0 Members and 164 Guests are viewing this topic.
baroutologos
NEW INFO FREE ENERGY......
http://freeenergylt.narod2.ru/aidas/
This is another attempt to explain the methodology followed by the TK replication group in order to guide us in their steps. Personally i find it still difficult to understand the how...
1) what is the primary frequency selected from white noise that corresponds to ferrite alleged self resonance (1.64 Mhz)
2) What kind of frquency correspond to the other 51 windings' coil lower end spectrum one? 382Khz
1+2) how those frequencies relate to each other?
3) Carrier wave is the energy carrier as i see it. It has a relation of 382.000 / 50 or 7640 / 1 cycle ratio. What is the importance of tuning one wave to the other?
4) The spark gap emulates the first 1.64 Mhz fundamental ferite resonance frequency?
5) How unloaded (even with a piece of paper separated the ferrite parts) the output winding can have as much as 1 Kv (no load) voltage and the wave generators to work without being burned?
Few questions...  soon more :P
ps" pls people quit trolling, relating to other OU devices, "i told you so" comments , Jesus told me etc
Goat
@All
Please take a look over @ energetic forum for tuning and build info:
http://www.energeticforum.com/renewable-energy/9673-wesley-stivep1-video-high-voltage-frequency-ou.html#post164613
"Originally Posted by dragon View Post
Thanks T-1000, can you re post it here? Also, what is the proper procedure to find the natural resonance of the ferrite ring?
T-1000:  That's correct and you need to support it in all time.
First you use those 2 copper plates after generator and generate white noise to it.  When doing that you check where are peaks on spectrum analizer and apply correct resonant frequency. No matter what type of signal is, the output should be sinus wave on secondary coil. In our case the resonance was 1,66Mhz
Now, when you put resonant frequency in, attach frequency analizer into primary coil of 51 turns the other 16 turns are on first primary). Select highest peak from lowest frequency range. So it will be resonant frequency for that coil. In our case it was 382Khz.
After doing this, you need carrier wave, in our case it is 50Hz. When you attach 50Hz to 16 turns coil and ferrite resonant on 51 turns coil, you need to synchronize pulses between in way you get large sinus 50Hz wave carring small high frequency pulses inside. For this we used TV set's horizontal and vertical lines sync circuit and adjusted its parameters to needed frequencies.
For each coil you need to make LC circuit acting as filter on needed frequencies. So you calculate capacitancy values in conventional way and test it.
If you manage get working circuit until this step, you should have OU already.
The paper between 2 pieces of toroid acts as insulator.
If you start discharging HV capacitor over spark gap to copper plates, it will make strong scalar magnetic wave impulse and amplifies output power while lowers needed input power from generators. Just be cautionous about this step, in our experiment the ferrite gone into pieces with load of 600W (150W is without sparks) after 15-20 minutes.
@T-1000 my apologies if I'm stepping on your toes as I'm sure you're a busy man... :) but sometimes links to other sites vanish...the text posted above should help the people here trying to replicate your team's device.
Edit: Sorry everyone the text is all parsed out, I'll try and correct it :P
Regards,
Paul
grizli
Quote from: stivep on October 30, 2011, 07:53:25 PM
Guys after Tbilisi I have got extra careful... and extra suspicious that all :)
Look at the video at the end there is schematic of the coil and during the movie several times it was posted that one half of ferrite has two winds 50 and 15... at my  particular example it was 51 and 16
second one  should have bifilar 2x 150winds ( in my particular setup it was 81)
The number of winds is not critical..hmmm......good question..
Critical seems to be ferrite by itself...
Definitely has something to do with frequency of nuclear spin so to say ferromagnetic.
Arrangement's of the coil are two opposite magnetic fluxes one  from copper strip the other from  set of two coils... 16 and 51... NMR utilize set of coils in similar pattern..
Wesley
Hmm, do you have any idea of exact ferrite type "name" in TV CRT screen coil ?
What ferrite type has been used in second part of video , originally one that was not cut by half, and what kind of cutting machine was used to cut so brittle materiajl to half
Ane one more question : Experimenter in fist part of video use TV CRT ferrite core: Has he tried to use HV SPARK gao to that TV crt type of ferrite to get even more energy out, or in the other words , will there be video that gives that spark gap operation
Thank you
cosmoLV
Quote from: FreeEnergyInfo on October 31, 2011, 02:57:04 PM
Извини, но эÑ,о уже дебилизация народа! Ну сколько можно враÑ,ÑŒ? ЭÑ,о просÑ,ой импульсный сÑ'м! Ð"де Ñ,уÑ, чудо? всÑ' эÑ,о делали а воÑ, Ñ,уÑ, пришел чувак завернул эÑ,о самое в другой чеÑ...ол и "Еврика"
и Ñ,о чÑ,о Ñ,,ерриÑ, разваливаеÑ,ся оÑ, импульсов Мы Ñ,оже знаем и проÑ...одили.
*особенно эÑ,о касаеÑ,ся stivep - Ñ'сли Ñ,Ñ‹ благом делом занимаешься, Ñ,о дай людям чÑ,оÑ,о ценное и Ñ...ваÑ,иÑ, Ñ...ерной занимаÑ,ся!
*especially stivep - if you are doing good business, then give people something of value and be engaged enough garbage!
Keep your chakras opened :)
stivep
Quote from: cosmoLV on October 31, 2011, 06:00:08 PM
That is a good one :)
time will show...
I do not have fame, money, benefits or name to share with anyone in exchange for his/her approval.
THERE IS NO BENEFIT I CAN THINK ABOUT THAT WOULD BE  REWARDING ME IN ANY POSSIBLE WAY..
APART FROM ME THERE ARE 5 PEOPLE THAT  STATE THAT IT WORKS..
ARE WE ALL DECIDED TO HOAX ANYONE?
These individuals do not benefit from that anyway..and they are long time in the field of free energy...
So I do not care.............. I was in the shadow and will stay in the shadow....
After all when free energy will become obvious and  present nobody will remember me so what I have to lose.... no gain as well...
Is than not the best reason to say true and real achievement?
That is my response!!!!!
Wesley
PS:
Quoteespecially stivep - if you are doing good business, then give people something of value
I'm not doing any business NONE!!!!!!!!!NO MONEY.... apart from tremendous expense I carry on myself trying to help others. Show me the reason that I will become  obligated  give you "Mr Russian fellow" anything...at all...
I'm giving to everyone  not to  Russian individual in particular...
So do not take it if you  do not feel like..
Did he pay $3000 for my trip to Tbilisi?
Did he risk his life( poison) to get  information delivered to others?
What was my gain giving  info about Tariel Kapanadze device to the people?
What did he (Russian Fellow)deliver apart from complain?
That is what Russian fellow can not understand....He simply does not get it...
So let it be.
Do not forget to report it  to Russian K.G.B. They may throw you few rubles for that :)
And definitely they can  not send me to Siberia to Concentration Lager known as Concentration Camp for that as well.
very similar device from
tiger2007 реплика3 .flv  http://www.youtube.com/watch?v=Fu5cZ2Xyh5M&feature=player_embedded#!
information with scope shoots: http://freeenergylt.narod2.ru/aidas/
