0 Members and 438 Guests are viewing this topic.
Mannix
Quote from: wattsup on October 22, 2011, 10:30:29 AM
@Mannix and @all
So what do I have to do with my flyback transformer? Tear it open and remove the diodes since the WNY device did not have any and there are none shown in the diagram that @T-1000 posted days ago. So I have to remove the diodes. Doctor Welby, we'll have to operate. Hmmmmm. Will it survive the trauma is the question? lol
Interlude.................10 minutes later........
Well I tried using a hack saw blade and started sawing off an edge of the circuit side of the flyback transformer, but there is no way you can do it. It is all encapsulated in epoxy. The only other way is to use a hot air gun and melt away the material. This is highly unpractical and will surely result in damage to the coil wires that will require reconnection. So this is not a good idea to use standard flyback with the WNY diagram.
The youtube I referred to in my previous post shows a circuit, shows it sparking, and is doing it with the standard flyback without any internal modifications or diode removal, so maybe we need to marry that to the WNY diagram. I have put his diagram below since this is one way to do it.
We already know TK did it in many ways starting with the green box inverter, with car battery start up, to his plexi unit with the 9 volt startup. These all confirm that the initial ramp up method is not important. So to see the differences in units, we know the initial ramp up can vary, so what does  not change. The TK coil. So all that before the TK coil is mainly up to what is practicable while the TK coil remains an unchanged method.
Creating the first spark can be accomplished in many ways. Tesla did it in the Tesla Ozone Patent using damped wave pulsing via a rotary switching method and his device produced sparks that we call corona discharge producing ozone gas. @T-1000 mentioned that his first vacuum spark gap is useful to hold in ozone gas and u.v. rays. There are many ozone circuits out there today that can do the same thing. Also there are countless U.V. lamp circuits that use high voltage as well. Being in the water treatment business I have a bunch of UV circuits in the shop so I will take a few on Monday and see what can be done. I think I have an older ozone generator as well. Guys can just contact your local water treatment company and ask them if they would have a few ozone or UV circuits they would like to donate for R&D.
What I am trying to say here is that just because @T-1000 had an old flyback, it does not mean that is the only solution to the first spark.
wattsup
Please try to replicate as close as possible with the right flyback configuration.
You may have difficulty tuning with the diode string in place and the encapsulated flybacks have screen grid and focus controls also tied to the hv dc section .
If you just want pulse dc, ok...but i think that this is about having  tuned loops where the coil configuration can do its "recycling"and pick up some friendly electrons on the way.
The analogy I like  is that we are creating  a little bit of our own lightning to tune into a bit more real lightning.
However right you may turn out to be , why play with the knowns at this point , when we are surrounded by so many unknowns, and so many interpretations...and a few typos!
nightwind
Quote from: xenomorphlabs on October 22, 2011, 04:19:10 PM
Good idea, they would be available to everyone.
But unfortunately wouldn't work either without modification, because you only got the "hot" output available and in Stivep's group device you need the "cold" end to connect to the other transformer secondary.
If i remember correctly ignition coils have the primary and secondary connected, so it is kind of available, but not sure if it would work the same if you can put that thing into resonance in the same way.
Could you wire two ignition coils in some parallel manner to mimic a flyback?
xenomorphlabs
@TheCell: May i ask what exactly you want to point out with the word "short-cut" in the spice schematic ?
leo48
Quotei have got two of those ignition coils,
The ignition coil car has a resonance frequency very low
;D
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
TheCell
Sorry if this is not correctly translated .
A potential of 24 Volts is sent through 2 Base Emitter Diodes that would normally have a Voltage across 0,7 each , resulting in a much to high base current.
I meant to say shorting the poles of a battery or power supply, with almost no resistance.
