuning-capacitor-0003uF-300pF-/290620925960?pt=UK_Consumer_VintageAudio_RL&hash=item43aa5b6808
Diodes- From Microwave oven ;)  they are high voltage high current diodes. 12 KV, you can also order them from china for CHEAP
http://www.ebay.co.uk/itm/4-pcs-Microwave-Oven-High-Voltage-HVM12-Diode-Rectifier-/120797205148?pt=LH_DefaultDomain_0&hash=item1c2013129c
these are very good for high voltage
Anyways in earlier experiments i have tried out 800 V diodes for 5 kv, only damaged after a lot of use and experimentation...
xenomorphlabs
@Energia9: Thank you for the tip. What kind of mineral oil do you use. Paraffin oil?
Mineral oil is usually flamable, not sure if that makes it safe to use when sparks could occur.
But you can confirm that the usage of mineral oil works fine as a HV isolator even at 25 kV voltages across the plates in your set-up?
energia9
Quote from: xenomorphlabs on October 21, 2011, 11:32:59 AM
Sorry so its hydraulic mineral oil,   The one are being used in Ignition coil for cars, the ignition coil is submerged in this oil, i got the oil from an old ignition coil,
Ignition coil can send 100Kilovolt.
oil has no conductivity, when voltage breaks down inside oil, it has to be really high voltage,  and no it can not ignite because it is in an oxygen free environment, nothing can burn without oxygen, this material will not explode either, only if you heat it to 300 degrees C then give spark to its fume, then it will burn, but only in oxygen rich environment.
REVISED:
Xeno, sorry for misleading info about the ebay item at the top (variable capactor)   the plates have to be more far from eachother than in a usual tuning capacitor, because as i have tried, at very close plates arcing will.. occur,   you can make your homemade variable capacitor btw, not too hard, look up on google.
and tesla did it that way too,
because we dont need high Picofarad, its very easy to achieve it, you need to use fairly big aluminium plates, oil will give you double capacitance
I will make a couple of these items, will show them in here.
dllabarre
@T-1000 & Stivep
Tariel's Green Box unit has the load (bulbs) connected to the ground wire and the ground wire showed 22amps.
I'm curious as to why is it that you don't need to connect the ground wire to the load?
What is different?  I want to understand everything about this device of yours.
Thank you for any explanation
DonL
energia9
Those of you who work hard on the device like me, and if you have the same thought as me, working together, sharing data and tips etc, we could speak in Skype all the time, It is continous work and dont have to wait
Send me a private message
