0 Members and 211 Guests are viewing this topic.
Pirate88179
Goat:
As the guy who began this topic, my vote is to post it here.  I mean, I believe this is all related and, if folks can get this up and running, it may help to understand what Tariel is doing.
It is up to you guys though.  I am just all for trying to figure this out.
What do you think?
forest
First find total schematic of device INCLUDING inverter and neon sign transformer! I think it is all connected together.I saw another video ones when Smith said that he found neon sign transformer that works so not everyone works!
Goat
@ Pirate88179
Thanks for the vote of confidence, the last device that Don Smith showed seems very easy to replicate and somewhat similar to Tariel Kapanadze's but even simpler to build.
@ All
Don Smith specified at the end of the video that "You don't have to know what you're doing at all" and that "you don't have to tune it" and that "the circuit takes care of that for you" !!!???
The only things he specified was:
1. L2 has to be an even division of or multiple of the wire length of the first coil L1.
2. Earth ground at center of the spark gap to limit the voltage for the device to be loaded onto the circuit.
3. Isolation transformer cannot use the frequency so it has to be corrected with a resistor across the 2 poles using the American Radio League or other chart using capacitance or resistance to calculate the frequency you want to end up with (60 or 120 cps).
4. Use a Varactor for voltage control on the output earth ground to limit the voltage to the device that you're trying to run.  He mentioned that it looks like a capacitor but it's not, from what I've seen looking for these it would be a varactor diode (see pic below).
He also mentions that with this setup that none of the electrons leave the system but instead just excite through induction at L1 and L2 and the isolation transformer so that no electrons has left the 12 V battery to drive the HV module!
All the above was taken from the videos and is subject to correction(s) if I misinterpreted anything.
Crazy thing about this is that I've seen Don Smith documents with pictures from these videos before but didn't see this particular circuit, only the more complicated ones!
BTW... my last post should have been DIY (for Do It Yourself) and not DYI (my bad).
Edit:  Sorry folks my last pics of the circuit went south so I removed them, I'll try to correct them and reload.
Regards,
Paul
jeanna
Good work goat!
I had one question after watching this that you did not mention.
Is this resistor a light bulb or some other resistive unit that we are accustomed to using?
Maybe it is just a 50 ohm little thing, but maybe we can use this spot. (she asked hopefully)
thank you,
jeanna
Goat
Hi jeanna
I did mention the resistor in 3. above but I'm not knowledgeable enough in electronics to know what it should be....
From what I understood the size of the resistor would have to be calculated for frequency as D. Smith mentioned using charts.
Regards,
Paul
