0 Members and 237 Guests are viewing this topic.
xenomorphlabs
I took the freedom to redraw the schematic done by T-1000 just for personal
reasons to understand it better and because i tend to arrange elements in a schematic in a different way and took into account that there was a mistake in the original related to the transistor emitter arrows.
Maybe someone finds it useful.
As a pdf: http://www.mediafire.com/?16vkycwdwt6x65o
Note : The transistor models chosen won't work for 88 Volt or whatever T-1000 used there and would have to replaced with higher Vcb variants.
baroutologos
Hey Xeno,
Nice redrawing here. As i see it, there is an inverter, a HV HF resonance transformer, a diode plug that lead to a second transformer whose windings are inductively and electrostatically coupled together (iductively for transfering power and electrostatically for the operation of the diode plug), and an exit-to-load resonant circuit.
Whereas it is supposed to happen the energy creation there?
xenomorphlabs
Quote from: baroutologos on October 22, 2011, 01:40:25 PM
Hey Xeno,
While i wouldn't call it energy creation but rather energy conversion, i would say
the additional energy has gateway into the system via the resonant condition
at the flyback and the following resonant circuits for a (cascaded) logarithmic gain.
This energy is always present in any resonant circuit with a sufficient Q, but gets usually tapped too much, so that the gateway closes.
The last transformer with the caduceus coil presumably manages to couple into that energy without destroying the resonant condition due to the non-reflective
topology of the individual coils with the special magnetic properties of the caduceus and the bucking coils.
This is not my personal thesis, it is an increasingly popular explanation for the phenomenon.
Magluvin
Quote from: energia9 on October 22, 2011, 10:35:54 AM
first of all why can we not have diode in the flyback? because they had no diodes in it?  it has been tried with a flyback that has diodes in it or not?  better try it first. saves us time and money...  please...
Hey E
If we look at the circuit, all of the coils of the fly-back are in series. One of the coils has a cap for resonance, and if we look at the original drawing of the circuit, AV plug at the left is not working open ended. The other side of the cap being charged by the AV IS connected to the other end of the fly-back through capacitance between the primary and secondary of the transformer just below and right of the AV plug.  ;]
So if we leave the diodes built into the fly-back in there, we wont get the oscillation needed to make use of that LC(the one winding with the cap) on the fly-back either.
Why not just cut away all but the HV winding, and wind new primaries, as needed.  Some fly-backs are completely encapsulated. May be very difficult to remove items without damaging the HV coil.
Some of these Ozone generating fan devices might have simpler versions, without controls/diodes built in. And as said earlier, plasma globes.
Mags
e2matrix
Quote from: gyulasun on October 20, 2011, 02:13:04 PM
Hi e2matrix,
Would like to tell you that every wrist-watch service shop have got a low frequency oscillator that drives a coil, this coil can be any kind, mainly with soft iron core, many watch service men use a simple open core transformer driven from the 50 or 60 Hz mains (with current limit). The purpose of this low frequency drive is to check the inside mechanical clock work and blow  any dust away with compressed air while the wheels turn faster than 1 Hz.
Some years ago I personally witnessed such speedy turning by a normal (solenoid) coil, used by a service man in his watch repair shop.
I do NOT want to speak against the properties of a Caduceus coil, nor against the Hyper Dimensional Resonator shown in the video. ANY pulsed oscillator with especially open core coils can AFFECT sensitive electronics due to its near-field radiation. I just wanted to clarify the effect shown in the video can be produced with "normal" coils/oscillators, this should not be connected to a special property of the Caduceus coil type.
Thanks,  Gyula
Thanks for that info Gyula.  I don't buy into Gibbs HDR resonator totally but I have heard rumors for a long time from many sources about a Caduceus coil having odd effects on time and possible scalar wave transmission.  So I thought it would be good to bring it up if people are going to build something to run full time powering a home I think it needs to be shielded as good as possible or at some distance from where people sleep and live.  I have heard scalar waves travel long distances too so it might be good to orient such a coil in a way that it doesn't point toward living areas.  I'm thinking vertical might be a good orientation.
