0 Members and 72 Guests are viewing this topic.
T-1000
Quote from: grizli on November 02, 2011, 07:19:09 AM
Its easy to make coil lookiing image, its HARD to drive it properly to get OU..
All coils need filters ? LOW pass? High Pass?  Edge frequency of filters?
Why 50 Hz signal and 380 kHz signal have to by in SYNC?= One is VERY slow and other is fast. What difference does it make here?
Unless you do experiment, your questions won't be answered.
And it is simple as that: when you mix 2 incoming signals on ferrite in 2 coils(the geometry question still needs to be answered), you resonate ferrite core and use as transformer on same time. The experiment results show what happens when you tune those 2 signals in such way they start affecting needed power IN vs OUT. :)
Jury1
Quote...
this video ist SPAM ....!!!!!!
VIEV...
@FreeEnergyInfo
all is possible...  but I could not see much difference with the device Tiger2007. Place  the copper plate replace the coil ... No spark gap. But in the Wesley video from  Georgia, spark gap is missing.
I was able lay down the high-frequency alternating current of two coils.
http://www.youtube.com/watch?v=NE4LBBrbVvw
MasterPlaster
Quote from: microcontroller on November 02, 2011, 08:40:20 AM
Offcource there is.
You find things that make sense and you find things that are suspicious.
Besides, untill you got one running in front of your eyes you can never be sure.
@microcontroller, OK you have said what you wanted to say. So now, please clear off. There are lots of sites where you can communicate with people like yourself.
Hope
Quote from: energia9 on October 31, 2011, 07:58:42 PM
im very close to replicate, the pressure will be soon off from wesley and others shoulder.  everything will be clear,
and people.
Never forget
Life is nothing without love.
without love: life would be violent for all.
So strenghten it. and we can make this place all harmonious.
positive feelings are your best tool to defend yourselves from any negative energy.
Well said!
Peace
wattsup
@T-1000
1) Please explain to us what the yoke coil replaces. Does it replace the flyback transformer (FBT) or the caduceus coil (CC) or is this a totally different system.
2) If it replaces the FBT, then should not the 150 turns coil have tap points at every 1/5th of total winds to put the small capacitor across the 3rd and 4th taps as per your diagram.
3) If it replaces the CC, then the topology is totally different concept. Can this be correct.
4) Another question is why do you guys want to work on the yoke coil when your first device works and people already started getting the components, etc. I think with the first device using the flyback and CC, we should look at this effect because it works with the CC that is extremely easy to make.
I have done some frequency hunting with the CC and have found some good effects. I will make a video hopefully tonight when I get back from work.
Also, I think I blew my flyback which was the standard dioded type. When I tried putting the HV output through the second FBT coil as per your diagram, I think the internal diodes just played havoc with that second coil.
5) Because of this, I would like to know if all have convened on a close match to the FBT you are using. Also, if we can identify the closest match to your flyback and if there is a good steady supply, I am willing to have one sent to you to try on your build, just to see if any other flyback will work before we all spend so much more time trying to hunt around for the right flyback. Maybe such a plan could be coordinated via @stivep and I am more then willing to paypal the expenses if this can lead to you trying a more widely available FBT model.
While testing my standard FBT, I have noticed that along with the HV output, there is another output. That output is the flyback returning to the power supply. When I provided the input power via my regulated DC power supply, the amperage and voltage reading flew through the roof and even if I put my Fluke 87 True RMS Multimeter across the feed supply, I could not get any readings as it only showed "overload".
So there is power exiting the FBT from the HV side but there is also some tremendous flyback return via the input side of the FBT that may need to be properly captured and returned to source.
I have so many more questions and even some requests for you to try certain variations but there has been so much off-topic things that it is not the good time.
Please do not give up on us.
wattsup
