0 Members and 151 Guests are viewing this topic.
zilano
Quote from: Hope on October 31, 2011, 12:55:28 AM
http://tech.groups.yahoo.com/group/freeenergysurprise/   they are working on this device but the document I have will not save so I can post it.   It is a Locked PDF.   Someone send me a program to convert a locked pdf and I will post it.  But I digress, the important part is that it is the reactance of the iron not the coil that causes the OU effect.  Altho I can see it working due to the elements harmonic makeup.  In the end I predict that the energy is coming from the iron's atomic particles changing into a near element.  (Like a decay effect and a heat exchange).
Has anyone noticed that that Rossi device is very similar to a Geet reaction chamber vented during the compression cycle?
I ask you all for comments about this and your thoughts on this subject.
It does apply toward TK device in that it also use's hammered compression obtained by HV electro motive FORCE increased like a head on collision.
http://www.pdf-unlocker.com/pdf-unlock-utility.html
http://www.pdfunlock.com/
http://www.pdfunlockertool.com/
ZZZZ
energia9
Quote from: stivep on October 30, 2011, 09:10:57 PM
Please read  this:
http://magnetism.vfedtec.com/NaturalRelativity.htm
http://magnetism.vfedtec.com/Overunity.htm NMR effect
http://magnetism.vfedtec.com/FieldDensity.htm NMR effect.
The material that may support capacitive Reactance is here it may support one of your thesis.
https://mail.google.com/mail/?shva=1#sent/132c68acde7b0eab
Magnetic Fields
http://www.ux1.eiu.edu/~cfadd/1360/29MagFlds/HmwkSol.html
thats a lots of homework:))
thx for all info and trying to help, really appreciated Wesley.
about the tests:
im tuning things now, i could not quite make 150 windings from 10 metres of wire at the same ferrite as of aidas,   i have around 75 winds of the stranded enameled wire.
@Wattsup:  Excellent friend:)  u work hard, keep up.
I hope to see more people replicating and sharing.
PEACE
gigastorm123
this is amazing! there was a post i made awhile back on how i had astral traveled and saw the future to when the first available to be made by everyone free energy device was made, and when i got images of it, that same woven silvery material was implemented in the same way here! except instead of wire wrapped around it, it was a thin hollow copper tubing wrapped into a coil, and through the copper tubing were two insulated steel wires with their ends sticking out one of the ends of the copper tubing. this then had that same silvery woven mesh strip going through the center of the coiled copper tubing and met on each side, idk if it was attacked to the copper tubbing or not either by solder or not, or maybe it was just glued or something, but then basicly i got an image of somone putting a pvc pipe the same outer diameter as the inner diameter of the copper tubing coil. i remember it being held up, i dont know if there was ferite inside or not, but if there was it was a hollow rod, and i remember feeling like the toroid came out in peices, which also fits in along with the seperated toroid halves seen here! the basic jist of the feeling of how it worked in my vision was that the copper tubing  and the steel wires were where the overunity part happened, and then, those wires' leads flowed back to a cicuit board in in a box where the capaciters/tuning circuitry/and other electric componants were. i remember in the images the whole thing looked like a toobox with the insulated coil setup where the hndle usualy is on a a toolbox and on the front were 3 dials, two number lcd displys and two up/down two way switches. with this new news im thinking one of those knob mighttve been a frequency modulation tuner,and the other two knobs might have to do with stageing the voltage/amperage as you turn it on to the final out put stage. i remember in my vision the other thing to note is that you turned it on in stages, and used the twitched to re-rout the power to othr internal parts. i think [this part couldve been my own ideas mixing in] that there is a veriac inside with it's large knob exposed on the front. basicly though in my vision the device had several startup stages that worked with the knobs on the front along with the switches and the lcd pannels. im thinking one of those lcd pannels was a voltage/amperage display and the other had to do with the frequency generator. also on the back was were the 120/220 volt wall plugs were, so you can plug common apliances into it.
the reason im puting this here is because it has reinspired my intrest in free energy as well as my confidence that the image i got wasnt just made up by my sub consious, due to seeing that silver mesh strip, kinda like the kind you see on the bottom of slot cars, seeing that in the video and hearing talk of a design for the future that might not involve a ferit toroid componant makes me confident again! also part of the reason i also never went back to that to dd more is because im a very easily distracted person and my mind jumps from one topic of intrest to another, im only 20 and still a bit imature and have little knoledge of electronics other then what i learn on the inernet while researching this stuff. but yeah this is amazing!!! i feel like we're on the right track with this design method! we need to keep going with it!
giga~
pix
Hi Zilano :)
I am glad to see you here.
A lot of people admire you for all the information you gave at www.energeticforum.com
Could you post your working schematic with explanation "how-to-do" here, at OU.com?
Because for unknown reason sometimes your posts vanish from the "Don Smith too good to be true" thread.
Also not eerybody could see your schematics because to be seen one must be logged. For example I am registered member at energeticforum, but can't see posted schematics and pictures.
Best Regards,
pix
