0 Members and 186 Guests are viewing this topic.
Jimboot
electricme
Someone suggested using a old ignition coil to get some High Voltage.
Below are 2 photos of a coil pulldown I did in July 2009.
I used a vice to hold the coil, and hacksawed around the aluminium cylinder very close to the insulated tower.
I managed to save the oil in a container, although residual oil did make it a bit messy.
It turned out the HV wire coil (secondary) was the coil closest to the iron laminations, the very 1st turn of the coil (during manufacture) was attatched to the iron core which in turn would have made contact to the bottom of the insulated tower.
The last turn was connected to the beginning of the wind of the Primary coil, the end of the primary going to the attatchment terminal as seen in the photo.
The primary just slid over the secondary, it came apart very easy, I was rather surprised just how small the main section was.
Magluvin
Hey electric
Is that a laminated core?
I wonder if it works just as well outside of the can?  ;]
Mags
xenomorphlabs
Quote from: TheCell on October 22, 2011, 05:32:46 PM
Sorry if this is not correctly translated .
A potential of 24 Volts is sent through 2 Base Emitter Diodes that would normally have a Voltage across 0,7 each , resulting in a much to high base current.
I meant to say shorting the poles of a battery or power supply, with almost no resistance.
eroneous information posted, that's why removed.
AbbaRue
I must have missed something somewhere.
I still don't know which windings are supposed to be caduceus coils.
I thought the transformer after the tuning capacitor was a step down transformer.
In the closeup photo he shows the coil made of 5 strands of 2mm as being wound as a caduceus coil.
Is that the secondary for the transformer at the tuning capacitor?
Could someone please clarify this.  Which windings are caduceus coils?
How many caduceus coils are used in this build? It sounds like there is more then one.
