0 Members and 381 Guests are viewing this topic.
forest
Spark gap material does not matter if you have silent spark as Tariel had in his green box device.No heat , no sound, not deterioration on electrodes.
energia9
Quote from: FreeEnergyInfo on October 24, 2011, 08:50:42 AM
NEW SHEM KAPANADZE..
http://freeenergylt.narod2.ru/tariel_kapanadze_secrecy/
who drew those schematic?
everything starts to get very confusing,
he uses 50 hertz signal amplifies it up, sets resonance between primary and secondary,boosts up voltage, then further transmit it to a second transformer which brings down voltage ... ???
do tariel say resonance can be achieved at 50 hertz?
i know that when tesla speaks about longitudinal electricity he mentions using less than 20 khz so the losses in hertzian waves are smaller. and he mentiones frequency must be not less than what earth resonates at, which is 6-10hz
energia9
Quote from: From other Planet on October 24, 2011, 09:16:32 AM
I would like to hear one more opinion, if putting 80 1kV 1A diodes (for example UF 4007, short switching times) in series to have cheap 80 kV Diode, is a good idea or not?
Also i am still very unsure about which spark gaps to use. Minimal/Nominal Voltage? Electrode Material?
The spark distance influence frequency spectrum produced by the spark?
Im working on a rotary spark gap for other projects, but dont know if i could use it in this setup. ???
Kind regards
Use high voltage diodes, those from microvave oven will do it just fine they are rated for 12kilovolt and can handle big power.
attaching 80 diodes in series will give you high switching and other losses. which is not good
xenomorphlabs
Quote from: energia9 on October 24, 2011, 09:20:35 AM
He indirectly said in his patent, that the secondary still contains a high frequency signal that will be converted to 50 Hz with a frequency adjuster.
Whether or not you give anything on that patent, the proposed circuit is a deviation from that.
Jury1
I was doing inverter on  the Flyback Transformer and faced with an interesting effect.
This is not the avalanche breakdown. Transistor was cold. The base is completely disabled.
http://www.youtube.com/watch?v=sgJRs8ehC94
