0 Members and 86 Guests are viewing this topic.
xenomorphlabs
Quote from: microcontroller on November 01, 2011, 08:28:54 PM
Hi
I did not say it is or was fake...
The only thing i did was share the things i found out to be suspicious.
You might agree with me that it is suspicious to have lamps hanging from trees and that it is fact that it is possible to easily hide external feed cables.
I think it is a good idea to see where all the wires go don't you think?
Also i think it is a rather bad decision to power those lamps at 50Hertz when doing a so called FE demo since they burn well on rectified DC or at any other suitable frequency far away from the mains frequency.
A light bulb isn't exactly a AC load i am sure you are aware of that.
Because this frequency is so close to the grid frequency i start to wonder what is powering those bulbs, and i'm sure i'm not the only one.
If it wasn't for this frequency things would look alot more trusty at least to me.
That's all so please don't blame me for sharing my findings, even if they have a somewhat negative character.
I'm open minded, but i am also accurate.
Tariel Kapanadze's patent WO2008103129A1 states:
QuoteThe electric energy formed by the second bobbin adjusts the necessary frequency (220 V 50 Hz or 110V 60 Hz) for use, by the help of second frequency adjuster
So it comes as no surprise then to hear the device run on 50 Hz, because it was designed to do so ...
So there is absolutely nothing supicious about the frequency.
It is an OU inverter and inverters run on 50 Hz.
If you wanna find hidden power wires, you can pretty much do that in 98% of all OU demonstrations, because debunkers can always suspect them hidden somewhere.
You either consider TK a fake or not, there is no inbetween.
Mannix
Please try hard not to  feed opinionated negativity.
It only knows how to fight.
I think it is "soft" ferrite that we are looking for .  104mm "available" ring coming soon.
@ wesley do you know if is  vital that the ring is cut into 2 halves?
I would rather not diamond cut it if its not important .
I see some monitor  yokes are in one piece.
Thank you
TEKTRON
Quote from: Mannix on November 01, 2011, 10:16:02 PM
Thank you
Romero halved his with a hammer. Nice results  :o
Jury1
Quote… @ wesley do you know if is  vital that the ring is cut into 2 halves?
IMHO the gap between the two cores to affect the setting of the resonance…
I think you can use either a rectangular core. It is important to have similar properties.
@ Wesley
how are you going to do frequency synchronization of two oscillators? This is a very unstable process ...
In Russia, the TPU rubber stamp as pies
http://www.youtube.com/watch?v=Pkvfo6opaiI&feature=mfu_in_order&list=UL
http://www.youtube.com/watch?v=wAmDpqhvxZE&feature=player_embedded
There is a diagram of the device. It is drawn from
a story by the author ...
http://www.001-lab.com/001lab/index.php?topic=1056.3800
