0 Members and 256 Guests are viewing this topic.
Hope
Hope
Quote from: Hope on October 28, 2011, 05:45:27 PM
I read a report recently and I WILL find it and post it.   They made a IRON pipe react with a center rod with high voltage on it.  They slowly ramped up the HV to the reactance level of the iron particles and gained over 1082% output over input in 1957 (or around then).  So it would seem perhaps the coil is the antenna and the iron reactance is the generator.   When I find this article again I will post the link.   It seemed like the frequency was around 14,220 K
http://tech.groups.yahoo.com/group/freeenergysurprise/   they are working on this device but the document I have will not save so I can post it.   It is a Locked PDF.   Someone send me a program to convert a locked pdf and I will post it.  But I digress, the important part is that it is the reactance of the iron not the coil that causes the OU effect.  Altho I can see it working due to the elements harmonic makeup.  In the end I predict that the energy is coming from the iron's atomic particles changing into a near element.  (Like a decay effect and a heat exchange).
Has anyone noticed that that Rossi device is very similar to a Geet reaction chamber vented during the compression cycle?
I ask you all for comments about this and your thoughts on this subject.
It does apply toward TK device in that it also use's hammered compression obtained by HV electro motive FORCE increased like a head on collision.
Jury1
@stivep
Can I find out in detail what generators are you using?  How do you connect them to the coils with low resistance?
I am interested in the signal  form of first and second generator, as well as the value of spark gap HV  generator.
Yours faithfully
FreeEnergyInfo
Quote from: Jury1 on October 31, 2011, 01:23:26 AM
@stivep
Yours faithfully
VIDEO...
Don Smith's device replication by NUB -10.10.2011.
http://www.youtube.com/watch?v=R2_gvWEa7tc
S T I V E P ,
PLYZ POSTED ORYGINAL SHEMATIC 800/600 PIKSEL http://freeenergylt.narod2.ru/aidas/R.bmp  ....
Mannix
It's looking like the hv pulse to the braid might need to get  its sync pulse from a few seperate turns  on the the output half.
Thankyou  Team99
